Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer drum loose banging around
From what i have read about the frigidaire front load washers...the bearings and spiders fail which causes the drum to come loose and bang around. it seems like a common problem with them from all the problems i have been reading.
well the same loose drum and banging noise has happened to me with my frigidaire front load (unknown model number)...what are the chances that the spider and bearings are actually the problem...should i bother to call in a service guy? from what i have read it will cost at least 450 to that rate i might as well purchase a new unit for 600ish...if i do decide to get a new unit is there a brand that you recommend? thanks...
  • 6 more comments
  • Anonymous Dec 06, 2008
    Hello, My front load Fridgedaire washer drum is loose from whereever it is supposed to be. Thanks Kate
  • kittyorat Dec 17, 2008
    I have a 5 yr old Frigidaire stackable washer/dryer. the front load washer (mdl #gstf1670as0) suddenly began to squeak during wash cycle and then made unbearably loud banging noise during spin cycle...from what i've read and heard, this is common an "arm" or "spring" and will cost $450-$500 to fix...if it is so common why not a "recall"? I cannot find a solution anywhere except to fix self (if can) or buy new...this set replaced a 20 year old whirlpool washer & dryer that "still ran", but did not fit in new kitchen...what gives? defective product? kittyorat
  • pjharney Jan 11, 2009
    I also have the same problem with a Frigidaire GSTF1670AS0 front load washer. I purchased it on 1.7.2004 along with a house full of appliances, all based upon Consumer Reports' research. This thing started banging last week and when I called my local dealer I was told that it was 5 years to the day! I'm told that the repair could run about $450. I called Frigidaire and was offered a 5% rebate towards a new one (that'll just cover the sales tax here in Massachusetts).
  • badfrigidre Jan 12, 2009
    My front loader just started making this noise. This washing machine has cost me double what I bought it for in repairs, new engine at one point, etc.etc. Now the drum is completely off and making a horrid sound. I will not be buying a Frigidaire again. I bought the set brand new in 2002 when we purchase a new house.
  • Anonymous Feb 05, 2009
    Man... am I regretting this purchase!
    4 1/2 years old. Started having the problem just after year 3. Drum and bearings replaced a year ago. Now same banging rattling freight train sounds and movements have restarted.
    You can literally see the drum swing side to side during the cycle. Works like a charm on an empty cycle but even baby clothes makes the whites and colors cycles return that horrid shaking. Not to mention the ticking. Every other second ticking. Annoying.
    Not the legs. All balanced. Have heard everything from drums off kilter to rubber bad to bra under-wire...still the problem remains. A mystery if ever one existed.
    Not the location. Happens if on solid concrete (basement / first floor) or wood (upper or second level)
    Frightful. But then again, what do I expect when I buy a washer from a 'fridge company'? Next buy will be whirlpool or maytag. Costs more but I won't have to call in a repairman!
  • Anonymous Mar 08, 2009
    We purchased an electrolux ewf 1087 front loader just over 2 years ago. Same problem, noise started to come out and now it will not spin. Will go back to top loader as the last one that we had lasted 15 years (not because it was broken, but because the enamel paint in the drum peeled off and left stains on clothes)
  • Nikki Nicholson May 11, 2010
    Has anyone checked your shock absorbers. If they are plastic they tend to break at the top of the shock where it attaches to the tank. The replacements are much improved.
  • Curt Jul 12, 2012
    I know this issue is dated, but I had the same symptoms on my Frigidaire front-loader. I pulled the tub assembly apart to find the spider (sprocket, tripod, or other name) that mounts the drive shaft to the inner tub was broken on two of the three arms. This allowed enough play to bang around while it was spinning. The part is not available separately. It is sold with the inner tub for as low as $253. Adding labor, and, as was put, it is more sensible just to go buy a new washer. Even for a DIY'er to fix it doesn't make sense unless he can find the assembly used for a good price. My model has bolts that hold the spider/shaft assembly to the inner tub. Unless you're handy and can find the part, I recommend a new one!
  • 20 Answers
SOURCE: Front Loading Washer - Load Banging During Spin Cycle
hello, your problem is that your shocks are bad and need to be replaced. you can access them by removing the front lower panel. make sure you unplug the washer first. you will see 2 of them on either side of the tub. i belive you can twist the upper portion and then remove the bottom screew and remove the shock. of course before you start you should have the new shocks. and make sure their is no water in the tub.
Posted on Dec 08, 2008
  • 640 Answers
SOURCE: drum/frigidaire washer
wow thats a long hard job ,,overhaul....the part your looking for is the spin tube surport,,you have to take the hold drum out than seperate the front tub from the back bearing tub,,and pull wash basket out though front..,,also if you had a leak or surport broke and is making noise.. change back bearing tub too.i recommend a professional technician...but if you want to do it your self question how to change wash basket,,glad to help
Posted on Dec 27, 2008
  • 2651 Answers
SOURCE: A loud bang a hammer was thrown in there.
ouch!! can you "lift up " on t he inner drum with a movement of 1 inch or more??? if so sounds as if you needa rear bearing assy. dont know how old machine is, but genearlly if parts not covered its not a worth while repair. will run hundreds of dollars
Posted on Feb 14, 2009
SOURCE: Loud banging noise during final high speed spin
I have the HE3T which is 6 yo. Last week it started making a loud banging noise in the spin cycle. I had a repairman come out. He said it is the drum bearings. He said that it is a problem with these machines and to call Sears. He said that the drum and bearing is one assembly and that Sears should cover it.
