Question about Acer Aspire 1642WLMi Notebook
My computer keeps rebootin and rebootin
When I turn on my computer the ACER log appears than it takes me to a black screen where the tabs SAFE MODE, SAFE MODE with Networking, Safe Mode with Command Prompt and so on are....I click on anyone and then the computer appears like if it is goin to load but then a blue screean appears and about 2 seconds dissapears and the computer shut down and turns on again it keeps doing the same thing and dont stop...please I need help to solve this problem
  • angelitoroma Nov 21, 2008
    Thanks for the answer but how do I reinstall the computer operating system....do I need a cd or what if I dont have any cds
    Novelist:
  • 124 Answers
Don't click on anything, press the number one key and it will boot into safe mode , once it does try to restart.
Posted on Nov 21, 2008
    Scholar:
  • 64 Answers
If you cant start windows in a safe mode (safe mode with command prompt is the one I use) to do a system restore then you will need to re-install the OS (Operating System), Sorry for the bad news....but welcome to Windows....Try running the repair option instead of the full install with the OS Disk first……Some times you can get lucky and save the existing data….Good Luck and let me know if this fixed ya,
cbinny1
    Genius:
  • 3,422 Answers
HI,
When you get that black screen selecr LAST KNOWN GOOD CONFIGURATION and then wait for the windows to load.If it restarts again then you will have to reinstall your operating system.
  • Priya darshan Nov 21, 2008
    To install your operating system you will need the discs.I ma sure they were given to you with your Acer laptop?let me know.
What's wrong if your computer boots up but when it's time to login in the screen goes black?
Depending on what make and model of computer you are using i would advise pressing and holding the power button until everything shuts down and then power on and keep on pressing the F5 key then a black screen will appear and select Safe Mode and see if you can log in on safe mode failing that i would try doing a start up repair.
Jan 25, 2015 | Computers & Internet
Toshiba Satellite A200 - Logging In
Please restart in the safe mode once.And run a virus scan after that turn off your laptop and turn it on again now don't go into the safe mode just start the windows normally,enter your password and see if you face the same problem.
Jun 24, 2008 | Toshiba Satellite A200-0ET00X Notebook
When I turn on my emachines t3265 desktop computer, it freezes at the logo, and does not proceed to Windows so I can log on. What is the likely problem, and how can I fix it?
Turn it on.
Hit the ESCAPE (or TAB) key to replace that colourful logo with the technical details of the computer's POST (Power On Self Test) messages. Look for any messages, such as "unable to boot from disk drive" or "disk-drive not detected". Also, remove any CD/DVD media from the CD/DVD drive. Also, remove any 3.5-inch diskette, and disconnect any USB memory-sticks BEFORE you turn it on.
Jul 18, 2011 | E-Machines T3265 PC Desktop
Sul monitor Acer AL1515 compare Input Not Supported
When a monitor displays "Input not supported", the display resolution is set too high. To resolve this, change the resolution to a supported resolution of the monitor. What you can do is restart your computer to safe mode first. These are the steps going into safe mode:
1. Make sure your computer is off.
2. Turn on computer then tap F8 repeatedly once per second. Similarly, Windows advanced options menu should be up on you screen.
3. use arrow keys to highlight "safe mode".
4. press enter twice.
5. log on to your user profile
6. you will get a window asking you to press "yes" or "no". CLICK the YES button.
7. perform the next steps below according to your windows version (operating system)
In Windows XP
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
  2. On the Settings tab, under Screen resolution, drag the slider to the desired resolution and click Apply.
  3. When prompted to apply the settings, click OK. The screen will turn black for a moment.
  4. Once the screen resolution changes, confirm the change by selecting Yes. A timer will count down for 15 seconds to ensure the change is desired.
    Click Yes to confirm the change; click No or do nothing to revert to the previous setting.
In Windows Vista
  1. Press the Start button , select Control Panel, select Appearance and Personalization, select Personalization, and then Display Settings.
  2. Under Resolution, move the slider to the desired resolution and click Apply.
NOTE: For Windows 7, it should be similar to the steps for Windows Vista.
Jan 16, 2011 | Acer X193W LCD Monitor
The screen has go black. Every once in a while the screen goes from black to saying Acer. Everything seems to plugged in just fine. The problem even starts right as you turn the computer on. Does this mean...
It could also be your computer.
Connect the monitor to another computer and see if the problem disappears. If there is not a problem, then probably the VGA card of the computer is defect.
Another thing to try before sending anything for repair, is changing the resolution and/or refresh rate of the computer. Could be lower or higher.
Sep 17, 2010 | Acer V193w LCD Monitor
How to go in safe mode?
to go into safe mode, turn on your computer and constantly press F8 immediately. You will press the F8 button at the first black screen, that is, when your computer displays its log.
While pressing the F8, a windows option will be the next screen to appear, amongst the windows option, you will see safe mode there, use your keyboard arrow key to scroll to safe mode and press enter.
By now,your computer should be loading on safe mode.
Good luck.
May 18, 2010 | IBM ThinkPad R51 Notebook
Had a power outage and now computer keeps rebooting. saw solution about going to my computer properties advance and unchecking automatically reboot, but cant' get there because computer keeps rebootin
hi
while rebooting u press the F5 key for a while, it will redirect u to a boot menu,in this boot menu u have some special options to boot like boot in safe mode,safe mode with networking ,debugging mode,last known good configuration boot,start normally,etc u first boot in safe mode and try to deactivate rebooting in ur own technicand u have more options try all of them it will be ok in 2 or 3 options
Thank You '
Dnt Foget to Rate me
Apr 21, 2009 | Acer Veriton M410-UF9500P Desktop
My Acer cannot log in the normal screen but the safe mode
Do you see the white cursor on the black background? If so, press CONTROL+ALT+DELETE keys. If the Task Manager window appears. You can start the PC from the CD/DVD and choose Startup Repair from the choices given.
Apr 19, 2009 | Acer Aspire 5920-6727 Notebook
I have a ViewSonic flat screen monitor. The images on the sign in page are fuzzy and unreadable. I have Windows XP.
I would check the connections between the monitor and computer. Also the refresh rate and/or resolution might be wrong. To correct this, you will need to boot your computer in safe mode. (restart computer, right after the computer's logo appears rapidly press the F8 key until a black and white menu appears. Select SAFE MODE) once the computer boots to safe mode, the sign on screen will appear very large. Sign onto the computer once at the desktop, RIGHT CLICK the background and select PROPERTIES. Once the display properties window appears click on the last tab SETTINGS. Here is where you can adjust the resolution. Take the screen resoltution to a low setting. You can always change this later when you boot your computer normally to get a better view. Next click on the ADVANCED button click on the MONITOR tab, usually flat screens operate at a lower refresh rate then CRT monitors. I usually keep my refresh rate to 60 Hertz. Next click on the GENERAL tab. This will allow you to change the DPI setting. I usually keep mine set to 96 DPI. You may want to experiment with this as monitors vary. Once done, click on the APPLY button then OK. Restart the comptuer and see if this has improved your display. You may need to do this several times trying different settings until you get a clear display. If you've exhausted all these steps, try a different monitor or changing the cable. If that fixes the problem then you know you have a bad monitor or cable. Good luck, let me know how it turns out.
Dec 19, 2008 | Computers & Internet
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Acer Aspire 1642WLMi Notebook Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
