Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Genie 2020L - Garage door does not close using remote/pad
We bought a brand new 1/2 HP motor for our Garage door in the summer. It worked fine for about a week and then it started to be selective when trying to close the door. Sometimes it goes down on the 1st push of a button the other it can take up to 1/2 hour even when the mounted pad is turned off...still does not work. I am so frustrated as it is just 1/2 year old.
The sensor are clear of any obstacles and the colors are red and green. It just does not work and I am ready to take my losses and go and buy a brand new motor which is not even close to the name GENIE.
Does anyone here has any hints?
You have loose wire(s). After speaking with Genie Customer Service, they had me disconect a few of the wires and try operating the unit, to no avail. I noticed when reconnecting the wires that several other wires on the same row of connections were loose. I tightened all wire connections and VOILA, it works.
1.Open plastic cover in front of the Unit.
2. Look on upper right corner for a row of screws. Model 2020L has a verticle row of (6) connection screws numbered from top to bottom, 1-6. These screws connet to a green circuit board. Looks kind of like a video card from a computer.
3. Tighten all these screws top to bottom assuring good connection of all wires.
My contention is this. As the motor runs, it causes a vibration that tends to loosen those screws causing a faulty connection to the circuit board. Hope this works for you.
Delta Dan
Posted on Nov 24, 2008
  • 373 Answers
I have a model 2020L Genie opener that has started acting
up.
First of all, the problem appears to be temperature
sensitive. The warmer (hot) it is, the
more likely it will occur. If it is cool
or cold it seems to be fine.
I finally messed around with it today.
The opener will just shut-off. Typically, it opens fine, but then it won't
close. Sometimes you have to wait a
couple minutes... sometimes longer. We
would usually walk away for 30 minutes.
This is important to seeing what kind of problem you have. When mine shuts off.... the light shuts off,
the button light shuts off, and the safety sensor LEDs shut off. The electric outlet plug has power and the
circuit board has power.
It is not the safety sensors or a loose connection or broken
wire.
It is not related to the safety circuit sensors or wires.
I am still looking for a solution, but thought I'd drop a
note here.
Posted on Jun 30, 2013
I cannot program my receiver Genie ACSR3 to work with a remote Genie GITR-3
check age difference, every so often the codes change and older parts will not work with newer parts
Nov 03, 2014 | Building Materials
Genie 900 door operator
hello,there is an adjuster on the side of the motor,also check that the micro switch[if fitted on your particular type} is 'clicking' and actually in contact with the arm as it revolves closed. hope that helps, cheers
Jun 02, 2014 | Genie PowerLift 900 1/2 HP Screw Drive...
I just installed a new Genie Silentmax 1000. The wall switch works. The up and down settings are right. The safety doors sensors are working. My problem now is that I can't get the remotes or the key...
On the back of the garage door opener there will be a button that you will push it will start flashing right then you will push the garage door opener button and do the same freaking packed push the button wait for the blinking light enter your code and pushed enter
Feb 16, 2014 | Genie Garage Door. SilentMax 1000 3/4 HP...
Garage Door Remote
Did you happen to put a new light bulb in it? I put an LED bulb in mine and the interference caused the remotes to stop working. I had a bear figuring it out, because it seemed to be totally random. Sometimes they would work and sometimes they wouldn't. Once I switched back to an incandescent, it worked fine.
Jan 17, 2014 | Genie Wayne Dalton 36560U 1/2 Hp Dc Belt...
Hi, I have an older garage door opener, Genie
If the opener doesn't work with the button on the wall the opener is defective, either the receiver board or the motor drive circuit or the motor itself.
May 03, 2017 | Transmitter Solutions Building Materials
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
I recently bought a house which has a craftsman 1/2 HP garage door opener. The garage door opener works fine using the wall mounted pad and also the numeric key pad, but not with the remote that came with...
If you didn't, try programming the remote this way.
Press and hold the button on the remote and then press and immediately release the smart/learn button on the motor unit. If this doesn't work you need to make sure you have the correct remote for the model opener you have. Your model number doesn't bring any results from Sears Parts.com.
Nov 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Genie Compact 3-Button Remote control will only open 1 door/not 2
On some of the remotes you will find a toggle switch to change frequencies, this might help. Note all new openers are operating on a different frequency than slightly older ones due to military interference. Even though both might be intellicode they might not work together on the same remote. Sometimes some openers are harder to program than others. So lets try to program the harder one. You need to find and press the learn button on the motor head. Then press the button on the remote once. The led light by the learn button should not flash. If so try it over. The light should either stay lit or go out after the first press. If it does press it again and then a third time. If it ever flashes during the program process try again. The third or fourth time the motor should operate. If not you either have a bad remote or more than likely a bed logic board. Thanks BB
May 15, 2010 | Genie Company IntelliCode GICT390-1BL...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,933 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
