Question about IBM ThinkPad T20 2647 Notebook
IBM Thinkpad 770
Hi,I have a IBM Thinkpad 770 and when I try to in stall windows xp it runs 100% on first bar and when it goes to fine the next bar it gets to 60% and stops and says that the c drive is cerrupted.What can fix this . Thanks Jody .
  • Lalit Varadpande
    Lalit Varadpande May 11, 2010
    have u used one of the four options to format (FAT and NTFS,quick and otherwise)when it asks?or have u used leave file system as it is?
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
Try to format the System using NTFS and if it still says 'corrupted', the Hard Drive is faulty and you will have to get a new one
Hope This Helps
Posted on Nov 21, 2008
Laptop turns on, goes to first screen which reads IBM TRHINKPAD. THEN FLASHES OFF TO NEXT SCREEN WHICH READS THE WINDOWS XP LOGO then it goes black and doesnt come back on
Your installation of Windows is most probably corrupted. Try pressing and holding the F8 button on your keyboard when the 'IBM THINKPAD" screen disappears. That should bring you to a Windows menu where you can select various modes. Select Safe Mode and press enter. If it boots, then you know that something's wrong with Windows and not the notebook itself. What have you installed prior to this problem? Maybe you should try uninstalling it while in safe mode, and then try starting up Windows normally again.
If your windows doesn't start anyway, you should get some live OS (OS that can boot from CD) like Ubuntu or Puppy Linux, so you can save the data from C: partition (burn it or copy it elsewhere) and then reinstall your copy of Windows XP.
Sep 01, 2011 | IBM ThinkPad R32 2658 Notebook
I need a sound driver, ethernet controller for my ibm thinkpad r50
Assuming that your Operating System is Windows XP I have given you the details to download the drivers. Visit the link:
Scroll down to Networking: Ethernet section
Intel PRO/1000 MT Mobile Connection adapter (10/100/1000 Ethernet) - Click on 8 Feb 2007 - Build 135400 In the next page click on 7ira09ww.exe and download
If your Network Adapter is Intel PRO/100 VE Network Connection adapter (10/100 Ethernet) then click in the other link Build 94590 (Build 94590 supports models with Intel PRO/100 VE Network Connection adapter (10/100 Ethernet) only. In the next page download 1urc13ww.exe
Apr 26, 2011 | IBM ThinkPad R50e Notebook
XP Drivers for IBM ThinkPad x41
Feb 13, 2009 | IBM ThinkPad X41 Tablet PC
Can`t get think pad to boot windows
Feb 08, 2009 | IBM Axiom 20GB HDD ThinkPad 770 Series...
ThinkPad A21m won't boot into Windows
Did the laptop you got come at least with a windows XP cd? If so boot the laptop off of that and try to install Windows XP and see if it goes thru. Just make sure during the installation you tell it to delete the partitions first and then let it go thru that way you know for sure the hard drive is clean at that point.
Feb 02, 2009 | IBM ThinkPad A21m 2628 Notebook
IBM thinkpad 770 cannot get it to start atall
u may check ram. or motherboard may be damaged. go to any techanician and get it repaired, this fault cant be solved over internet
Dec 18, 2008 | IBM ThinkPad 770 Notebook
Screen flashes and goes black when you move mouse
some virus or spyware would have been the cause for tat...
go to start and then run,
there, type msconfig n press enter
in tat msconfig window, try clicking startup tab, there, try to remove tat virus startup, which would have been the cause for ur problem..
after tat restart and check, if it is solved
Jul 20, 2008 | IBM ThinkPad 770 Notebook
Thinkpad 600E
Error 19990301 on a Thinkpad 600 usually indicates that the hard drive is not properly connected, and error code 19990305 signifies "no bootable device". So, it's the hard drive.
First of all, I would try removing and replacing the drive to see if that cures it. You can get the service manual from Lenovo at
If this doesn't fix it, the hard drive is faulty. However, small size hard drives (10 or 20Gb) which suit these older machines are very cheap on eBay.
Dec 18, 2007 | IBM ThinkPad 600E 2645 Notebook
Computer boot up
There is either a problem with the graphics driver not starting properly or the boot.ini file of the operating system is corrupt. First thing to try is press F8 on boot up and this will take you into safe mode, if prompted for a password just press 'enter' When in safe mode highlight the line 'Last known good configuration' and press enter for a reboot, if all boots ok then it should be right. If still no screen, press F8 again on next boot up and this time select boot windows in safe mode and if it boots ok, there maybe a graphics fault or a driver error for something that starts on boot up, as in safe mode only the minimal drivers start (hence safe mode). If you get into safe mode first, right click my computer>properties>hardware tab>device manager, then go down the hardware list to graphics adapter,and click on '+' sign to your adapter, right click on line and select uninstall. Restart the pc then it will be automatically installed again and the drivers loaded. If you are still unable to boot then it is a process of ilimination to find what is causing the problem, but it will more than likely after trying the above be a windows system file error and require you to use your XP disc for a system repair.
Apr 30, 2007 | IBM ThinkPad 770 Notebook
IBM ThinkPad T20 2647 Notebook Logo
85 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
