Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Opening door - Aquarius 1100
The hinge of the opening door is broken and needs to be changed. Where can I find spare parts in Portugal?
Well. jacinto , get your part of ebay if you can get on the net. i got my hinge part also from ebay did it my self also. best wishes cazx.
Posted on Jul 14, 2007
    President:
  • 1,462 Answers
Do by mail order from uk
Posted on Mar 19, 2007
SOURCE:
I need a replacement door for my Hoover Easy Logic 1100 aa Washing machine. I beleive that the model is discontinued but my machine is in perfectly good working order. Could you advise anywhere where I...
I searched for quite some time without success and I am Pretty good at finding things.
Contact Hoover using this link:
http://service.hoover.co.uk/spares
To order Hoover Genuine Spares & Accessories please call 08443 712758
Opening hours: Mon-Fri 8.30am - 5pm.
I could not even come up with the part number for the door. I did find the following:
1. Door Seal
2. Door Glass
3. Door Handle
4. Door Hinges
No luck on finding the complete door assembly.
Another alternative... if the Yorkshire area has an appliance recycling venter you may be able to find one there or in the classified ads "for parts only" But then your faced with disposing of the "junk."
I recommend you contact Hoover using the number or Lonk above and see what they can do for you.
I wish I could have done more for you but the whole door assembly just does not seem to be readily available.
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Washing Machines
Tip
How do I change freezer door opening side?
Hi.
Details on how to change the fridge door opening side depend on the appliance model.If this is a chest unit, you will simply need to rotate the unit. On most upright units the general procedure to change door opening orientation is more or less the one ilustrated below:
  1. Disconnect power from the appliance.
  2. Get to the top side of the unit, and remove the hinge plate. This is usually held by two Torx or Philips screws. You may need to help yourself with a putty knife to remove a protective panel covering the plate. Be careful not to damage any part.
  3. Remove top hinge and put it on one side.
  4. After removing the plate you may need to remove the plastic clip located at the top on the handle side of the door, oppositely to the old hinge side. Use the putty knife to pry up and remove the plastic clip.
  5. Open the door and lift it from the lower hinge pivot.On many fridges you will have to remove the bottom hinge too, often held by two screws, and covered with a proective pane, to free the door before removing it
  6. Carefully place the door on the floor.
  7. Remove protective panels on top and bottom on handle side of the frige cavity, reinstall the hinges on handle side position, swapping them with the protective panels.
  8. Remove the door pivot and mount it on the opposite side.
  9. On the door disassemble and refit handle or any other part if needed.
The precise and complete procedure is usually illustrated on the appliance user manual. If you need manual or schematics, try asking a new Fixya question. Ensure that you are providing full model number, as printed on service tag.
To get more detailed info you can also try calling the appliance manufacturer at the number listed on the owners manual.
Regards.
on Mar 30, 2010 | Refrigerators
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Sep 12, 2009 | Ovens
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Door opening internal plastic hinge broken
Just saw you post as I was searching for the same item. If you have not found the part yet, it can be ordered from repairclinic.com (part #916507). $5.50 plus shipping.
Apr 18, 2009 | Sharp R-1480 Microwave Oven
Door hinge is broken on my hotpoint aquarius
Get the model number off the unit and go to sears parts on line. Good luck
Dec 30, 2008 | Hotpoint Aquarius WD63 Front Load...
Broken Hinge
Hello jonckenny,
I wasn't able to track down your specific part but by using this link and speaking with their parts rep, thsy should be able to assist you.. http://www.pcappliancerepair.com/cgi-bin/partsearch.cgi
Hope this helps.
Regards,
Rick
Dec 07, 2008 | Hotpoint Aquarius WD63 Front Load...
Dismantling door of Aquarius 1100 WM63P.
Revove all screws from inside of door then it will split with aid of flat screwdriver.
Nov 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
178 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