I called today and Sears todl me that I have to pay for a Sears technician to come out a determine if it is indeed the problem. If so, it will be covered under the lifetime warranty on the drum. I have to pay for the service call $75.00 and if it is the problem, I will be reimbursed. Cross my fingers!
Posted on May 21, 2009
  • 4088 Answers
SOURCE: Frigidaire front-load washer making LOUD banging
Does the loose brace end look broken or like a bolt fell out of it. If it has the missing bolt appearance, look for parts on the floor of the machine. Look for where it was attached and re-bolt the part. If it was welded, it will require the same to fix the problem. Not a usual DIY fix.
Posted on Sep 14, 2009
Hi, I have a frigidare affinity front load washing machine and when it is running a cycle it sounds like the drum is banging around in the machine. It's a new noise, did something come loose? What
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
Interior drum is loose. The satin less steel drum on the inside seems to have come loose. The outside part is well seated and secure but the interior drum seems to have become loose.
if the drum bangs all around and is noisy when it's spinning the spider gear is broke.usually it breaks from using to much detergent,in a front load washer you use less water so you need less detergent,you should be using 1/4 cup of h.e. detergent,any more than that damages the spider gear,the metal that it's made out of is like a metal stud that you would use when framing a wall,the extra detergent gets in there and it's like sand paper it eats at the metal and it breaks and the drum feels loose.unfortunetly it's time for a new washer,the gear costs around 4 to 5 hundred dollars not including the can check to see if one or both shocks are broken or check the springs on the top sides under the top panel but it sounds like the spider gear to me.
Feb 21, 2011 | Frigidaire GLTF1670A Front Load Washer
A loud banging noise while spin drieing.
when the bowl is empty check that the drum is not loose that is the inner and outer concentric drums bist be solid in relation to each other. the whole unit will move around though If the inner is loose then you cant use the washer until the bearings and spider are renewed cheers
Jan 23, 2011 | Whirlpool GHW9200L Front Load Washer
My frigidaire gltr1670a washer is making a banging noise when on the spin cycle. I took the bottom cover off and watched the drum it doesn't seem to be from the outside of the drum cover it sounds like its...
It sounds like the spider arm supports in your washer has failed. The spider arms hold the stainless steel wash drum to the axle. You need to stop using the machine immediately since the wash drum is flopping around the plastic tub. It is an expensive fix. The replacement drum/spider can cost over $300 with shipping. Get a few estimates before deciding whether to repair or replace. Sorry.
Dec 09, 2010 | Frigidaire GLTR1670A Front Load Washer
Drum bangs while turning
if the tub is banging all around and very noisy in the spin cycle it's time for a new washer.the spider gear is broken,this happens from using to much detergent,the front load washers use very little water so you should only be using very little detergent and it should be H.E. detergent.the spider gear costs around 500 bucks and the detergent eats at it like acid,let me know how you make out
Aug 29, 2010 | Frigidaire ATF6000ES Front Load Washer
My frigidaire front load washer/rear control panel GSTR1670AS0 just started to make a VERY LOAD banging noise. I replaced the belt, but it is still noisy and then got the same banging result during the...
Could be Drum bearings, try Grabbing the inner drum and moving it front to back ,should have little or NO Play, assuming this is okay then check the counter weight, Concrete Slab on top of machine outer drum loose
Dec 06, 2017 | Frigidaire GSTR1670A Front Load Washer
Loose inner drum
your bearing is gone. needs a new tub assembly. its pricy
Feb 05, 2010 | Frigidaire GLTF1240A Front Load Washer
I have a Kenore Elite 110.45992400 and it is thumping when it spins and the drum feels loose when you try to move it around. I've been reading, I gather this is the tub/bearing assembly? What is the spider...
The drum bearing is located at the back of the drum, and it is held by a drum spider.
This is the drum spider:
The drum spider is attached to drum on one side, and on the other it has the drum bearing.
See here a general diagram: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
See also
how to mend it .com - Replacing a Drum Spider
Apr 17, 2009 | Kenmore Washing Machines
The drum bangs on the spin
Two possibles for this are aloose balance block or cracked drum spider.The front block is most prone to coming loose.
To check spider rotate drum little by little and pull towards you to check for movement.
Post back if further help needed.
Dec 19, 2008 | Hotpoint Aquarius WF220 Front Load Washer
During spin cycle started making loud noise now drum feels loose DURING SPIN CYCLE DRUM SOUNDS AS IF IT'S HITTING SIDE.. FEELS LOOSE WHEN I PUSH IT AROUND FRIGIDARE GLTF1040ASO
ckd your warranty papers sounds like rear drum support(spider) has broken will require new basket and rear drum half est cost 400-600 spider is not a separate part and rear bearing is probably damaged that too is not a separate part and require rear tub replacement
May 20, 2008 | Frigidaire GLTF1670A Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
3,680 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
