Question about Sonic 3 Wheel Scooter
Battery charger wont switch over to charge on a sonic scooter
When you plug the charger up to the scooter it wont switch over to charge the batteries
  • 1 more comment
  • Anonymous Mar 28, 2009
    Scooter ran to the store key was removed while shopping, returned inserted key, scooter would not operate.
    voltage is 30V at hand controls, can the voltage be to high?
    Beep code is three pause one is this telling me that the thumb control forward reverse is not working correctly, the pot checks out as good, could it be a lower wiring problem or the main control box it's self, OR?????
    Thank you
    Lary
  • Anonymous Mar 15, 2014
    a 36 volt system, does not seem to be charging. Plug charger into wall outlet and green light come on at the charger, but plug into scooter light stays green. If turn scooter on charger flash's red which doesn't charge battery.
  • Anonymous Mar 30, 2014
    scooter TGB 50cc back wheel wont spin
I have a pride sonic scooter just replaced the batteries, meter on scooter shows full charge and changer shows fully charged but when I go to ride it it creeps along like the batteries are very weak?
Posted on Mar 18, 2011
  • 118 Answers
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
Posted on Nov 27, 2008
How do I charge my sonic scooter
Your Sonic Scooter battery is a 12V battery. It may be anywhere from a 5 AH to 12 AH battery, but all are still 12 Volts. You can use just about any 12 V charger, or Trickle charger to charge it. (The lower the Ampere Hours, the less time it will run before needing to be charged again.)
Apr 19, 2017 | Health & Beauty
How do I charge a moxie power scooter??
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
Feb 02, 2016 | Health & Beauty
Green ready light on Pride Sonic three wheel scooter wont turn on. What turns it on?
Hi if it is similar to pride x the circuit will shut down if key is left on for 20 minutes u will still have lights. Remove key for a short time then replace it & turn on ..goood luck
Jan 21, 2016 | Pride Sonic 3 Wheel Portable Scooter
My gogo elite traveller wont chrage. The charging light isnt on when i plug the scooter in.
Sounds your batteries are to low in voltage for the charger to recognize. Also check the fuse on the battery box, normally a red one 10amps.
Feb 13, 2015 | Pride Mobility Products GoGo Elite...
Batteries wont charge
You would need a voltmeter to check the charger in order to see if it is charging the batteries. New batteries if purchased from a reputable outfit will have a nominal charge and should work initially in order to test the scooter. Depending on the model check for blown fuses and disconnected wires on the battery boxes, connections, plugs and charging circuits including the wall outlet. The display on the scooter will indicate the state of charge and the key switch should work and give an initial indication that the scooter is on. If you provide make and model I can respond with more specific information.
Mar 23, 2014 | Health & Beauty
Scooter won't take a charge
scooter battries must be charged on a regular basis.or else the on board charger wont charge them .Try useing a trickle charger to bring them back to life. if you dont have access to one bring them to a local service station they should charge them for a small fee.
Jun 26, 2012 | Pride Sonic 3 Wheel Portable Scooter
How long will batteries last if not used?
Get the batteries tested .As a motor mechanic your husband should know about battery care you could have removed them and charged them with a car battery charger or any of the trickle chargers used to keep batteries charged while not in use
May 09, 2017 | Pride Mobility Products Sonic Scooter By...
Try to use scooter, clicking sound, then moves bout 4 inches. charged batteeries all night.
How old are the batteries? When you connect the charger, if the charger indicates the batteries are charged within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced.
If the battery indicator on the scooter says the batteries are charged but the scooter still will not move, make sure the freewheel lever is in the drive position.
If you continue to have issues, contact your sales person or the manufacturer to schedule a service call.
Oct 19, 2010 | Sonic 3 Wheel Scooter
New batteries, fully charged, still wont work
I will ask but don't take offence, so many people overlook the obvious, have you checked the free wheel lever/s are not set to free wheel (if it is the scooter will be relatively easy to push forward or backward) if set to free wheel then move lever/s to drive position
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Sonic_om.pdf
this is a link for the sonic scooter user guide, not 100% sure that it is the exact one or not but it should show you were to find the free wheel lock on your scooter it is in this guide and I would be surprised if it is not the same as yours. Hope that helps. Mark.
Oct 29, 2008 | Pride Sonic 3 Wheel Portable Scooter
Sonic 3 Wheel Scooter Logo
919 people viewed this question
Top Sonic Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Sonic Health and Beauty Expert? Answer questions, earn points and help others
