Question about NorStar Meridian M7310 Phone
M7310 Nortel/Meridian phone system call transferring
I am trying to get call transfer disconnect to work with the model M7310 phones. These phones do not have the flash/recall button and have been told it will not work then.  I want to be able to transfer incoming calls to an outside line on the fly, only when I want to send them not preprogrammed times.  I am curious if I can replace the phones with a different model phone from Nortel that has the recall/flash button? I havent seen one that is available, the processor is a 6x16 unit. I noticed these phones use a standard rj-45 connector and if I swap the whole system(processor and all) I dont want to have to string Cat5e with the ethernet connectors.
Any insight?
ThanksJake
  • 1 more comment
  • dubnation Nov 21, 2008
    I have searched for a different nortel phone, I am unable to find a Nortel phone that has flash/recall. Is there a workaround for not having the flash/recall or a Nortel phone someone knows of that I am not seeing? I would like to not replace the whole system, but if I have to, does anyone know of a phone system that has the flash/recall that uses an rj-45 wire setup as opposed to the ethernet connectors like used on the merlin systems. I dont want to have to string new wire through the building.
    Thanks
    Jake
    We had the call transfer disconnect service added to the lines and it still doesnt work. On the M7310 there is a call forward button, by going through the sequence you can get a 3 way call going, but when I hang up to allow the initial caller who dialed me and the caller who I dialed remain on the line together it hangs up on both of them. The scenario is when someone calls for tech support to one of the locations in California I want them to be able to transfer those calls up to the Oregon location.
    Jake
    The Link feature command of 71 worked. Thanks SOOO much! We used feature 71 instead of the call transfer button and it worked.
    Sergeant:
    Champion:
  • 283 Answers
Click this http://www.google.com/products?q=meridian+m3820. Hope this could help. Please dont rate me if not satisfied. Thank you
Posted on Nov 21, 2008
    Genius:
  • 1,913 Answers
Purchase new phone only good solution.
  • NorStar Master
  • 2,460 Answers
Actually they do, you just have to learn a couple of new terms.
If you have a manual, look up RECALL or FLASH or LINK. Specifically Feature 70 and FEAT 71. In your spare button set, you probaly have gray buttons labeled CONF/TRANS and LINK. Now you use them depends on how you are transferring calls. Are you on Centrex or do you have 3 way Conference calling from the telco? That's the one where you can establish a 3 way call and hang up and the other two parties stay connected. If you have that, you'll use the LINK button to get second dial tone, dial your number, and press LINK again to establish a 3-way. LINK time is defaulted at 600 mS, and is adjusted in A 4. Misc programming under LINK.
If you don't and want to use the system to conference (using two lines), you'll use the CONF/TRANS button. There may be some disconnect supervision (ie DS cabinet) issues, Supervised/Unsupervised programmnig changes, and transmission losses in conferencing, so your mileage may vary. Best would be maybe to conference with a VoIP trunk or other lossless facility. Anyway, you put the first call on hold, make the second call, then press CONF and the held line to establish a 3-way. At this point, if you have Disconnect Supervision, you can press conference again and leave the call, or put the call on HOLD to keep it on your phone and the other 2 parties can still talk to each other.
I hope this helps. You probably know how to program buttons (FEAT *3) and that procedure will be in your manual. The sytsem programming is in the basic 616 DRx manual and the whole thing is about 300 pages. If you don't have one, you should be able to find the one place that has a free manual (hint Nortel 616 DR5 Installation Guide).
Carl
  • Carl Navarro
    Carl Navarro Nov 21, 2008
    You can keep it simple by programming the button to do it. FEAT *3 press the button FEAT 71.
    Then find that "lost" LINK button :-)
    Thanks for the rating.
    Carl
  • 4,806 Answers
If the phones software dosen't support call transfer, all you have to do is set up the process using your telephone service provider.
Give them a call i'm sure they can help you
regards
  • 685 Answers
Http://www.nortel.com/ here you should find everything your looking for
  • Juanita Vega
    Juanita Vega Nov 21, 2008
    you can also try panasonic that is what i use and they have a varity of phones
  • Juanita Vega
    http://www.panasonic.com/
Nortel m7310 cant use touch tone
Try Feature 808 before pressing the touchtone digit - it tells the Norstar to send Long Tones to the remote system.
Jul 22, 2013 | Nortel Meridian M7310 Business Phone...
My M7310 won't forward a call to the next open line but gives a busy signal
Hard to answer because your problem description does not match the part.
Nortel Meridian M7208 Corded Phone is a digital phone which works off a phone system.Also note that the carrier controls the rollover, not the phone or its system.
Once you have more/proper details maybe you can be helped.
Dec 14, 2012 | Nortel Meridian M7208 Corded Phone
All of a sudden the line lights on our nortel switch Meridian M7310 phones started blinking and the lines are dead. Any ideas?
If you only have one line,why not just lose the Nortel system? You can reuse the wiring from the phone sets to the contoller as regular inside wire,and just plug in regular phones(and maybe put the Nortel phones and controller on EBay and make a few bucks off it!)
Oct 26, 2012 | NorStar Meridian M7310 Phone
F 981
If none of your voicemail feature codes(f980-f989) are active, then that means that the system doesn't recognize any nortel voicemail on the system.Which means that a) your system has a non-nortel voicemail system attached to it, b) theres no voicemail attached to the system at all or c) the voicemail is no longer functioning.
Jun 23, 2010 | NorStar Meridian M7310 Phone
We have a Norstar - Meridian M7310 phone system. Today for some unknown reason when an incoming call comes in, the ring is two short rings rather that the "longer" ring that we normally have. I have...
The two short rings is telling you that the call is either a transfered call (answered by someone else and transfered) or answered by an auto attendant and transfered. Watch the ringing phone when the call comes in and see if the intercom LED blinks.
Bill C. www.dyna-tech.us
Mar 12, 2010 | NorStar M7310 Corded Phone
Our voicemail transfer button will not work for oneparticular phone.
More than likely although the button is marked as a transfer its not programmed as a transfer button. To see how its programmed press feature *0 (button inquiry) and press the button marked transfer. To re-program the button press feature *3, press the button marked transfer,and press feature 70. that willchange the program on that button.
Oct 13, 2009 | NorStar Meridian M7310 Phone
Unable to transfer calls to a certain internal extension using a M7310 Nortel Corded phone
The do not disturb might be active on the extension that your trying to transfer to.On the extension that your trying to transfer to, enter feature #85 to cancel out do not disturb.
Sep 28, 2009 | Nortel Meridian M7208 Corded Phone
Cordless phone
Just about any one will do IF you get an Analog Terminal Adaptor made for your system. The ATA requires programming in your system, so it's probably best to call a Nortel service tech.
Before some smart sould points out that Nortel has a digital cordless, remember that the "T" phone doesn't work on a Compact 308 box. Besides, an ATA and a $50 cordless is WAY less expensive.
Carl
Jun 27, 2009 | NorStar Meridian M7310 Phone
Nortel M7310 Display Caller
In system programming your station needs to set caller id to Y.
i am assuming the system accept caller id. Other stations are working.
Jun 22, 2009 | NorStar Meridian M7310 Phone
Norstar Meridian T7316E
Search the web for a manual on how to use your phone.
If you are getting calls, then the lines are programmed in the system. There is no way to disable the transfer or hold buttons.
Oct 21, 2008 | NorStar Meridian M7310 Phone
NorStar Meridian M7310 Phone Logo
601 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
