Back to:
Tags:
LG 42PX3DCV 42 in. EDTV Plasma Television
STATIC CHARGE (by 5 users)
posted by FUZZIEST on Dec 19, 2006
just boughthis tv 10/15...has been working fine until last week....
My daughter caused the breaker to flip and my powerbar was located on this portion of the panel.
Ever since this happened there has been a small static charge that slowly builds and creates "static lines" across the display...The only way to make them disappear(for about an hour or so) is to turn off all my hardware and reset the power bar.
After I do this everything is a-ok on the display and then it re-appears
Can anyone help?!?!?!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by kjwilkes, posted on Aug 12, 2008
I have had my Insignia for about a year and I am seeing "static" in the lower left jand corner of the screen. It doesn't always show, but when it does, it is distracting. It can be as small as a square inch or as large as a quarter of the visable area. Any ideas on what is causing it and how to fix it?
Comment by Guest, posted on Apr 08, 2008
i have static in my television
Comment by creeper1958, posted on Nov 26, 2007
my tv is a 60vg825 after changing the bulb it worker fine for a while but now it keeps turning off what could be the problem?
Comment by jlynn432, posted on Nov 15, 2007
Hi, I have the same problem. I've tried different outlets, but it still happens. It's really frustrating!
Best Solution
posted on Aug 20, 2007
FixYa! (100)
mikeandtab
Rank:Master Master
Rating: 80%, 13 votes
I'VE SEEN THIS IN THE PAST AND IT WAS ANOTHER ITEM PLUGGED IN TO THE SAME OUTLET WITH A SHORT, AND OFTEN TIMES IT'S AS SIMPLE AS A FLOURESCENT LIGHT.THE PROCESS OF ELEIMINATION WILL HELP YOU.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on STATIC CHARGE:
I don't want to Accept this solution
Solution #2
posted on Dec 20, 2006
FixYa! (100)
henlopen
Rank:Wiz Wiz
Rating: 84%, 610 votes
First thing I'd check is the powerbar. Did you plug the TV into the outlet direct? What caused the breaker to trip? If it was an overload by using too much current, there is a possibility that there is a loose connection in your house wiring causing arcing and the interiference lines you're seeing on the display. You may even want to try the set in a different outlet if the powerbar checks ok, and if the set then works fine, get an electrican ASAP!
Thank You!
Solution #3
posted on Jul 19, 2008
Not Rated (0)
lfostano
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
Plug your TV in a reliable surge suppressor or UPS , common problems arise from power losses and low voltage as well as spikes.These will really mess with you electronics.
Thank You!
Solution #4
posted on Feb 22, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
I had same problem 5 years ago.after the receiver from my tv company (direct TV) got broken , I change it with a newer model and the TV start working perfect. now my TV is gone (screen stop working).
Thank You!
Solution #5
posted on Dec 22, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
i can get dvd to work fine the picture looks like its atimated. What can I do?
Thank You!
Solution #6
posted on Aug 10, 2007
Not Rated (0)
Guest
Rating: 0%, 0 votes
Get a very good surge protector. Make sure it has close to or over 3000 joules and you should be fine.
Thank You!
Solution #7
posted on Aug 08, 2007
Not Rated (0)
CanDo
Rank:Wiz Wiz
Rating: 77%, 118 votes
With todays electronics and small amps and voltage the slght's jumps and surges can easiely knock out our equipment . It happens all around me all the time. Lightning, power surges, transformers, power plants and more are constantly effecting our equipment. We need the best surge protectors today to help us stay safe. It sounds like you have been a victum of a surge.
Thank You!
Can you Help with these Flat Panel Televisions problems?
how can i solve my plasma t.v which THE SCREEN IS FINE,BUT...
I have just lost sound on tv but still have picture Is...
After a few mins ou tv will power down then shut off,like...
My husband was changing an outlet that had an old metal...
On my LG plasma i see picture is splitted horizontally....
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
