Lexmark 2500, downloaded from disc as directed...all cables connected, printer is powered on, printer in turned to on-line in control panel, have rebooted 8 times, computer recognizes new hardware(printer) but for the life of me i can not get anything to print, the alignment page did print, so printer does work. when i go to print the window pops up computer can not communicate with printer
  • 162 Answers
Change usb cable / usb port Do a windows test page from the printer properties window
Posted on Nov 21, 2008
The compuer is not connected
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/hsBChY. Select your operating system, download and execute the file.
Feb 10, 2012 | Lexmark X5495 All-in-One &USB...
What should I do with my Lexmark printer x3430? It will not print an entire article. It will print only one page.
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/AbnM39. Select your operating system, download and execute the file. After the install process, try to print again.
Feb 08, 2012 | Lexmark X Office Equipment & Supplies
My printer want scan to pc
printer wont scan to pc - Lexmark X5650 ALL-IN-ONE PRINTER
Dec 05, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
Do i need software like ocr so that the lexmark x6650 scanner can work
If you are scanning documents for editing or saving them as PDF, you will need to install the OCR scan software. The Lexmark OCR scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center to request for one.
If your scanner was working before, it could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
  4. Reboot computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to scan a document again to verify that the problem is fixed.
Nov 02, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Lexmark x5070 says cannot download application list when I try scanning something.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer > reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
  4. Reboot computer.
Sep 17, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
The buttons on the control panel of my Lexmark 2500 are not working. The printer is connected and I can scan from my computer, but I cannot print. I changed the ink cartridges, but as the lights on the...
Please go through the following checklist:
  • Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
  • Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
  • Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
  • If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
  • Make sure the correct power supply is connected to the printer.
Source: The Printer is Not Powering On
Jul 28, 2011 | Lexmark X2500 All-In-One Printer
My son gave me a lexmark X1185, but I do not have the disc to download it. How do I get the printer installed and what do I have to do to get it showing under Control Panel, Printers?
Hello, if you can paste the (very long-2 lines) link below into your web browser you'll get to the Lexmark website page for your printer. Select from the drop-down menu your operating system (you'll see it's already set to 32-bit Windows XP-but that might not be your operating system) and download it onto your desktop or 'downloads' directory. Once there, double-click the filename and it will install. Best NOT to have your printer connected at this stage-wait till the driver has finished installing THEN plug in the printer to your usb connector and turn on its power. Your computer should then 'discover' the printer.
Regards,
Nicam49
the address is below:-
http://support.lexmark.com/index?locale=en&productCode=LEXMARK_X1185&userlocale=EN_US+&segment=DOWNLOAD&os=WINDOWS_XP&page=downloadsList&oslocale=en_US#1
Oct 16, 2010 | Lexmark Office Equipment & Supplies
Lost setup disc for Lexmark 2500
you can download the drivers from the manufacture website
May 19, 2008 | Lexmark X2500 All-In-One Printer
66 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
