I would think one of your safety switches aren't making. Could be the seat switch, neutral lever isn't made, blade engagement lever is in the engaged position and this will not allow the motor to be turned over. Try that!
The simplicity has a a two point mounting system for the deck. It attaches to the front axle which has two runners that go to the front axle's rear support bracket.
Closely check the runners near where the pins that hold the mower deck. They are known for cracking and breakage. Secondly, closely check the decks metal center support bracket, it bolts to the center of the deck and supports the idler pulleys as well as the deck alignment and mounting. Those, too, are known to crack near the front just behind the front pulley.
HI jLAFORCE 1. Other possible causes include: Loose, Dirty or Disconnected Spark Plug in Your Lawn Mower: Check it out, clean off debris, re-connect and tighten. Fuel Not Reaching the Engine: Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
