Samsung BN59-00599A Remote Control Logo
carl doherty Posted on May 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung remote BN59-01039A stopped working - Samsung BN59-00599A Remote Control
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on May 10, 2012
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986810
Points
237762
Check the batteres first. Replace them with new ones. If it also do not help you, your remote control need service. [cleaning].
Visit this site [Electro-help], to get more details about how a remote control can be checked and repaired. Search for it either by Yahoo 0r Google. Pull up older posts there, which will guide you.
Samsung LE32C450E1W TV remote control stopped working, changed batteries no luck, turned off at power source for 30 min which fixed prob temp but has happened again and now turn off doesn't help....
Check the remote control for its infrared emission. Check it with fresh batteries. Clean the battery contacts inside its battery compartment. If these do not help you, you remote control need cleaning. If you wish to know more about how to clean and repair a remote control check this site. Pull up older posts. One among it has details.
Samsung ht-c453 remote stopped working
kindly check the battery of your remote control...
1helpful
My samsung tv (21SB1RG) just stop working with its remote.but the remote is good,what can i do to make it work ?
just check infrared transmission is ok with infra reciver if recieve wawes from your remote the you system have some problem otherwise change ir led and try
2helpful
Goog day. I have a Samsung LE40A559 LCD TV and about a week ago it stopped responding to the remote. Remote itself is working as when the TV is off and I push buttons on the remote the blue light on TV...
The flashing blue light shows that the TV is receiving I.R. from the remote but doesn't mean that the signal being received is recognized by the Samsung. If you have a "universal" remote then your TV code may need to be re-entered/reprogrammed...changing batteries in a "universal" will usually require it to be reprogrammed.
Also...because of the remotes construction (rubber membranes with carbon dots that short across PC traces) I've seen certain buttons stop working altogether.
Samsung remote control - UE40B8000XWXXU
This is odd.. I have a UN model, the 6000 actually and all remotes have stopped having any effect on the Television, even the units original remote. I can access every other device except the TV, it's as if the RF sensor on the TV has failed to function anymore. Let me know if you found a solution to this problem!
2answers
Remote stops working does not respond all the time
change the battery that should be the problem if the problem still persists then its hardware problem got to get a new remote.
1helpful
2answers
Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
2helpful
4answers
My sky remote has stopped working on my samsung tv
Easy peezy...just press TV on your sky remote,now hold select and the red button until it blinks twice,after it blinks twice enter this code ...1430....it sjould blink twice again,now press standby,it should turn your tv of,if it does press select to save these settings,it should now control your volume too,let me know if this helps
Remote stopped working after color wheel replaced
See http://www.consumermeet.com/entry/samsung-remote-wire.html , that seems to address the same problem.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
