Question about Olympus FL-50 TTL Flash
Connecting E-volt 510,FL 50 flash,and FP 01flash grip
How to connect so the shutter release on the flash grip can be used
neta
  • 852 Answers
SOURCE: Connect an FL-20, FL-36, FL-40 or FL-50 external flash
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-5060 Wide Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Posted on Sep 04, 2005
neta
  • 852 Answers
SOURCE: Connect a FL-20, FL-36, FL-40 or FL-50 dedicated external flash
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-750 Zoom. FL-CB02 Hot Shoe to TTL Cable -this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
neta
  • 852 Answers
The FL-20, FL-36, FL-40 or FL-50 external flash can be attached directly to the hot shoe on the camera. You also can use the FL-BK01 Flash Bracket and the FL-CB02 Hot Shoe to TTL cable.
  • 3 Answers
SOURCE: Non-syncing Olympus FL-36
Hey I have an E510 and an fl 36 flash unit and no problems for a year now.
And no problems at all {knock wood]!
Have you checked to see if all the flash pins are making contact?
Normally I only turn my flash on after I put it on the camera and then turn the camera off and then on again to see if everything is ok. I remember the flash would not communicate with the camera on a shoot and after a while I realized that the flash was not all the way in the hot shoe. Fool around with the flash off the camera first and see the flash have modes that you have to set up if the mode is set in full manual that might be a problem. There is a button that you have to hold down for three seconds to get in the menu. My buttons are fine and have not faded any at all. I realize that the power button an the flash is hard to press on, I do hope I was of help .GOOD LUCK
From Chris
Posted on May 11, 2009
SOURCE: FL-50 Repair
Here is the part that you need.
http://www.uscamera.com/cgi-bin/cart.pl
It will take some fiddling around with very small parts to get that installed.
Or you can send it in to Olympus- I know a couple of people that have been charged ~$50 for the repair and Olympus also reconditions everything as well.
Cheers.
Posted on Jun 02, 2009
Why is my fl 50 is flashing out of sync ?
Set Shutter at 125 or smaller
Set Aperture at 8
You never told us what camera was flash attached to.
atdlee@netzero.com
Jan 15, 2008 | Olympus FL-50 TTL Flash
Built-in flash and an external flash simultaneously
Yes, please see the following table: Optional Flash Flash Control Mode Capacity FL-50 TTL Auto (Super FP flash)/ TTL Auto/ Auto/ Manual/ Manual (Super FP flash) The FL-50 flash can be connected with the E-300 camera through flash power grip: FP-1 and flash cable: FL-CB05. FL-40 Auto/ Manual The external flash cannot be used with the built-in flash. * Only Auto and Manual mode can be set in the concurrent use of FL-40 and the built-in flash. (For their specification design, E-300 and FL-40 can not communicate in TTL Auto and R-TTL Auto modes.) FL-36 TTL Auto (Super FP flash)/ TTL Auto/ Auto/ Manual/ Manual (Super FP flash) The external flash can be used with the built-in flash.
Sep 04, 2005 | Olympus EVOLT E-300 Digital Camera
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Connect these external flashes...
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-770 Zoom. FL-CB02 Hot Shoe to TTL Cable - this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Connect to external flashes
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-770 Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Connect an external flash
For external flash use with the C-3030 Zoom, you will need the appropriate flash cable and grip. Please use the following as a reference: Exclusive Grip FL-BK01 - used to mount external flash to the C-3030/C-3000 Bracket Cable FL-CB01 - this cable is required for the dedicated FL-40 flash PC Flash Cable FL-CB04 - this cable is required for any "other" external flash/strobe use that connects with PC sync cable
Sep 01, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Sep 01, 2005 | Olympus C-3000 Zoom Digital Camera
Olympus FL-50 TTL Flash Logo
44 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
