Question about Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher I have a whirlpool dishwasher that does not appear to be getting hot water. The washer water is cold initially and only seems to get warm once the heater in the base of the machine heats it. The hot water supply line does not get hot so I presume no water is being supplied. Is the water supposed to be hot at the start. If yes could this be caused be a faulty inlet valve and if so how can I check. The dishes are dirty especially on the top rack. Thanks for your help. David
Gendos is on track with his question. I have the same dishwasher and it doesn't get enough hot water to clean the dishes and runs for hours because the heating element wasn't designed to heat water, just maintain it. The only solution we have found is to run the hot water from the kitchen faucet before we start the dishwasher. The only long term solution is to install a circulation pump on your hot water line, or find a dishwasher that pre-heats the water.
Posted on Mar 11, 2007
Wash water isn't hot even after we run hot water in sink before turning on dish water. However rinse water is hot. It appears the heating element is not working on wash but is on rinse?
Posted on Jan 07, 2007
Kitchenaid dishwasher KDC-18 works but the water does not get hot just cold. Any solution?
Dishwasher must be connected to a hot water line in order to work properly. Also, it often requires a good deal of time for hot water to make its way from the water heater to the dishwasher. If the dishwasher is located under the kitchen counter, turn on the hot water in the sink until it runs hot, then start the dishwasher.
Many dishwashers have a built in heater, but hot water should be initially fed into the dishwasher through the water inlet in order for it to perform properly.
Mar 17, 2013 | KitchenAid Dishwashers
Water not heating up
see this causes and fix it. God bless you
will not run on cold water or even luke warm water, it has to be hot water. Most will even specify 120F or hotter water temp as incoming water. These new units only use 1.5-3 gallons of water for each fill, so the temp has to be there. Many brands recommend that you run your kitchen sink water until it gets hot, then start filling your dishwasher, we also recommend that. Some dishwashers will stop if it senses too cold of water coming in, others will try to warm the water and if it can't in so much time, the unit will stop and give an error code. Hot water also helps dissolve and mix the soap detergent better, giving you better washing results. Just make sure the water is hot going into your dishwasher, no getting around it.
Oct 16, 2012 | Hobart Am-12a Commercial Pan Pass Thru...
Just got a new Bosch dishwasher (forget which model). After the dishwashing cycle has ended (even long after), the dishwasher and dishes are still wet. Was this an installation problem? Thanks
Hi -
I can't see how any installation problem would cause this - if the dishes are still wet at the end of the cycle, you'll probably find the water isn't heating during the wash cycle. The dishwasher uses steam to heat the washing compartment and dry the dishes. It would appear that the dishwasher isn't heating water internally.
Even if the washer was accidentally connected to the cold water supply ** (see note), this shouldn't happen as regardless of the water supply temperature, the washer should still heat the water to the correct temperature internally.
** UK dishwashers should be connected to the cold water supply. For US installations, dishwashers are commonly connected to the hot water supply. For other locations, please consult your installation instructions.
I suggest you start a regular wash cycle and leave it to run for 10-15 minutes. Then open the door and test the temperature of the water in the base of the washer by hand. The water should be hot and there should be steam present in the washer when you open the door.
If the water is cold or only warm, the water isn't being heated internally or isn't heating to the correct temperature, in which case you should contact the retailer or Bosch Service immediately for a replacement. Do not accept an offer of repair on a brand new washer!
Additionally, do not attempt to repair the dishwasher yourself when under warrantly as this will invalidate the warranty.
Hope this helps. If you need further assistance, please let me know your location and the model number of the washer. This should be laser-etched into the top of the door if you can't find it on any of your paperwork.
Regards, BElectric
Apr 27, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Do I need to use hot water when I first put my dishwasher in
No, you do want to make sure that your water heater is set to 125 to get the best wash
Nov 09, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Can you change the temp of the water coming in the dishwasher? Other than the temp from the hot water line. The temp to the sink is very hot but when you open the dish washer the water just seems very...
THE WATER LINE TO THE DISHWASHER SHOULD BE FROM SAME HOT WATER LINE TO THE SINK. RUN THE HOT WATER IN THE SINK UNTIL HOT THEN TURN ON DISK WASHER AND CHECK THAT THE TEMP IS CLOSE TO SAME TEMP. HAVE SEEN COLD WATER LINE USED. YOU SHOULD BE ABLE TO SEE WHICH LINE THAT THE WATER LINE TO DISHWASHER IS CONNECTED.
Mar 08, 2010 | Samsung DMR78AHS Builtin Dishwasher
My dishwasher is not heating the water up just running cold
Try turning on the faucet by the dishwasher and let the water run until it gets hot. Once this is done turn on the dishwasher and see if the water is warm or hot. Most dishwashers do not heat the water (residential dishwasher) they take the hot water from the hot water side of the sink. If the water heater is located a distance from the dishwasher then the cold water fills the dishwasher before the hot water can make it to the unit. This should cure your problem.
Hope this helped
Dave
Jan 15, 2010 | Dishwashers
Kenmore dishwasher. The upper rack is not getting clean. Even very light residue remains. And, detergent is left in door at end of cycle. The bottom is filling up, so I don't think it's the intake valve....
I find it odd that the dishwasher is filling with cold water if the water is hot at the sink. It sounds like the dishwasher is connected to the cold water line rather than the hot. Check under your sink; if you've got standard plumbing, the dishwasher supply line should be connected to the left water pipe.
Regardless, the water temperature doesn't fully explain the symptoms, especially the detergent left in the door (assuming you're using fresh detergent and it's not caking in the door prior to washing).
I would check the blades again. Even thought they may appear clean, there may be debris in them that get forced into the openings during operation, but fall away from the openings when the water flow stops. Remove the blades, run water into them, then invert them to drain while rocking back and forth. If there's crud in them, you may need to do this several times.
Sep 14, 2009 | Dishwashers
No hot water
Hi Jon, is this a new machine that you have just got? if so it sounds like the hot and cold water pipes are on the wrong way round. If not sounds like a thermostat problem
May 29, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Water not hot nor warm
When you run the hot water at the kitchen sink until it is hot and start a cycle on your dishwasher, is water hot when you open the door after it stops filling?
If no, the diswasher is connected to the cold water line, not the hot water line. The water temerature entering should be a minimum of 120 degrees but no hotter than 140 degrees.
If the water going in is hot, but it cools down after each filling then the heating element has failed and needs to be replaced. When the heating element fails, the dishes, especially the glassware will be foggy and still dirty.
Please reply with what you find. Good Luck!
Mar 30, 2009 | Dishwashers
Do not get a cold water wash from front load fridgidaire only hot
most diswashers only hook from the left side under the sink which is hot, some dishwashers on hot make the water extra hot with the bottom element for pots and pans, sounds like your dishwasher is working properly, you need hot water to sterilize. Rob
Feb 21, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
470 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
