Question about Kenmore Oasis HE 27082 Top Load Washer
OL on Oasis Washer
I get oL reading in my washer, but its not over loaded!
  • 1 more comment
  • tanya_dance Nov 22, 2008
    Is there a website to learn how to take apart the nutator? We found a pair of PJ's trapped in it, I wonder if anything else is in there! Thank SO much!!!
  • tanya_dance Nov 24, 2008
    I need to find out how to take off the nutator (agitator) on the Oasis Top Loader, I have a feeling something is stuck in there. Thanks So much
  • jetsonx Nov 27, 2008
    i get ol........checked under nurator.......nothing there
My oasis he canyon capacity washer was displaying a ol error code i looked on this sight and noticed someone had clothes stuck under thiers. Mine had same problem and the way i removed the nutator was to first pop off the cap which covered the bolt assembly holding the cone (nutator in place then i tried to pull it up but it didnt move i. iI had someone hold the drum and wiggled it back and forth. i still could not pull it off i used needle nose vise grips and on the lip where the bolt was removed i clamped it on and pulled straight up and it came off fine. No there was not any marring of the surface either if a person wanted to they could use cloth between the vise grips and the lip area.
hope this aids someone.
Posted on Dec 08, 2008
  • 370 Answers
Does your washer have an agitator or a nutator.(nutator is the little cone on the bottom) They have had problems with the nutator tightening and causing extra drag on the motor. The Oasis is a very complicated machine. It is either that or the control board. You can replace the control board yourself and see if that fixes it to save the hefty service technician charge. If the control board doesnt fix it then you have to call a technician. if you need any further help let me know.
Posted on Nov 21, 2008
  • Justin Duby
    Justin Duby Nov 22, 2008
    If you go to sears.com and put in your model number in the parts section you can get a diagram of your machine. (exploided view)
OL code and fixing it?
The machine may have a defective overload sensor.
Jul 21, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
Getting oL code even after diagnostic check
OL, usually means Over Loaded. It is an error code thrown up by the on board computericon1.png.. generally when TOO much wet weight is in the bowl.
This condition is could be caused by faulty solenoid or solenoids at the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity will indicate a faulty solenoid and the inlet valve assy will need to be replaced.
Try unplugging for 12 hrs before reconnecting
If the problem continues then the controller board is damaged and will need to be replaced.
Jan 13, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Screen say OL on my Kenmore Catalyst Elite. What does oL mean?
OL error means the Motor Controller has sensed an Overload.
The oL code means the motor control board is struggling to power the motor up. If it recurs after removing some clothes - usually this means a new motor control.... or worse - a new bearing.
If it were a problem with the tub floating up, the unit would spin instead of nutate.
Bearing failure in this machine is very common.
I suspect the drive shaft and bearing are the problem. The bearing and shaft are part of the outer tub.
Feb 28, 2013 | Kenmore Oasis HE 27082 Top Load Washer
Not agitating and showing ol even if empty
Something is between tubs triggering th OL. Remove the agitation device and lift out the inner basket to get to the item between tubs and rock on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 03, 2011 | Kenmore Oasis HE 27082 Top Load Washer
Ol error on oassi elite washer
my washer told ol code ,i know that means over load ,put its told me that even when i put small load
Mar 01, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
What does oL mean when the load is over? We just moved into a place with the washer and the clothes are soaking wet after the load is over? It's the kenmore elite.
Hi
Thanks for using FixYa. oL flashes when the machine/motor control detects a load size that exceeds the washer’s capacity. Open the door lids to clear display, remove excess laundry, then restart the cycle. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 05, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore washer OASIS errror code OL
The new outer tub with bearing W10128830 cost approximately $197 dollars.
If you can get access to the shaft it may be an Emory cloth will help smooth things down so that you no longer get the OL code.
This is an ambitious do-it-yourself project... as most appliance repairmen don't understand how this machine operates.
http://media.fotki.com/1_p,srrtbrrfbdbqgkkxgtqsskgwtqkq,vi/bqkfstqqfxrqqbkwgqdxbwsqrwrtq/1/1303472/5961857/image828956817962821589img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 22, 2010 | Kenmore 22422 Top Load Washer
Screen says oL. Kenmore oasis elite he 110.2708,2709
OL, usually means Over Loaded. It is an error code thrown up by the on board computer.. generally when TOO much wet weight is in the bowl.
Jan 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Washer is skiping rinse and don't spin has code ol
be sure that both water sources are connected and turned on.
Sep 14, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I GOT ERROR CODES F32(LD),F70(OL).HOW I CAN FIX IT?
Kenmore Elite Top load washer machine. Error "OL" does not spin fast enough. Clothes are still very wet. I have checked the machine is sitting on even surface and well balanced from all sides. Any idea(s) ???
Jun 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
174 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
