Question about Tao XM2go Satellite Radio Receiver
My tao xm2go will not turn on
High pitched sound for several months, freezes up occasionally
  • 3 Answers
Dear Glen,
My Tao solution is to buy the Delphi MyFi which appears to have an identical interface. See page 10 here: http://file.xm411.com/manuals/MyFiUserGuide411.pdf . This is expensive but service in not available.
digitally,
(/\/\<erwin
Posted on Nov 21, 2008
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
No sound comes out of radio?
Turn up the volume by pressing the top of the center cluster of buttons. Does it work in the home dock or car dock without headphones?
Nov 23, 2012 | Tao XM2go Satellite Radio Receiver
My Tao xm2go quit working. I've tried re-setting it. I've replaced the battery, I double checked that the charger is putting out the correct voltage with a multi-meter. it won't turn on, either with the...
Try plugging the power adapter directly into the bottom of the radio without using either base/cradle - wait a minute - then see if you get a battery indication.
Jan 18, 2010 | Tao XM2go Satellite Radio Receiver
My Tao won't turn on and when I put it in the craddle all it does is blink
Probably bad battery. XM actually recalled original batteries and supplied new replacements.
Oct 25, 2009 | Tao XM2go Satellite Radio Receiver
Failure of the battery to charge while in the home cradle
Wall transformer is bad or was replaced with lower amp unit. Same thing can happen with aftermarket car charger. Possible solution without replacing transformer: turn off LCD backlighting....
Sep 03, 2009 | Tao XM2go Satellite Radio Receiver
Atenna connection when using Altec Speaker or Car Kit
Dear xm2go,
I could not find any service options for my own Tao XM2go unit. The only option appears to be the Delphi MyFi unit which appears to be identical (see page 10 here: http://file.xm411.com/manuals/MyFiUserGuide411.pdf )
digitally,
(/\/\<erwin
Oct 07, 2008 | Tao XM2go Satellite Radio Receiver
Antenna Connection Problem
I have the same exact problem. I took a small needle nose pliers and pressed the antenna connection on the TAO radio. I put it back into the cradle of my Altec Lansing amplified speakers. It works again. For how long we will see.
Sep 05, 2008 | Tao XM2go Satellite Radio Receiver
Tao XM2go shuts off for no reason
You could try taking the batteries out and cleaning the contacts, replacing the batteries and/or using sellotape to hold the batteries in place. They could be loose and disconnect when you move it in a certain way. If not the batteries, you could try further dismantling and cleaning, but you may just end up with a clean ball of sellotape that still has problems...! worth a try. stoodleysnow
Aug 30, 2006 | Tao XM2go Satellite Radio Receiver
High Pitched whine when using line out with car power adapter
I was ready to mention the car's alternator but you say the noise is there if the ignition is on or off. What type voltage adapter are you using? It sounds as if it's the culprit. If it's an inverter I could understand the noise being generated. Have you tried earthing ALL the components involved? Earthing problems can cause some mighty weird things to happen.\ Are you sure nothing else in the car is switched on? eg. another radio or something with an inbuilt oscillator. Try running the power for the adapter straight from the battery and put a noise filter in line. Are you turning the engine off but leaving the ignition switched on? Doing this can cause a noise from the fuel pump. Oh and make sure the antenna is correctly earthed. Apart from that, I'm stumped BMW
Jul 17, 2006 | Tao XM2go Satellite Radio Receiver
Tao XM2go Satellite Radio Receiver Logo
268 people viewed this question
Top Tao Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Tao Audio Player and Recorder Expert? Answer questions, earn points and help others
