I attempted to enter service mode and do the trouble reset and it did not fix this code. I tried stop 00 stop 01 and the code screen comes back up and will not let me into the service screen. This code supposedly means that the HDD needs formatting but I can't format it because it won't let me into those options. Know of any tricks or alternate ways to format the HDD?
enter service mode, select state confirmation, select memory/hdd adj, select hdd format, select physical format, press start button, when displays ok turn off main power for 10 seconds, c-d010 will display again, repeat instructions and do logical format, turn main power off for 10 seconds..should be ok si
You have to press "utility" then "meter count" then "details" before doing the above, enter at your peril though one wrong button push and you could wipe the machine.
We can scan to email from a xerox MFP thru xchange2007 within the domain but cannot scan outside....
(More)
We can scan to email from a xerox MFP thru xchange2007 within the domain but cannot scan outside. Relay is set up for not only the machine's IP but the entire inside network (!). All credentials and NW config's. have been triple checked. There is a Savin 3740 MFP on this network that can scan outside just fine.
machine will not work, it says 'direction for this OHP size is not supported. Please change to...
(More)
machine will not work, it says 'direction for this OHP size is not supported. Please change to direction or set size larger than A4'.
