Question about Goodman GMS90703BXA Heater
No light at all on board
I have no light at all on my board. I have power to the unit, but it will show no signs of turning on (like it has no power). I would have to guess the board is shot. It seems like a pretty easy job to replace. Is there anything I can be missing or should know.
  • djm41368 Nov 22, 2008
Have you checked your fuse? It happened to me and drove me nuts. The board would not even get the termostat to triger?
Posted on Nov 21, 2008
  • MasChingon Nov 21, 2008
    It should have a 3 or 5 amp fuse on the board.
Whirlpool ADP3315 dishwasher no lights no response.
If you wish to get some details; check the site linked here. Pull up older posts.
Jun 05, 2016 | Televison & Video
What is the most common problems that occur in Seiki tv model # SE50FY10 when the screen does not turn on but the power light is on?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 06, 2016 | Seiki Televison & Video
Where are the fuses located in onkyontx-sv525- only found 1 at power in
If you pulled the cover and only see one fuse, and if it is not blown, then you need to search deeper for the problem. All replaceable fuses on the main board are viewable.
May 08, 2015 | Onkyo TX-SV525 Receiver
I have a Sony Bravia kdl-40xbr9, when I turn it on it shows no picture or sound , the green light and Sony logo turn on normally. When I take the power cord out and put it back again , the Bravia sign and...
It sounds very much like a main digital board problem. Who advised you to replace the power[G] board and T'Con board; I don't know. I've went through this fault; a few months back with my carrier, but failed make it right because, the main board was not available either at the open electronic spare part market, or by the authorized service centre for Sony here, in my country. The people at the service centre asked me the set to be to their custody for repair; and I refused. They won't sell the main board outside; they say. What to do? It is still in my workshop.
So I advice you to contact the authorized service centre; in this case. Gopakumar Gopalan Google
Sep 17, 2014 | Televison & Video
Power turns off after 2 seconds once turned on.
Get an ESR meter, not all caps show outwards signs of failure.
Feb 05, 2014 | Televison & Video
E2 error on pro form 730 key in belt and motor run about 5 sec and shuts down sensor light blinks but not a steady light
Dear Sir:
I will try to help you, use the patience and carefully: need screwdriver, hex, allen+Dvom(DigitalVoltemeter)
Troubleshooting: ERR2 - Motor Movement
Since the motor moves when you press speed up, focus on the optic sensor, its wire connections, and the
optic sensor wheel. If all seems well at the sensor, inspect the motor.
Optic Sensor
??? Optic sensor wheel - Make sure that the optic sensor wheel rotates securely, without wobbling, in the
middle of the optic sensor. Realign and tighten if necessary. If optic sensor wheel teeth are missing or
bent, replace the optic sensor wheel.
??? Optic sensor wires - Make sure that wires are inserted securely to the optic sensor and to the drive board.
Check wire continuity.
??? Optic sensor - Turn on unit power. Turn the motor flywheel with your hand. The optic sensor
indicator (LED10, drive board) should light. . If it does not light, and all parts above are
good, replace the optic sensor.
??? Motor arcing - Does the motor show signs of wear - irregular arcing, carbon dust?
??? Motor brushes - Do brushes show signs of irregular wear - cracks, dents, lines? Replace the
motor brushes.
??? M+ M- Wires - Make sure wires are connected properly.
??? Display main IC - To ensure proper signal processing, press down on the main IC on the display
board, marked U5. .
??? Ribbon cable - Ensure that the ribbon cable is attached at the drive and display boards. Check cable
Troubleshooting: ERR 2 - No Motor Movement
Turn unit power off and then on to clear the ERR2 message from the display. To test whether the drive
board is putting out power to the motor, insert multimeter probes on the M+ M- connectors and press
the speed up key. . (Note: To avoid ERR2.)
Power to Motor
If the drive board puts out power to the motor, but the motor does not operate, either the motor wires or
motor is malfunctioning. Test wires for continuity. Inspect connections. Perform an ohm test on the
motor . Inspect motor brushes.
No Power to Motor
If there is no power to the motor, either the signal is not arriving at the drive board, the transformer
or inductor is bad, or the drive board is bad. Inspect the following:
??? Display - Does the display beep when you press speed up? If so, the display has sent its signal.
If not, inspect overlay-to-display connections. And press down on the main program IC, marked U5.
??? Wires and their connections - inspect data cable connections from the display to the drive board,
test data cable continuity, inspect M+ M- wires from the drive board to the motor.
??? Inductor (6310 only) - inspect inductor and its wires and their connections. .
??? Transformer - inspect the transformer and its wires and their connections.
??? Drive Board - inspect the drive board for burnt or cracked components. Inspect LEDs (See DRIVE.03
and DRIVE.04). Press on the drive board IC chips to ensure good connection. If the power indicator on
the drive board, LED8, lights, but there is no power to the motor, and other components are good,
replace the drive board.
wITH THIS YOU FIX IT. If you need further assistance, please reach me
Oct 20, 2011 | Exercise & Fitness
GE model PDS22MFSAWW, clicking as if the unit is turning on and off? The digit temperature lights are gone, but fridge is running okay?
Due to the digital temp lights no showing , this is a sign of the main control board bad . The clicking from behind the refrig , clarrifies this . Replaceing the main control board , behind the refrig , behind the small 8 " X 10 " panel , will solve both problems . The part # WR55X10942 .
Dec 14, 2009 | GE Refrigerators
Projector turns on the power light flashing and lamp light solid
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jun 12, 2009 | HP Digital Projector Vp6120 Multimedia...
Tablet pc
did you depress the reset on the bottom of the unit?
Jun 10, 2007 | NEC VL-PAD-933 Tablet PC
Won't Power On
This reply does not solve the problem, however my MAYTAG M7DH
45B2A DEHUMIDIFIER had the same problem.
Circuit Board COR 268BV1.O had circuits burned (on lower side of
board). The circuits that showed signs of arching were the right end
of D1, D 2, D3, D4, and at C2, C3, C4, C5, J1, O1,.
Apparently water must have entered the area and shorted these circuits. But I do not know. The only alternative is to replace circuit
board or junk it
Mar 25, 2007 | Maytag M7DH45B2A Dehumidifier
Goodman GMS90703BXA Heater Logo
37 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
