Question about PC Chips (M925G) Motherboard
M925 v7.3...Bios problem...ethernet option no available
Well as i said in bios there is an option no enable audio...modem...and where must be an option to enable ethernet isn´t there...i download latest bios and flash the board and the same...can it be a bug in the release?? or what can it be?? thanx
  • 624 Answers
For the M925G I can find a V8.0 and v9.1b motherboard on the PC Chips web site but not a v7.3. At any rate this manual clearly shows there should be an option to enable or disable the Ethernet port on the BIOS Features Setup Page near the bottom. If the option is not there and I would be more inclined to think that the wrong firmware may have been flashed to your board. You might try downloading and flashing the BIOS update again, making sure the checksums match when the procedure is complete. By the way the link to the manual I?m referring to is here: http://www.pcchips.com.tw/PCCWeb/Products/ProductsDetail.aspx?MenuID=0&LanID=2&DetailID=255&DetailName=Manual.
Posted on Jan 02, 2007
M925 v7.3 motherboard not booting from cd rom
Hello download the manual here:
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=231&CategoryID=1&DetailName=Manual&MenuID=45&LanID=0
You willl need adobe reader to read content.
Enter the bios (press the delete button under post) and select the boot option for the drive.
The bios must be set to boot from cd/dvd first.
Read the manual how to do this.
And second the harddrive.
Remember to save your work when done.
Good luck
Nov 26, 2012 | Pcchips P4 Motherboard PC CHIPS M925 V7.3...
I have installed the ethernet controler driver but its not working
If it's pic card installed on motherboard then reconnect it into it's slot.Then uninstall driver from device manager and control panel->add remove programs then reinstall driver then check.Also check in bios that ehterrnet lan is enabled on bios.When you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then go to advanced and enable ethernet lan option then save settings and exit from bios.Let me know if you need further assistance.Thanks for using FixYa.
Nov 22, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
I'm looking for Bios update and drivers for a board that is hard to find. Its a ECS M925 1.0 board. chipset: via p4m266 (vt8751). southbirdge: via VT8235. Bios: American Megatrends Inc. v.0700T date...
Hi Jenkins21448,
I believe your mean PCChips M925. ECS didn't make a M925 board.
So you can find the PCChips bios and drivers HERE. If you download the manual there is a drawing of the motherboard for you to compare, to make sure you have the right drivers. But, you may be right that that board you have is extremely rare. I've never seen or heard of ECS making a M925. Check out the picture to be sure.
Thanks
Mark
Mar 04, 2010 | Computers & Internet
Upgrade PCChips M925
According to PCChips, the maximum CPU & memory supported for all three is the Intel P4 Northwood (HT) 3.06 GHz 512K,533FSB,Socket 478 and 2GB (2 x 1GB) DDR 266.
Be sure you have the latest BIOS version for your motherbaord.
M925ALU (V7.3) must have BIOS : 030703s
M925G (V8.0) and M925G (V9.1b) must have BIOS : 050510s
Hope this helps you out.
Jan 09, 2010 | PC Chips (M925G) Motherboard
My device manger says that the realtec RTL8168C is working properly. However, when I plug and ethernet wire into it, it does not light up, nor does the modem. I have replaced the modem and cables. I have...
You need to go into the BIOS and see if the LAN port had been disabled.
To do this restart your computer and hit the Del key, that will get you into the BIOS, look for On-board Devices and check that the LAN is enabled.
Good luck.
Aug 18, 2009 | EliteGroup ECS A780GM-A Motherboard - AMD...
Sound card drivers on bord need AMIBIOS Motherboard Manufacturer Identification Version 1.4 (01/12/2004) Copyright 2003 American Megatrends, Inc. This file has recorded information useful in identifying...
look et...According to the numbers you provided you have Elitegroup Computer motherboard. So for any possible BIOS upgrade, drivers or any other technical support you will need to visit => www.ecsusa.com. or call them at 510-226-7333. Suc6 Theo.nl
Jan 07, 2009 | Computers & Internet
Toshiba Satellite 3000
Try going into bios utility and check to see if there is a HDD enable option. If not, find another pc and burn a bootable bios disc with the original bios.
Jun 11, 2008 | Toshiba Satellite 3000-S353 Notebook
Speedstream 4100 modem
can be a deffective modem.. they Bell.ca had replaced mine only 5 times..
Dec 29, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
VGA doesn't work on my EMachines W2040
Take new vga graphic card which can be use in agp slot and upgrade ur system with it. ok bye bye
Sep 25, 2007 | E-Machines eMachines Desktop PC
My Mdoem's ethernet and usb lights are off
assuming you using ethernet to connect the pc to the modem: how about checking your ethernetLAN card on the pc if it's integrated with the motherboard you can enable it from the bios settings if it's an expansion card it sounds like you need the most up to date driver which can be downloaded from the card manufacturer's website if you have access to internet on another pc. assuming your pc is connected to the modem via usb: reinstall the driver for the modem . another thing you can do is buy a usb to ethernet adapter which are available for under $5 on the market one end connects to the usb port on your pc and the other end is ethernet and this should work .
Aug 10, 2007 | NetGear DM602 ADSL-Modem
PC Chips (M925G) Motherboard Logo
846 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
