Question about RCA P46921 46" Rear Projection Television
RCA 46 in rear projection
Hello i have a rca rear projection tv that has sound on all of the channels but like four or five. I have tried using new coax and plugging the tv in directly to the wall but still the same results. It is also the same channels that never work correctly. I have great picture but no sound.
  • matt garner Dec 20, 2006
    thanks first all for the info! hummm.. well i tried that and stilll nothing... think the tv tuner could be out?
  • Anonymous Jan 27, 2009
    I do not know how to disable the sap setting and turn it off to restore volume to my channels.
    Sergeant:
  • 308 Answers
The first thing that I would check is in the audio menu to see if it is set on the SAP mode (secondary audio programming). If it is and there is no audio being broadcast on that channel, then you would have to turn SAP to off (which is usually what it is set to). Now there have been problems with the audio dropping out on regular CRT style RCA televisions where the audio would drop out, and you had to unplug the set for about 30 seconds to reset the TV, and I would try that next.
Posted on Dec 20, 2006
SOURCE:
RCA P46924 46" Rear Projection Home Theatre Gone Haywire
the button cluster in the front may have a bad tack switch(button) or the buttons may have loose connections. you can take the speaker grill off and look yourself...watch for wires..unplug your tv first:) also if you use spray cleaner that may have seeped into the button cluster too...you may be able to get the cluster as a whole from a local tv repair shop and put it in yourself..save labor charges:)
Mar 21, 2009 | RCA P46924 46" Rear Projection Television
RCA projection tv is blue and fuzzy
may be convegence try turning down the blue screen and see that that does see if the picture clears...
Feb 04, 2009 | RCA Televison & Video
No sound
there is a switch on the back of the tv that has internal and external speakers slection i would check that especialy if you have hooked up any new componants
Dec 07, 2008 | RCA P46924 46" Rear Projection Television
D52W19 RCA 46 inch t.v.
my RCA D52W19 52" rear projection TV will not power up ( turn on )
Nov 17, 2008 | RCA D52W19 52" Rear Projection Television
RCA P46924 64" Rear Projection TV
disconnect the wii it will eventually ruin your tv game systems can't be used on rear projection because of problems caused you may need to hook everything up at the bottom of the panel and switch back and forth using your remote we had to do that on ours
Oct 22, 2008 | RCA P46924 46" Rear Projection Television
RCA 46 inch convergence problem
AM sorry, but can you provide your model number TV and chassis please?. I will tell you location parts. Thank you
Jul 14, 2008 | RCA P52926 52" Rear Projection Television
Screen is blue no channels
if you can get pic using an external input you've got a tuning failure, if not video processing.
May 06, 2008 | RCA P46921 46" Rear Projection Television
RCA Projection TV
ok lets begin... shut off? ...is the set staying off. NO POwer at all.. does the set try to come on. does the set have a blinking led on front. have you tried unpluging then waiting 30 min then trying to turn it on again.. this set has a processor and when it detectect any fault will shut the set down
Mar 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hd61lpw42 rca tv
I also have an issue w/my RCA rear projection TV making a piercing sound. My TV does not do it on the HD channels, but does make the noise on the regular cable channels and on On-Demand as well.
I
Dec 27, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P46921 46" Rear Projection Television Logo
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
