Question about Acer Computers & Internet
My ACER aspire 5315 was purchased in may 08 apears to have no power and will not boot up - battery apears to have failed even when it is connected to the mains power.
    Problem Solver:
Try removing the battery, connecting it to main power and see if it then boots. that usually works for me; if so, then replace the battery.
Posted on Nov 21, 2008
My aspire 5315 is stuck on resuming windows... it won't finish loading to turn the computer on, any suggestions?
Try re-booting, if that fails pull the plug from AC , remove battery, hold down on/off button for 10 seconds, plug into AC boot normally.
Nov 09, 2012 | Acer Aspire 5315 Notebook
I have an Aspire 5315-2153. Power cord is connected and a green light for battery. After pushing power on button, nothing happens. I hear no sounds or see anything powering up. Solution anyone?
Try removing the battery and leave the machine connected to the AC and try to boot again. The battery is a Li-ion and has a built in safety chip that stops the battery from charging when the battery is drained too low. This prevents the battery from rapidly charging and causing a fire in the battery. If this works then you have to replace the battery if you wish to make it portable. It will run without the battery in it.
Mar 23, 2011 | Acer Aspire 5315-2153 Notebook
Hi my acer aspire 5315 will not boot up, i turn it on i get nothing but the little cursor in the top right hand corner...can anyone help please thank u in advance
That is probably because some important boot files are missing. What you can try is to take out the hard drive and move it to another acer aspire 5315 computer. To take out the hard drive, remove ALL electrical components (power cable, battery, etc.), open the computer's hard drive bay, and take it out VERY carefully. Make sure you do not cut the cables. That could damage the hard drive. Then, you remove the hard drive on the other acer aspire 5315 computer using the same instructions above. Then, you can identify the missing boot files (they will be in a hidden drive called System Reserved), copy them onto your computer's hidden System Reserved drive (if it's missing you'll have to create one manually), and put it back in the other acer aspire 5315 computer. Make sure that you put the wires where they were when you removed them, otherwise the hard drive might not work. Then, try turning on the computer again.
Nov 14, 2010 | Acer Aspire 5315 Notebook
Acer aspire 5315 with no display
If you are connecting with external monitor, then you have to toggle the display Fn+F5 together, still not getting the display then,
Unplug battery and adapter,
Press and hold the power button for 20 sec
then try to turn on the computer
Nov 26, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5315 doesnt boot blank screen
When you power up the laptop press F1 or F2 or "del" key to enter in bios setup.
Then check your harddisk is detect or not?
Then also make sure SATA option is disabled in bios.
Then go to boot option and set first boot device as your harddrive.Then save settings and exit.
But if you even not able to enter in bios then you have reset bios settings and Refix RAM memory .
For that open back cover fo laptop and find cmos cell on motherbord pull it for 10 minutes so all settings of bios goes to factory defaults.
Let me know if you need more assistanse.
Sep 25, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
May 20, 2009 | Acer Aspire 5315 Notebook
Acer won't boot up
when any computer posts/boots up.
it goes through a sequence of initialising things before booting.
i,ve been repairing computers for around 12-15 years.
1st i,d try removing the ram ( memory ) usually underneath the laptop, behind a screw cover. Or ocassionally under the keyboard.
if 2 sticks of ram are installed, remove the battery. and 1 stick of Ram. put battery on and try to boot. if no joy with that try the other stick of ram. and replace battery-Re-boot.
If this works you have 1 stick of faulty ram or faulty ram slot on motherboard. Failing this. I suspect that the CPU has overheated, and therefore a replacement Processor should solve the problem.
Thankyou for using fixya.
Mike @ compurepair.
Apr 20, 2009 | Acer Aspire 5315 Notebook
My acer aspire 5315 doesnt boot up the power
remove the battery and plug in power..if it works then your battery having problem..if not then ur power adpter having problem...
Apr 20, 2009 | Acer Aspire One PC Notebook
My Aspire 5315 will not start
I actually contacted Acer by email for this and got a reply in less than a day.
Try the steps below for a power reset, to eliminate a hardware problem with your notebook:
1. Disconnect the AC adapter from the laptop.
2. Remove the battery.
3. Press and hold the power button for about 30 seconds then release it. (You will not see anything happen)
4. Connect the AC Adapter to the laptop. Make sure the AC Adapter is plugged in.
5. Turn the computer on as normal.
6. Once Windows boots, insert the battery.
If the notebook still does not power on, we recommend the notebook be serviced by our authorized repair depot. You can set this up for service yourself by going to; click on the link for Depot Repair. If you are out of warranty, or you would rather do this via phone, please contact Acer Technical Support at 1-800-816-2237, Mon-Fri 7am-9pm CST and Sat-Sun 8am-5pm CST excluding holidays. For out of warranty products please call 1-866-621-2237. Hours of operation are 7am-8pm CST, Mon-Fri, and Sat-Sun 8am-5pm CST excluding holidays.
Dec 17, 2008 | Acer Aspire 5315 Notebook
Computers & Internet Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
