Question about HP Computers & Internet
Power light which is green on power supply is on, but when push in the power button on the front of the machine, it does nothing and the green light goes out. I have to then unplug the the power cord and plug it back in and its green again.
  • 3 Answers
Chaque pwr sw pin in ur cpu
Posted on Nov 21, 2008
Fisher Paykel DS605i single dishdrawer with a user-supplied integrate panel. There are three buttons on front. The left-hand button is power button; the center button is start/pause; and the right-hand...
Hello, Thank You for using FixYa. I will be helping you today.Are any of the cycle lights lighting up like rinse and normal and is the light on front blinking and pausing if so how many times is it blinking? Try turning the power off too the unit for five minutes and back on, because if the lid was open some or was stuck it can stop the unit from running.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jun 29, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
My Compaq Presario SR1250nx will not turn on. The power chord is attached and power strip is turned on. I've also tested on a stand alone outlet to ensure it wasn't the power chord. A little green light...
Looks like your power supply's failed. The green light on the back of your power supply is just a neon light that just confirms that the power lead is OK, it does not relate to the status of the power supply! Try powering it up with another power supply, or replacing the power supply.
Oct 14, 2010 | HP Compaq Presario SR1250NX (PJ534AA) PC...
Pushed the on button, the green light comes on,
Green light comes on, what about other indicator lights? Is there activity like fans humming. Try to take out the battery and power up using the ac adapter only.
May 12, 2010 | Acer Aspire One PC Notebook
Computer does not power up. The green light on the back of the PS does not come on. I have 120 volts at the plug but when plugged into he power supply and push the power button on front of the computer...
make sure the switch on the back of the power supply is set to 120 volts , does the power-supply fan come on? if not it may be the power supply they are pretty inexpensive and not too dificult to replace
Sep 17, 2009 | Computers & Internet
Compaq proliant 5500 server wont power up
In my experience when a server/computer does absolutely nothing when the power button is pressed it is a dead processor. That may not be the case in your situation. It could be as simple as a defective power switch. Is the switch a soft touch or does it push in and click? Does the switch feel normal when pushed? One of the power supplies could also be bad. Do you have any good power supplies to test in the server? Were there any power outages recently that could have caused damage to the PSU? I would start with checking the switch. You could hook up a circuit tester and see if the switch completes the circuit when depressed. Also take a look inside the server and look for any loose connections on the mainboard. It is possible the wire for the power switch has come loose.
Sep 05, 2009 | Compaq ProLiant 3000/5500 Redundant...
Computer will not turn on
Best way to check is to open your case. Near the power supply plug to the motherboard should be a little led light. If it is getting power to the board this light should be green. If it's unlit then most likely your power supply has gone bad. Hope this helps.
Dec 21, 2008 | E-Machines Emachine T5026 power supply **...
E-Machines 2862 Dead On Power-Up
I believe that the front button is not connecting to the switch for the power supply. Also make sure all internal connections are secure. Sometimes the button breaks from behind so that it cannot contact the switch. Let me know if it helps. There are other solutions if you tried this one first.
Nov 01, 2007 | E-Machines T2682 (000002965) PC Desktop
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Computers & Internet Logo
220 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
