Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
My simpltech will not let me back up
I have had my Simpletech for almost a year and its been working fine but the other day it stopped letting me back up and my mac time machine wont reconize it either. It keeps popping up a window saying needs repair and that i need to back it up soon because its giving min. function. I can get to all the info i have backed up but cant back up anymore. I still have 71 gigs still left on it so that quit a lot still left for back up... Help Please... with the economy the way it is i cant aford to another one and i cant aford to lose the stuff on it... Thanks Roc
    Novelist:
    Scholar:
  • 158 Answers
The Only solution is to buy a big external hard drive prefurably not the one you have currently have go for the maxtor range as they are better quality in service for external devices and mak sure they are Sata drives which have better durabilaty and speed over Eide device hard drives and alot quieter and self power down when not in use and don't over heat as much with the other drives go for the cheapest one that has both usb 1.1/2.0 capabilaties this will make sure you have the correct speed for data transfer.
Posted on Nov 23, 2008
My fabrik simpltech 500g hd doesnt work on anything but my macbook, is it locked?
If it's formated under MAC OS, windows will never see partitions on your hdd.
Dec 25, 2011 | SimpleTech 500GB SimpleDrive Pro External...
SimpleTech 500 GB external hard blinking red light
I got one with the same problem. I opened up the case and hooked up the hard drive to a generic usb to sata adapter that i picked up on ebay and it works fine now if a bit clunky looking.
Sep 10, 2009 | SimpleTech 500GB SimpleDrive Pro External...
I have my simple tech set to back up personal docs every day. This works fine. However, when I attempt to back up the entire HD to SimpleTech, it begins ok then stops before completed. One time it stopped...
Double check all the power options on your PC to make sure it is not set to go to sleep or hibernate or any other process that may interrupt the backup itself.
Also make sure there is enough space to back up to.
Make sure that the interface you use to connect also has any power saving turned off.
Many devices have the option of going to sleep or turning off to save power and you would need to check the full properties of your usb or firewire card to check that.
Make sure your antivirus or any other application is not set to scan or run during the same time interval as your backup
when you have checked all that you may find that it now works as it should.
http://www.ehow.com/how_5097708_turn-off-power-saving.html has some useful info as does
http://www.howtogeek.com/howto/windows-vista/disable-power-management-on-windows-vista/
If this information was useful please click
Aug 14, 2009 | SimpleTech 160GB USB 2.0 / FireWire...
Simpletech External Drive now failing to connect with USB 2.0
Hello sir, let me give you some tips, you can dismantle it and get the HDD unit, buy a cheap external SATA usb hdd enclosure with USB 2.0 . Well all of them are 2.0 compatible (the unit without the HDD) and put it there. you can always keep the old one for posterity. hope this helps.
Aug 06, 2009 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Mount problem for external simpletech 100GB harddrive
Typically points to a hard drive failure. These normally happen without much warning. Have you contacted the manufacturer tech support?
Feb 23, 2018 | SimpleTech 100GB SimpleDrive portable USB...
SimpleTech external HD won't turn on
Get a new AC adapter for it. I had the same problem, & I had an AC adapter that was the same type for the modem & I tried that one & it was working again.
Feb 28, 2009 | SimpleTech 160GB USB 2.0 / FireWire...
Have a 160 GB ext. Hard drive - no longer made. Bought it over a year ago but never plugged it in until two day ago. The red light comes on but it does not show up under"My Computer" Took it to Best Buy...
Although I have seen it fail often, in your case it is worthwhile to try the 'Add hardware' wizard in the Control Panel. If you have an installation disk of any kind, have it at hand. Let the system look for the drive (plugged in of course) and if it finds it and has no drivers for it, it will ask for the installation disk but you may have to tell Win where to look for it by drive letter. If you don't have an installation disk, you will have to go through the drivers list offered to see if SimpleTech is listed.
SimpleTech still has an active website so I would check there first:
SimpleTech support page
If you have no luck you find no driver, there are several websites that have a huge array of drivers for current and obsolete hardware.
Good luck-
Feb 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Can't write onto HDD
This seems like a driver confliction. i suggest you re install the driver sets that came with this unit. it should be a disk that came with the HDD. Use this disk and reinstall all software. this should fix this issue. I would also defrag the main on board hard drive as well. Sometimes, this simple tool will fix this issue as well.
Feb 19, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Dropped external harddrive
If the drive isn't working anymore just RMA (Return to Manufacturer) it. Most hard drives have a pretty decent warranty on them. Your simpletech 250GB has a 3 year warranty on it. Info on the warranty can be found at http://www.simpletech.com/support/warranty/. If you want to RMA it, click the "Technical Support / RMA Request" on the left hand side of that page.
Apr 18, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 500 GB drive won't work (repost because not solved)
I had a similar problem with a SimpleTech 250g Pininfarina USB drive.
I went through the drivers, the power supply, the USB cables, and the various
computers, USB cards and Operating systems.
Finally I opened the case and found the disk drive was mounted too far
forward, causing the IDE connector to barely touch. I loosened the mount screws,
slid the drive back towards the connector, tightened everything down and it works.
Dec 09, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
42 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Ricky Ostrom
Ricky Ostrom
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
