Sanyo ds 35580
My son recently had this model tv given to him, we can not get it to go to the DVD player that is plugged into the Red Yellow White inputs in the back. I am assuming this is something very simple to figure out but there is only vol up/down chan up/down menu and power buttons. I have tried auto programming w the dvd on with no luck. Please help me LOL
techman
  • 3130 Answers
SOURCE: Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Posted on Oct 16, 2006
JMuskovitz
  • 135 Answers
SOURCE: Need Help Setting Up DVD player to an old Zenith Television
You can find the owner's manual for this set online at: http://www.zenithservice.com/gcsc/b2c/hpi/main?tc=owm.command.OwmCmd It says that the BOTTOM four connectors are: 1. S-Video IN 2. Video IN 3. Audio (Right) IN 4. Audio (Left) IN Above the Audio IN connectors are two audio OUT connectors, which you could hook to external speakers, your stereo, etc. But these are not needed for hooking up your DVD player. From your DVD player, you need to hook up either the S-Video or Video connection (Video is typically the Yellow wire), plus the Audio connections (Red and White). If your DVD player has an S-Video output, this will give you a better picture than the standard Video connection. S-Video cables have a different plug, with four or five wires in the connector, and are keyed so they only fit into the socket in one orientation. Be careful to line it up properly and not force it in the wrong way.
Posted on Feb 28, 2007
konzzz
  • 255 Answers
SOURCE: Yellow input/output cable broken off in TV
you can use a screw small enough to fit in the middle of the tip of the cord.the tip is hollow so just remove any plastic or hard rubber that is clinging on the said tip.(use a big needle for this.)be careful when doing this.make sure that the unit is turned off and unplugged.after inserting the small screw,slowly twist and try to pull it gently until the screw is tight enough but not breaking, to pull the tip.
Posted on May 13, 2009
  • 290 Answers
SOURCE: connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Posted on Jan 02, 2010
bernardlunda
  • 318 Answers
SOURCE: I have a ds25390 sanyo tv and can not figure out
you can test your tv on a different tv. and a/v cables togather. yellow is video- white /red are for sound.
okay
Posted on Jan 05, 2010
I have a polaroid hdtv 32gsr3000 and trying to hook up a sanyo dvd to and when we play a dvd it has no coler all black and white we are using 3 cables that came with the dvd player.
Make sure you connected wires right both on player and tv. There are Two ways to connect it.
1. Use 3 wires: white, red, yellow. White and red are for audio and yellow is for video. Yellow need to be connect to yellow port on TV and DVD player
2. 5 wires. Again red and white are for audio. And there is another red plus green and blue. Those 3 are for video and have to be connected to corresponding ports on TV and pkayer. Make sure you don't mix up red wires
Dec 03, 2017 | Polaroid Televison & Video
Where can I find a connector cable for my Sanyo TV model DP32242 to my Sanyo DVD player model DWM380?
Gonna need three wire connector (is red/white and yellow, yellow for video, red for right sound channel, white for left sound channel). Standard, and sold at either Walmart or Radio Shack.
Dec 31, 2014 | Sanyo Televison & Video
How to hookup Sanyo DVW-6100 to a Sylvania tv
If the Sylvania tv is a CRT (old style tube tv) you can just use an RCA cable and hook it into the composite video. It will be the cable that has a red, white and yellow connectors on it. The yellow is the video, the red is the right audio and the white is the left audio. Connect ones side of this cable to the output of the DVD/TAPE player and to the input on the TV side.
Sep 04, 2014 | Sanyo DVW-6100 DVD Player/VCR
Where do i plug in my dvd player to a sanyo avm 2506
Get RCA cables they come in 2 or 3 conductors, Yellow andWhite for Mono and Yellow, White and Red for stereo connection.Connect the one side of the Yellow cable to where it saysVideo OUT on the DVD.
Connect the other side of the Yellow cable to where it saysVideo IN on the TV.
Connect the one side of the White cable to where it saysAudio OUT L on the DVD.
Connect the one side of the White cable to where it saysAudio IN L on the TV.
(optional) Connect the one side of the Red cable to where itsays Audio OUT R on the DVD.
(optional) Connect the one side of the Red cable to where itsays Audio IN R on the TV.www.aaatvservice.com
Jan 26, 2012 | Sanyo AVM-2506 TV
I have been given an Argos DVD Player. I have the lead with the red white and yellow plugs at both ends. No Manual, how to I attach it to TV. Do I use a Scart lead ? Thank you.
If your TV has what is called RCA jacks that is what red, white, and yellow color code is for. Red and white for audio, and yellow for video. If your TV does not have right and left audio in (red and white) There are adapters available at electronics store but not worth the price considering what a DVD player goes for these days.
Aug 21, 2011 | Computers & Internet
Hello. I recently bought a magnavox dvd/ vcr and attempting to connect it to my Sanyo DP32649-06 TV. The magnavox does not have the ant in or ant out plugs needed for my cable to appear on the...
Can you tell me the model # of the Magnavox?
What type of "out" connections does your Magnavox DVD have?
Old style Coaxial RG6?
Composite (Red and White for audio \ Yellow for Video)
Component (Red and White for audio \ Blue, Red, Green For video)
SVideo
HDMI?
Jun 11, 2011 | Sanyo Televison & Video
How do i get my sons dvd player in color. it plays every movie in black and white
Make sure the connection to the TV is correct. Yellow(video) jack from the DVD player will go to yellow jack of the TV, white to white(audioL) and red to red(audioR) for compsite audio/video connection. Red to red, green to green and blue to blue for component connection.
Dec 29, 2009 | Sony DVP-SR200P DVD Player
Trying to hook up a Philips 22'' TV to Sony CD/DVD player. Need help. I have a Red, White. and Black connector to go from TV to CD Player. Do I need anytning else? TV model # 22PFL3504D/F7
Usually the Color Red and White is for the audio channels and yellow is for the video but in your case you find black instead of yellow.
So you do the connection as per the instruction given below.
TV DVD Player
Red--------------Red
White------------White
Black-------------Yellow
Jul 25, 2009 | Televison & Video
I don't know where to put the yellow, red and white connectors on the TV or the dvw
look on the back of your flat screen , there is a panel with inputs , example: VIDEO 1 , VIDEO 2 , etc. , connect your yellow , red & white from the DVD COMBO to video 1 (input) there colored to match with your cable , yellow w/ yellow , red w/ red , white w/ white , hope this helps AJ
May 08, 2009 | Sanyo DVW-6100 DVD Player/VCR
Connecting to cable tv
if you have a cable that has 1 red 1 yellow and 1 white plug it will usually work plug the white cable into the white input and try alternating the yellow and red in the yellow input
Jan 01, 2009 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
