Question about Acer Aspire 5630 Notebook
Acer Aspire 5630 Brightness controls unable to be fixed...
Okay I know you use Fn to change the brightness but my brightness increase button doesn't work, is there any way to increase my brightness without using Fn and that right arrow key? (which doesn't work period..)
Thanks for any help.. :)
How do i adjust the contrast on my acer aspire 5738z laptop
Try the following:
For Windows Vista / 7
1. Press the Fn+Left Arrow Key for brightness down and Fn+Right Arrow Key for brightness up (the Fn key is located at the left side of the space bar)
2. If that won't work, go to Start > type Power Options and click on the Power options icon.
3. Adjust the screen brightness bar below.
Good luck.
Sep 07, 2011 | Acer Aspire 5630 Notebook
Dark picture on monitor
Occasionally, you may find your laptop's monitor is too dim for your liking. A normal desktop computer's monitor has an on-board menu system that lets you adjust the brightness and picture control settings as you please. A laptop monitor has no such controls. You can adjust the brightness of your laptop monitor using your laptop's keyboard.
1. Press and hold the "FN" key on your laptop's keyboard. This is the "Function" key, which operates much the same way that the "Shift" key does: It allows keyboard buttons to be used for multiple purposes. It's located in the lower left corner of most laptop keyboards, next to the "Windows," "CTRL" and "ALT" keys.
2. Look at the top row of keys on your keyboard for a key with a tiny triangle pointing upwards and the symbol of a sun on it. This is the "Increase Brightness" key. With the "FN" key held down, press the "Increase Brightness" key. On most laptop keyboards this is the "F7" key, but it varies depending on the model.
3. Continue to hold down the "FN" and "Increase Brightness" key until your dim laptop monitor has reached the level of brightness you require. A laptop monitor can only get so bright. It will stop at its highest setting.
4. Release the "FN" and "Increase Brightness" keys. You have now fixed your dim laptop monitor.
I hope you find it very helpful. Thank you for using fixya
Aug 17, 2011 | Acer Aspire 5610-2089 Notebook PC (ACER...
Screen is too dark, barely can see the print. Is there an adjustment to use? was working fine a few days ago, then, has been getting darker.
Most computers have a key combination to increase brightness. This is usually Fn+UP for brighter on Fn+DOWN for darker. If this is not the correct key combo, look for keys that have symbols looking like the sun or a light, those keys combined with Fn will change the screen brightness. This can also be changed in Windows, if that is the OS you are using. Go to Start->Control Panel->Power Options and an opiton for screen brightness will be there. Also, right clicking the battery/power cord icon in the system tray can get you to the power options.
May 08, 2011 | Acer Aspire 5630-6288 Notebook
How to increase the brightness of acer 5630
Notebooks change the brightness usually by pressing the Fn key and another key on the top row. The top row has one key for making brighter (picture of a light on it?).
Please rate Fixya answers
Apr 10, 2011 | Acer Aspire 5630 Notebook
Is there any way to brighten my screen on my acer aspire 5601 lap top
Examine the keyboard. There should be a symbol on most of the function keys (F1, F2, etc.). Look for one that looks like a sun or lightbulb, either with an arrow pointing up or with the sun/lighbulb filled in. Hold the 'Fn' key, and tap the up/bright sun/lightbulb key a few times. The screen should increase in brightness.
If you cannot find the specified keys, you may be able to adjust brightness from inside Windows. Right click on the battery icon in the taskbar and open 'power options'. Look for a sun and moon with a sliding bar between them. You might also be able to adjust brightness by customizing your desktop (right click on the desktop and look for the proper menu).
Mar 22, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
Screen is too dark,how do you increase brightness?
press the FN key + the right arrow key >
please rate me
Sep 02, 2010 | Acer Aspire 5630 Notebook
Adjust brightness
if its a laptop the problem should be from the pcb inverter at the back change the inverter for a possible improve ment
May 26, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Screen not bright enough
hit and hold the fn button and adjust the brightness with the right arrow. krakkerjack
Mar 16, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5630 screen brightness adjustment...
How do I adjust my brightness or contrast on my laptop? See our brightness definition for a visual example. Finally, most laptops only enable users to adjust their brightness of their screen.
Click on the above Link, Good Luck, Please dont for get to Vote.Thank you.
Dec 15, 2007 | Acer Aspire 5100 Notebook
You press the function (Fn) key and the left/right arrows, not the Ctrl / Alt, shift buttons
Oct 26, 2007 | Acer Aspire 5630 Notebook
Acer Aspire 5630 Notebook Logo
237 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
