Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Color seems to be pealing up from the bottom of screen
The color seems to be pealing up. There is about 5 inches on the bottom of the screen that is pink in color. You can still see the picture through this. Directly above the pink is a green color and when there is writen words on the bottom of the screen in pink there is duplicate words in the green section. Is this something that I can fix myself or is this something that a technician must do? Thank you.
  • Philips Master
  • 3,459 Answers
If the screen is bouncing...expanding/shrinking you need to get a repair kit from www.TvRepairKits.com
If your screen looks 3d in color, has a stationary bow, or if you can't adjust one or more colors from the "convergence" menu you need to buy a convergence repair kit. You can get one from the same site listed above.
Hope this Helps,
Posted on Nov 29, 2008
Horizontal line about 1 from bottom of picture
The t con board or LCD panel of the tv is faulty. Can confirm by replacing the t con board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 13, 2016 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
I HIT THE RESET AND NOW IT SEEMS FROZEN. KEEPS SHOWING THE IRULU SYMBOL FLOATING AROUND. NOW WHAT?
get it to power off total . hod the switch for 20 sec
power up .
if it wont power it up with a usb attached to computer that can trigger it to go into debug mode
Jan 05, 2015 | Irulu 2014 7 inch Android Tablet PC, 4.2...
I have three black circles, and some color streaking at he bottom inch of my RCA, LCD tv
that is usually caused by cleaning the screen with windex the windex runs down the screen bewteen the screen and plastic frame and actually seeps inside between the screen layers. Eventually it may go away by itself if the circles are not too bad but in most cases the damage is permanent.It can also be an issue called screen delamination which there is no fix for.
Mar 02, 2012 | RCA Televison & Video
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
I have a hitachi 43FDX10B ultrascand HD rear
well it seems to me that you need to call the manufacturer to see how to reset the pixels for that tv. it seems someone has taking a magnet or something like that to the tv screen
Nov 29, 2009 | Hitachi 43FDX01B TV
Convergence problem, I think
i think you need a tech .because all the users adjustment were tried.
May 28, 2009 | Hitachi 57F500 57" Rear Projection...
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
KDF-E50A10 Sony TV Purchased May 06
IF THIS HAPPENS ONLY WHEN USING HD SORCE THEIR IS A MODIFICATION TO BE CARRIED OUT.IF NOT THE OPTICAL BLOCK WILL REQUIRE REPLACING.
Nov 10, 2007 | Sony KDF-E50A10 50 in. LCD HDTV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
199 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
