Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
PICTURE AND SOUND KEEP GOING OUT AND COME BACK FOR 30 SECONDS
TV TURNS ON PIC AND SOUND FINE THEN PIC AND SOUND ON FOR 30 SEC AND OFF FOR 30 JUST KEEPS GOING BACK AND FORTH. TRIED USING DRY AIR TO REMOVE DUST FROM INSIDE TV, BUT DID NOTHING.
    Genius:
  • Sony Master
  • 1,689 Answers
One of the power supply areas are most likely going intermittent. This can be from cold solder connections on the circuit boards, or from some components failing due to age.
An experienced tech should be able to service your set, but it will be expensive for the time involved. Sometimes these types of faults can be very time consuming to resolve.
Jerry G.
Posted on Nov 25, 2008
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
Picture and sound come and go on antenna or dvd
Try another lamp. Error 5 is Lamp power supply, but its usually always the lamp bad.
Mar 27, 2014 | Sony Grand WEGA KF60WE610 60" Rear...
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
Oct 02, 2010 | Sony KP-51WS500 51" Rear Projection...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sound but no pic on wii, but just on guitar heroes
take the cords out of the back of the wii for 30 sec.
Sep 21, 2009 | Nintendo Wii Console
T V blinks to black every few seconds otherwise works fine
Sony put i pic killer circut in there tvs. if the tube was not
giving the proper feed voltage on the guns in
the pic tube it blinks off ,sound good no pic.
if you turn up the brightness
on the flyback transfromer you can
get a little more life out of it ,
Jun 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SOUND AND PIC GOES OUT FOR 30 SECONDS, THEN PIC COMES BACK THEN SOUND. IS THIS THE LAMP OR THERMAL FUSE OR WHAT.
The lamp is going bad. If it was the thermal fuse it would not be intermittent. It is very common for some Sony sets like yours to do exactly what you describe when the lamp is going bad.
May 17, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
We keep losing sound and picture on our TV
If you haven't replaced the lamp, it is almost certainly time to change it. A weak lamp will cause the TV to play for a short time. As the old weak lamp heats up, it draws more current, and the reflector in the lamp, having become cloudy over time, converts the light into more heat rather than reflected it out into the set. Eventually the lamp draws too much current and the set turns it off, going into a restart cycle. Buy an original Sony lamp, as the aftermarket replacement lamps are known trouble makers. Be sure to rate this solution. Thanks!
Nov 13, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
No pic and shuts off
If the housing of the door comes open you will lose the sound and picture almost instantly. Have you replaced your lamp in this tv it sounds like the life on your lamp is coming to an end.
Oct 15, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Flashing lights no pic but has soung
I'm sure you've found out by now that the bulb was going bad...
Jul 28, 2007 | RCA HD50LPW175 50" HDTV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
94 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
