Question about Saeco Odea Go
Coffee drip seems to be clogged?
Normally, it drips a full cup. But, it recently seems to barely drip anything out of the spout. Any solutions as to unclog it so it drips the way its supposed to?
Changer de sorte de café le noir semble colmater les ouverture
Posted on Dec 14, 2008
Coffee coming one side only of spout
There are two ways to overcome this uneven drip of coffee into the cup.
1- Make sure the machine is placed on a level counter top. The coffee drips as a gravity flow. Machine placed on a tilted surface will allow coffee flow more on the tilted side.
2- It appears the coffee faucet outlet has not been cleaned/flushed with any coffee cleaners or descaling solution. Clean the coffee outlet as following:
* Prepare two or four cups of Baking soda solution.Fill the Baking soda in water tank and make few espresso, using the preground cycle.
** Then use two to 4 cups of descaling solution and repeat the process making several espresso.
Oct 14, 2014 | Gaggia 74845 Platinum vision coffee maker...
I have a model K40 (the fifth Keurig I have purchased). This one now barely drips water, takes forever to make about a third of a cup of coffee
There are instructions on youtube for the proper procedures to clean a Keurig. If you ever ran anything but clean water through the coffee maker, like reheating a cup of coffee the grinds in the bottom of the cup clog the system. Watch the video it is usually done with a small paper clip.and vinegar
Aug 30, 2014 | Keurig Elite K40 Black Coffee Maker 1 Cup
Jura-Capresso Impressa Z5 - left coffee spout is clogged the left spout only lets drips of coffee coming through yes we: 1. use only dry beans 2. have the water harshness setting below 10 (we only use...
As the coffee is dispensed, it is normal to have some residue left in the tubing and spouts. It is the reason that the machine will require cleaning on a regular basis using the Jura tablets that dissolves the coffee film. In the case the spouts get clogged, the best approach would be to dismantle the spout assembly. Since it may not always be possible, I found that filling a cup with a coffee cleaning solution such as Puly Cleaner (pulycleaner.co.uk) and having the spout dip in the solution overnight can help. Probably that dissolving a Jura cleaning tablet in a cup of warm water would provide similar cleaning power.
Dismantling the spout is rather straightforward. You start with removing the front logo by rotating it counter-clockwise. Behind it you will find a T15 Torx screw. Removing it will allow removal of spout cover by pulling the top part lightly towards you and then sliding it down below the spouts. Grab the spouts by the sides and wiggle downwards until it comes loose. You can now clean the spouts but will most likely need to soak it. See the video showing removal of the spouts @ youtu.be/9QlRGY0eX3s
Jun 08, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
Water does not go through the cup
The drip spout may be clogged. Easy fix, just poke through it with something like an ice pick or even a paper clip. Also, you may be using too much coffee grinds which could slow down or stop completely the flow of water.
Dec 25, 2010 | Keurig B60 Coffee Maker
Fixable???
If you let me know what color your drip b30 mini is I may have a drip plate for you!
My Email:
help@igotsweetdeals.com
Lets do a quick check on how to brew with this unit;
1 turn power on
2 add water
3 place mug under spout (do not use a clear coffee cup because sensors will not detect a cup)
4 push button
5 wait 3 minutes
6 enjoy your coffee hopefully
Hope this helps you, if you need anything else just email me with the address above.
My website is http://iwantsweetdeals.com/ where I sell Keurig replacement parts
May 26, 2010 | Keurig B30 Mini Coffee Maker
Both spouts seem clogged
I have a Jura Impressa F7 that had the exact same issue. To solve it was pretty simple. Try and make a cup of coffee, and while the machine is trying to pump the coffee thru the spouts, grab the chrome handle on the spout and vigerously move it up and down rapidly. You should notice small grounds of coffee dislodge and follow the stream of coffee into your cup. If you do this a couple of times, you will be able to clear the trapped grounds within the spout. Hope it works for you as well as it worked for me.
Jun 23, 2009 | Jura Capresso Impressa F9 Espresso Machine
Spout drip faberware coffe pot model 55
Hi. Go to repairshack.con for parts. bobbyone
Apr 01, 2009 | Faberware 12-55 Cup Coffee Urn
Coffe comes out in a longer than usual drip
See my B30-solution; same procedure!
http://www.fixya.com/support/t2900087-bosch_benvenuto_tkn68e75_coffee_maker
Jan 12, 2009 | Bosch Benvenuto B20 Espresso & Coffee...
Drips onto counter when pouring from carafe
There are other makes and models with carafes that do the same thing. One tip I saw on tv, though not for this particular brand, said one cheap fix was simply to smear the tiniest trace of vegetable oil or shortening on the pour spout. What is happening is that the liquid wants to cling to the pot. It doesn't like letting go of the surface. But water-based liquids readily let go of oiled or greasy surfaces.
I have a Stay and Go. I had the same problem. I tried this technique, and it worked immediately. Two issues I imagine folks will have with this is, it doesn't last (after a few cups, the hot water has cut the oil off the spout) and they will not like the idea of oil or shortening in their coffee. But the amount you need is so small, I never saw a trace of oil or grease in my coffee cup at all.
It does work, but... perhaps a different spout design or material would be better? Don't designers know about such problems?
Joe
Mar 02, 2008 | Hamilton Beach Stay or Go 45234 Coffee...
Saeco Odea Go Logo
451 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
