Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Won't turn on...
My TV shut itself down and now won't turn on. I hit the power button and you can hear the "coming on noises" and the timer light around the power button flashes but nothing happens. If you hit the button again it is like it turns off. You only get the "coming on noises" and flashes every other time you hit the power button. I called Samsung and they took me through the reset process but nothing worked. Please help.
    Sergeant:
  • 308 Answers
It's possible that the convergence IC's may be bad in this set along with a few resistors. A TV repair shop should be able to fix the set for you.
Posted on Dec 20, 2006
Replaced lamp, tv worked great for a week, yellow blinking status light, dust cover is secure and the switch is good. tv won't power up
Now the tv projection lamp tries to light up to the tv screen and shutting itself down,u hearing tv make alots of cliking noises to the tv set too?Yes,mean the Ballast board it is also dead,now must replaced the Ballast board too.The Ballast board only job are to ignite the tv projection lamp only.
Aug 09, 2011 | Mitsubishi WD62527 62 in. LCD HDTV
I have a D52GW12 tv. During a storm a couple days ago there must have been a power surge. I have managed to get the TV's power light to blink but it won't turn on. How do I reset the Tv or fix the...
Unplug from the wall and hit the power button on the tv. The light may come on dim then fade out or you hear a click. This means it has built in surge protection. Plug it back into the wall and you should be good to go if nothing burnt up.
Jun 21, 2011 | Televison & Video
I need help I just won a tv but it didnt come with a remote but I have a RCA remote transmitter. Im trying to program it for the tv but I dont have the book anymore can you please help me The tv is on but...
This Web page should allow you to find the codes for any devices you want to add for this remote.http://remotefinder.rca.com/default.aspx?site=rca
Other than that there is an easy way to program this remote.
1. Turn on the device by hand. 2. Hold down the device name key.(hold the TV button to program a TV) 3. While holding down this key also hold down the power key until the red light turns off and comes back on. Then release both buttons. 4. From here hit the power button repeatedly until the device turns off. 5. Hit the stop key at the bottom. Now the remote is programmed for that device.
May 05, 2011 | Televison & Video
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Remote was hit, shut set off, and can't get it back on. Sounds like timer is on.
First try turning the TV on from the Power button the set itself (assuming it has one).
If not, unplug the TV from the wall, wait a half hour, then plug it back in. It should come back on.
Also check that none of the buttons on the remote are stuck down, and that the batteries in the remote are OK. The toy might've stuck a repeating button down (like volume) which may have then drained the remote's batteries.
Apr 07, 2008 | Televison & Video
No picture no sound
Probably, the selftest fails while turning on. If this is the case, press input&menu buttons at the same time for 5 seconds, then the green led will start to blink. Let me know how many times the led blinks.
Regards
Mar 01, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
TV won' turn on
Solder, solder, solder! Shut down circuits protect crts to avoid permanent damage. If any of the deflection circuits are defective, or intermittent, shut down occurs. I have not only seen bad solder on deflection circuits, especially vertical, but also intermittent connections on the yokes themselves. I've also seen shorted convergence ics cause shut down. Don't forget solder connections in the power supply.
Jul 05, 2007 | Mitsubishi WS-55807 TV
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
201 people viewed this question
Jerry Greenberg
Jerry Greenberg
