Question about Dell OptiPlex GX270 PC Desktop
Dell gx270 power switch
This dell will power up for a millisecond. U can hear the fans start, but then they turn off instantly. When u hit the power button, a green light comes on momentarily, but then goes off immediately. I think I need a new power button bcz u cannot hear it click. Any suggestions?
  • antonio77997 Nov 22, 2008
    Thanks, I'll try disconnecting everything. I had the power supply tested and it works fine. The problem I feel is the motherboard. I'll try ur suggestions and let u know. Thanks.
  • FedUpwithDel Dec 21, 2008
    I now have the same problem, only after having pressured Dell into replacing the motherboard in March 2008, which I learned was standard practice through January 2008 as zillions of these GX270's suffered from leaky capacitors which caused the first meltdown. (Thermal Event)
    Having spent the time to replace the motherboard with a refurbished one which took weeks to procure from Dell, its disgraceful that a second motherboard bit the dust after 8 mos.
    My advice... Dont waste your time! Replace the machine. While I have 10 different Dell machines in service with no problem, I have more HP/Compaq machines which have provided reliable service for much longer.... Though both companies are tough to deal with for the rare service/support problems that I've attempted to resolve that way. Most problems I resolve in house, but in cases like these you have no alternative but to contact them.
    Both are like big airlines... Too big and disconnected. I like the big names, and what choices do we have, so I think the 270 will get an HP replacement.
I TURN MY DELL OPTIPLEX GX280, MONITOR AND PRINTER OFF BY TURNING THE POWER BAR THEY ARE PLUGGED INTO OFF. WHEN I TURN THE POWER BAR THEY ARE PLUGGED INTO BACK ON THE COMPUTER STARTS MOMENTARILY THEN GOES BACK OFF. CAN I MAKE ANY ADJUSTMENT TO CAUSE IT TO STAY ON WHEN POWER IS RESTORED AFTER TURNING THE POWER BAR ON?
Posted on Jan 30, 2010
    Problem Solver:
  • 13 Answers
I don't think you need a new switch. The power "switch" on the front of computers today is a momentary action push button switch. Not a locking or clicking switch as older computers used to have.
Many of today's computers, including the gx270 / gx280 computers from Dell are really always on. You can see the green or yellow LEDs on the motherboards glow when they are "off" (like a sleep mode).
They are in a "sleep" mode until you push the power switch, which sends a momentary signal off to the motherboard to fully power up and turn itself "on".
I think you have something else happening here. When the system tries to power itself up, and detects a severe problem, it will try to automatically turn itself off.
The problem could be a bad motherboard, power supply, memory or processor. It could even be a failed hard disk that is drawing too much power (shorting out) from the supply.
If you had done something to the system, like move it or open it up for an upgrade, etc.. Look again at all the internal connections, and make sure there is nothing rattling around inside that might also be causing a short.
You could try removing all the PCI cards in the system, removing the power and data cable connections from all the disks (Floppy, Hard Disk, CD/DVD) and see if the bare motherboard (with CPU and memory) will boot by it self. If it does boot, then the problem was somewhere in those items and you can replace them one at a time until you find the problem, or if it all works again then it may have been a loose or bad connection.
If you have another machine available, you could try switching the power supplies and seeing if that is the problem.
-Chip
Posted on Nov 22, 2008
My dell 1550 is not starting it is starting and shutdowning and repeats the same what to do setup is also not working
This sounds like an overheating issue, either the fan intake port is clogged with hair and dust or the the fan no longer works and is instantly overheating. Listen for the whirl of the fan underneath the the laptop. If you hear aloud noise, then it is either clogged or the fan is going out, hitting something. If you hear no fan noise, then the fan is completely out and needs to e replaced, either way, check that particular part and get it looked at.
Jan 13, 2015 | Dell Computers & Internet
Gx270 tower mother board amber LED solid on
If the fan is not spinning this can be the issue ...but it can also be the motherboard itself ..if you have the possibility try to change the fan ..cause if it fails to start the computer will also fail cause the cpu it will shut down the system instantly if it has no cooler working ..(gets to the shut down temperature in one sec or so ) If it seams that it is trying to start ..but , like I said , it shuts down ..just try to change the fan ...but it may be a issue with the power supply or the motherboard as well...
Dec 18, 2011 | Dell OptiPlex GX270 Small Mini-Tower...
Fan stop working but computer turns on after a couple of mins it shuts down gx270
fan stop working but computer turns on after a couple of mins it shuts down gx270
try
cleang ram
repair os
Feb 12, 2011 | Dell OptiPlex GX270 PC Desktop
Unable to power on a dell gx270. swapped ps with another. same problem. tested ps, ok. what gives?
Try jump starting it by shorting the power switch pins on the MB with a flat head screwdriver. If it starts then check the power switch on the case for loose connection. If it fails then replace the MB.
Oct 23, 2010 | Dell OptiPlex GX270 PC Desktop
Dell Optiplex GX270 will not start and power button is orange
I think that it is most likely that this is a power supply going bad. These can be purchased cheaply on eBay (make sure the picture matches). This replacement is moderately technical.
The other good possibility is a bad capacitor(s) on the motherboard. This is very common for the GX270s due to a manufacturer defect. Most of them failed in years 2-4, though. This would require a replacement motherboard (very technical). Pictures of bad capacitors: http://brianmorristech.com/?p=105
It could also be related to the power connector from the power supply to the motherboard (unlikely).
Another good option would be to buy a used GX270 from eBay and put your hard drive into it.
Jul 13, 2009 | Dell OptiPlex GX270 PC Desktop
Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
Feb 14, 2009 | Dell OptiPlex GX270 PC Desktop
System couldnot respond after booting dell gx270
Try to check connections between the monitor and the System Unit or what they called CPU. Turn on the computer you must hear 1 beep means the computer start normally. if you haven't, try taking out any new installed hardware but not the video card if you don't have onboard video device and turn on your computer again.. if problem still exist keep in touch.. TY
HOPE I CAN HELP
Dec 04, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
Loud "jet engine taking off" type sound
If you changed out the power supply then the only other device that could be making that noise is your CPU cooling fan. To be sure, open the case and disconnect the CPU cooling fan plug from the motherbrd (MAKE SURE POWER IS OFF) and see if the noise stops. Don’t worry about the “Fan Failure Error” when you turn on the computer. Just hit F1 to continue. Don’t leave the computer running without the fan plugged in longer then necessary. After tying this procedure, please contact me for further diagnosis.
Oct 16, 2008 | Dell OptiPlex GX270 PC Desktop
Dell gx270 {switch}
My motherboard shows error thermal error and after 3 minut its power is close automatically
Apr 10, 2008 | Dell (4T274-DE) Motherboard
Dell OptiPlex GX270 PC Desktop Logo
1,056 people viewed this question
Alun Cox
