Question about Roxio Easy Media Creator 10 Suite
I get an error in Creator Classic
When I try to use roxio creator 10 -Creator Classic I get the error message" Roxio Creator Classic has encounterred a problem and needs to close" what would cause that?
  • 69 Answers
I'm not sure what the problem is. Does it happen regularly? If it is regular make a note of any actions you take before the error occurs.
Check to see whether you have the latest updates for your software.
Also check on line to see whether any other uses have a similar problem check on any forums...
Roxio may have their own forums or be able to assist with your query.
Failing this you may solve this by uninstalling the software and reinstall it this may do the trick.
Kind regards
Alleluia
Posted on Nov 21, 2008
I have installed Roxio Easy Media Creator 7.5...It does not open. I get an error that Roxio has encountered a problem and needs to close.
Regarding on this concern, I would be providing you a link which could possibly help you in fixing your problem. Please refer to the link below.
http://kb.roxio.com/search.aspx?URL=/content/kb/WinOnCD/000103CR&PARAMS=
Cheers . .
    Feb 15, 2011 | Roxio Easy Media Creator 7.5 for PC
    I get error message,no permission to launch application using roxio creator 2010 pro, when i try to creator dvd.
    I will be providing you a link with a troubleshooting steps that you would need in resolving this issue. Please refer to the link below.
    http://kb.roxio.com/search.aspx?URL=/content/000244CR&PARAMS=set-locale=en
    Cheers . . .
    Jan 02, 2011 | Roxio Creator 2010 Full Version for PC...
    Roxio 9 compatibility with windows 7
    Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
    Roxio Creater 9 is not listed as compatible with Windows 7
    The following are from the Roxio site:
    The following products have been designed to be Window 7 compatible (as of January 2010):
    • Roxio Creator 2010
    • Roxio Creator 2010 Plus
    • Roxio Creator 2010 Special Edition
    • Roxio Creator 2010 PRO
    • Roxio Easy LP to MP3
    • Roxio Burn
    • Roxio CinePlayer BD
    The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
    • Roxio Easy VHS to DVD
    • Roxio MyDVD 10 Premier
    • Roxio My DVD Video Lab 10
    • Roxio RecordNow Music Lab 10 Premier
    • Roxio Easy DVD Copy 4 Premier
    • Roxio Easy CD & DVD Burning
    • Roxio BackOnTrack 3 Suite
    • Roxio CinePlayer
    Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
    After successful download of creator 2009, cannot open to homepag
    mine did the same thing, i called dell , they could not fix 7 techs tried and failed. so i went to http://support.roxio.com and download creator 2009 service pack 4 (52.5mb) u have to register it first, then download . follow the instructions . mine works now.
    Mar 29, 2009 | Roxio Creator 2009 for PC
    Can't install Roxio Creator 2009
    There is a patch from Roxio to resolve this error!
    http://kb.roxio.com/content//kb/Creator/000217CR
    Deadog4201
    Feb 05, 2009 | Roxio Easy Media Creator 10 Suite
    Having installed Roxio Creator 10, I get a recurring message: "RoxMMTrayApp Module has encountered a problem and needs to close." Etc. It occurs even when I am not editing with that software. ...
    ROXIO Multi Media Tray Application Module Has Encountered a problem and needs to close.
    This Means ROXIO Creator 10 Try Application Encountered an error.
    And since it happens while burning a disc
    You should
    1. Uninstall ROXIO Creator 10 , and reinstall it to make sure nothing is corupted.
    2. If you still get the same problem it's time to check your intire system for errors.
    This can mean you will need to take trouble shooting steps.
    1. Use another burning program to see if you can burn without errors.
    2. if you can burn fine with another burning program like NERO then chances are
    you have an incompatability with ROXIO Creator 10 and should consult the documentation
    to see if your drive is actually supported by it.
    Do these things weed hopper and all will be well with you.
    Az.
    Sep 16, 2008 | Computers & Internet
    Even when not editing with Roxio Creator 10, I get the message: "RoxMMTrayApp Module has encountered a problem and needs to close." Etc. Why?
    Seems to be a common problem with other users also. Something is crashing when windows starts up. Try disabling it at startup like shown here at http://forums.support.roxio.com/lofiversion/index.php/t25600.html . If that doesn't fix it, it might just need an update. Check out http://www.roxio.com/enu/support/emc10/software_updates.html for updates to your software.
    Cannot Initialize API
    1. Try to launch Creator Classic to see if it can repair the engine files. a. Double click on the "Roxio Easy Media Creator Home" icon. b. Click "Creator Classic" under the "Applications" section. c. The Windows installer should launch and ask you to insert your installation disc
    Try this and see how it works, if it does not, contact me and give me more details
    Mar 25, 2008 | Roxio Easy CD & DVD Creator 6...
    Roxio Easy Media Creator 10 Suite Logo
    141 people viewed this question
    Top Roxio Computers & Internet Experts
    Marvin
    Marvin
    Alun Cox
    Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
