Question about Thermador SEC301BPSS Electric Single Oven
Door The door on this oven will not stay closed all the way. I have taken the door off and put it back on, but no help. The light will not turn off because of this problem. Please help
  • 175 Answers
Your oven needs two new hinges on the affected door. I have seen this problem many times, the internal stops on the door bend over time and cause the door to not close all the way. They are fairly easy to replace, you just have to split the door open to repalce em. Hope this helps!
Posted on Dec 21, 2006
    Welcome Back:
    Visited the website for 2 consecutive days.
I had this problem with a Thermador wall oven. Two service calls later, new hinges and a new oven box and the door would still not close completely without a push. The service repairman said this was all he could do. A year later I took matters into my own hands. I found that the cabinet rails were not installed level (1/4" off)and square to the face of the cabinet. I reinstalled them level and the problem went away. You have to have the supports that the oven sits on level and square to the cabinet face. If it is not no hinge replacement or new oven box will help. To see if this is the problem pull the oven from the cabinet and put it on a table then see if the door operates correctly. If so the rails are not level and square. engine262000@yahoo.com
Posted on Jan 01, 2007
  • Pat Davies Sep 16, 2007
    Make sure the oven is mounted correctly in the cabinet. I had the same problem. The rails that support the oven where not level. This caused the oven door to not completely shut. To test this take the oven out and place it on a table. Try the door now. If it closes completely that is you problem.
Oven door closes but does not fit snugly against the face of body of oven. have taken door out and put back in/on with no joy, owner of oven thinks it has been like this since new.
It is like that on the bottom, of my own door of my oven.
Since new! On the older oven I had, you lifted the door and it's hinges up and out and the door came off to make the old way of cleaning the oven easier - when you put it back on, the door would pull up tight on all sides - new ones' seem to have a gap
Mar 12, 2015 | Ovens
My JenAir oven door doesn't close fully
most likely you have bad door hinges if the door doesn't close correctly,i don't know if you know this but alot of parts are no loner available for this model,it must be old,the only thing you can get for the door is the hinges and that's it,you'll need the rest of the model number to get the right hinges you're missing the last two letters,you can go here put your model number in to look up parts.
https://www.searspartsdirect.com/model-number/JMW8527CAB/1266/0125300.html
go to door and look at part 16 the hinge,hope this helps you out,when you open the door,if it sags down lower to the ground the hinges are bad,when open it should be at a 90 degree angle
Feb 01, 2018 | Jenn-Air JMW8527C Electric Double Oven
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
Door hinges appear to be sprung
pull up alittle on door then back down to seat the hinge
unless you put something heavy on door , this should work
Mar 02, 2009 | Frigidare FGB24S5DC Gas Single Oven
Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Oct 13, 2008 | GE JKP15 Electric Single Oven
Lower oven door
here is my video might help you.
Mar 02, 2008 | KitchenAid KEBC277 Electric Double Oven
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
Thermador SEC301BPSS Electric Single Oven Logo
770 people viewed this question
Top Thermador Ovens Experts
goober123
Level 1 Expert
Oloyede Monsuru
Marvin
Marvin
Are you a Thermador Oven Expert? Answer questions, earn points and help others
