Ethernet adapter registers as ''media disconnected'' even though it
I have just done a complete re-install of Windows XP and SP2. My ethernet connector is connected to my router, but when I type IPCONFIG, it says Media Disconnected.
    Top Expert:
  • Computers & ... Master
  • 77,499 Answers
Have you installed the router software?
Posted on Nov 21, 2008
  • 1,879 Answers
Bad cable,
wrong cable,
bad connection,
bad router,
router turned off.
Unless you have more than one network adapter in your machine. do an ipconfig /all
Update Drivers pour REALTEK8139/810X Family fast Ethernet NIC sur "XP"
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Apr 30, 2011 | Televison & Video
How to enable WPA security. i tried to enter the http://www.192.168.0.1 but the page is not showing theres no admin page.help pls
Try http://192.168.0.1 - you don't enter www. in front of an IP. Check that this is actually your routers IP address by doing Start > Run. Type "cmd" without the quotes and press Ok. In the black window that pops up, type "ipconfig" without the quotes. You'll see something like this:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\root>ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
IP Address. . . . . . . . . . . . : 192.168.0.2
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
Ethernet adapter Local Area Connection 2:
Media State . . . . . . . . . . . : Media disconnected
Ethernet adapter Bluetooth Network Connection:
If your Default Gateway Value is 192.168.0.1 then you're good to go, otherwise this value will be what your routers address will probably be.
Mar 01, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I reinstalled Windows XP to my computer and now i cant get the internet. There is a yellow question mark and exlmation point next to Ethernet Controller and it has a code 28 error.
You should have had 2 cds that came with your computer. The 2nd one has all the drivers on it. Install the drivers and your problem will go away.
Nov 19, 2009 | Microsoft Windows XP Professional
NFORCE4-939 do I need the ethernet network access manager?
You only need the Ethernet if you want to connect to a network. If you can not get the onboard ethernet to work, you can always use a USB adapter. By the way, have you downloaded the drivers from nVidia?
Jun 30, 2009 | EliteGroup NFORCE4-A939 (NFORCE4A93910)...
Media disconnected
If you are using one box (or modem/router) only, when your computer says media disconnected, it means that your computer does not detect your modem.
You can try unplugging and replugging the ethernet at the back of your computer or laptop. make sure that the light on the ethernet port is lit up (especially for desktops, not sure about laptops though).
You can also do the same process with the ethernet cable from your modem/router. if your modem/router has other ethernet ports in it, try to connect it to other ports as well. If your computer still says media disconnected, try purchasing or borrowing a new ethernet cable.
Also make sure that your ethernet adapter is working properly and that media disconnected follows after ethernet adapter local area connection and not wireless connection.
Hope this helps!
May 04, 2009 | D-Link AirPlus DI-524 Wireless Router
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
Wireless fails to work after reinstalling XP SP2
Hey there,
The wireless driver might only work on Vista, try the IT Administrators - Intel® PROSet/Wireless WiFi Connection Utility for Windows* XP and Windows Vista*from here
First uninstall the one you have though..
Hope this helps
Chris (ziraffa)
Sep 10, 2008 | Intel PRO/Wireless 3945ABG Network...
Ethernet adapter
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=in&dlc=en&product=3446906&lang=en this is link for your ethernet card driver and windows xp will automatically find driver of ethernet card if its not find then just copy sp2.cab and i386.cab in to %systemroot%\system32\drivers folder and then try to install it manualy
Sep 30, 2007 | Microsoft Windows XP Professional With...
Terrible slow internet connection after installing SP2
If you are sure it is a motherboard problem relating to the on board ethernet connection, purchase a PCI slot ethernet card and see if using the card manufacturers drivers are better than the motherboard ethernet drivers. Although i'm not sure how a slow connection is the motherboard problem, it maybe that it's SP2 thats the problem. Have you checked the driver that is used for the onboard ethernet connection, it maybe you need to re-install original motherboard ethernet driver you got with it.
Dec 07, 2006 | Albatron KX600S Pro Motherboard
Computers & Internet Logo
1,090 people viewed this question
David Payne
David Payne
