Question about Motorola XTN and Spirit Pro Replacement 10-hour Plug-In Wall Charger 2-Way Radio
Ear bud/ptt, not working
I bought a ear piece with ptt and it is not working. When I push the ptt it does not work.
How do I switch it to external mic?
  • Motorola Master
  • 1,654 Answers
Two things to check for:
1) The radio is shut off when you plug the earpiece into the radio.
2) Your VOX feature is shut off, or set to zero. (The XTN radio will sense an audio device is plugged into the jack and sometimes cause problems such as you are having.)
Lastly, be certain the accessory is designed to be used with the XTN style radio.
Posted on Nov 21, 2008
My samsung s4 has a problem when i call someone they can hear me but i cant hear them .i tried testing my ear piece by pressing *#0*# and tested its working fine. After testing it would work...
Do you have the correct type of ear buds for the Samsung? When I first got my Samsung phone I only had ear buds for the iPhone, but they are wired different than ear buds made for the Samsung. I went online and bought ear buds for the Samsung and now all is copacetic.
Feb 24, 2015 | Samsung Cell Phones
Just moved to new location and hooked up i com. Am only getting sound in left ear. Have rechecked everything and all connections seem sound???
this is an oxmoron you cant have checked every thing
left and right ear audio on CBs come from a common mono signal
so the right ear signal is missing or the headphone on the right ear piece is busted
Nov 27, 2014 | Icom Ptt Over Ear Mic / Ear-phone For...
No sound from speaker but through ear piece I get sound.
Many devices will automatically switch off the large speaker when ear phones are plugged into them. Also there may be a switch or button or prompt on your radio to switch between regular speaker and ear phone jack. Look for that first.
Try connecting and disconnection ear phones while listening to a station and see if the problem is intermittent. If is works sometimes but not every time then it is most likely an internal connection.
You will have to access the inside of the radio to investigate further. Connect a working external music or sound source with speaker wire to the terminals inside the radio that connect to the radio's speaker. If the radio's speaker works with the external sound source then you know it is a bad connection inside your radio. If the radio's speaker does not work with the external sound source then it is most likely a faulty radio speaker. Look closely for a broken solder point or broken/disconnected wire.
Sep 10, 2013 | Eton E100 SW/FM/AM Radio
When I press PTT the walkie talkie turns off
Dead, shorted, not fully charged, bad battery connection, or bad battery.
Jun 15, 2012 | Radio Communications
Is it possible to fix a non working PTT button on a RDV2020
The PTT button is one of the common failure parts. It is replaceable, but best done by an experienced repair center.
The following things can happen over time:
1) The internal PTT switch can wear out from frequent usage.
2) The user begins to press harder to get the PTT to work, bending the PTT switch further away from the external button the user is pressing.
3) Plastic diaphram, if any present, gets broken in half, and the external PTT switch doesn't work anymore.
Several companies offer flat rate repair on this style unit for around $85.
Best regards.
Aug 02, 2011 | Motorola Mobility RDV2020 RDX Series On...
My Nokia 6600 fold phone wont answer automatically on hands free.
I KNOW THAT NOKIA 6600 DOES NOT HAVE push to talk or (PTT)
thanks for that question.....
Feb 13, 2009 | Nokia 6600
Two-Way Radio LI 5650 WXC -> ear bud doesn't work
Did you try plugging in the audio device before turning on the radio? If so, follow this by pressing the PTT on the radio once. It should clear the problem.
Dec 07, 2008 | Radio Communications
Soft, rubber like piece cover speaker on Samsung WEP170 Bluetooth
I bought a pair of Sony headphones for my MP3 player, they came with three sets of rubber covers for the bud part of the head phone.
I have the WEP 170 also but didn't like how it fit in my ear, so I took one of the Sony bud cusions and replaced it with the one on the WEP, works great and even helps to cancel out noise.
Hope this helps
Jan 23, 2008 | Samsung WEP170 Wireless Headset
Transmission problem
A couple of things you can try:
1. Use electronic contact cleaner (spray type) on the PTT switch;
2. Use an external speaker/microphone and/or handsfree VOX headset
3. Replace the PTT switch. 4 solder points. Might not be easy but doable.
The last would require that you remove the defective PTT switch and use that as per sample when looking for replacement. Some printers uses the same type of switch. Familiarity with electronic components/circuitry, use of a DVM and a soldering iron would also be required.
Hope this be of some idea/help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Dec 17, 2007 | Motorola Talkabout T5800 (22 Channels)...
Motorola XTN and Spirit Pro Replacement 10-hour Plug-In Wall Charger 2-Way Radio Logo
120 people viewed this question
Top Motorola Radio Communications Experts
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
