Question about Whirlpool Duet GHW9150P Front Load Washer
Adds strait HOT water to a cold cycle.
I know it is supposed to raise the water temp. to help the detergent work better, but I don't want strait hot water on my dark or delicate clothes. It really malfunctions at times and the whole wash is steaming! I've tried shutting off the hot water to the washer, then I get NO water. The only solution is to shut it off and start over again but if Im not right there it happens again, too late! My question is: can the sensor for the water temp malfunction? and if so can it be checked? The repairman has been here, but of course it doesnt do it while hes here. I have an extended warranty{my washer is 5 years old} please let me know. thanks.
    Genius:
  • 1,028 Answers
Possible bad cold water valve have had problems with coil connections internally breaking down..on cold setting do you get cold water ? if not valve definitely problem be sure and ck connections and make sure hoses are not reversed also ck screen inside valve at hose connection for trash or sand
Posted on Nov 21, 2008
Cold water setting not working-only hot comes out
The cold cycle begins with hot water to dissolve powder detergent regardless of whether you are using powder or liquid.
Jul 27, 2016 | Whirlpool Washing Machines
Tip
Dishwasher Water Temperatures
No matter what detergent you use, the "pills", powder, or gels, they are meant to activate PROPERLY, key word PROPERLY, at a minimum of 120 degrees Fahrenheit in a dishwasher. I recommend ALWAYS using the "high temp wash, boost, etc" on ANY cycle in order to keep the water HOT! Always run the hot water in the sink prior to starting the dishwasher! The unit is tied in to the hot water line under the kitchen sink and requires very little water to fill--by the time the hot water finally reaches the dishwasher, chances are it'll be running on cold or tepid water--the detergent won't dissolve or activate the way it's supposed to. Not only that, in between fills during the cycle, especially in winter, the water will cool down in the pipes too much. Normally, the water heating selection will maintain water temps in the 130-150 degree range! If someone has been sick in the house, turn on the SANI RINSE if your unit has it! This won't stop--but it'll help prevent cross contamination--people getting sick from the dishes--this setting normally kicks the water temp up to 190 degrees during the rinse cycle.
on Sep 08, 2015 | Dishwashers
Siemens dishwasher isn't washing dishes clean and leaves some detergent in the door
Hello. From what you're describing, you might have low spray pressure(due to a clogged filter on the main pump, if your model has a filter). I really need the model number to help you accurately. Also, the water temperature may be too low to dissolve the detergent-- DISHWASHERS LIKE HOT WATER! The minimum temp for all the detergents is 120 degrees or hotter! I tell all my customers to turn on the hi-temp wash, or temp boost, or whatever the manufacturer calls it on every wash cycle! Otherwise, you're at the mercy of whatever temperature water got put in the tub. ALWAYS RUN THE HOT WATER IN THE SINK BEFORE TURNING ON THE WASHER. Modern units take very little water to fill. By the time the hot water makes it to the washer in most cases, it's already running on tepid or cold water--especially in the winter. I hope I helped you!
Sep 28, 2015 | Siemens Dishwashers
Water not heating up
see this causes and fix it. God bless you
will not run on cold water or even luke warm water, it has to be hot water. Most will even specify 120F or hotter water temp as incoming water. These new units only use 1.5-3 gallons of water for each fill, so the temp has to be there. Many brands recommend that you run your kitchen sink water until it gets hot, then start filling your dishwasher, we also recommend that. Some dishwashers will stop if it senses too cold of water coming in, others will try to warm the water and if it can't in so much time, the unit will stop and give an error code. Hot water also helps dissolve and mix the soap detergent better, giving you better washing results. Just make sure the water is hot going into your dishwasher, no getting around it.
Oct 16, 2012 | Hobart Am-12a Commercial Pan Pass Thru...
Kenmore Elite dishwasher won't clean and leaves white film
CHANCES ARE YOUR WATER TEMP IS TOO COOL and the 2nd
PROBLEM IS VERY HARD WATER THAT IS CAUSING THE WHITE RESIDUE. RAISE THE TEMP ON HOUSEHOLD WATER TO 140 F AND ADD SOME SALT TO THE WASH CYCLE. LASTLY USE A LIQUID DETERGENT LIKE LIQUID CASCADE.
Oct 13, 2012 | Kenmore Dishwashers
Hi, Our VFW post bought a used Hobart commercial dishwasher, model # wmp-es2 serial # 14054-302.We use the commercial soap,sanitizer, and rinse aid. The problem is,after washing the glasses they look...
Check that the dishwasher is getting hot by feeling the temperature of the door - also at the end of the cycle when you open the door there should be lots of steam. If the machine is heating the water then increase the salt delivery a little - or even try a more expensive detergent to see if it makes any difference.
Temperature-
The single most important factor in getting good results is HOT WATER!!
The water must be at least 130o to work effectively. This is documented by the major manufacturers of detergents, such as Proctor & Gamble. Otherwise, greasy films will occur, along with soap residues left on glassware, etc. Use a candy thermometer in a glass under the running hot water tap on your sink to measure the incoming water temp. In general, it is best to always turn on the hot water at the kitchen sink for at least one minute to allow the actual hot water to flow. If not, the first couple of wash cycles will have cold water in the tub, and this wastes time, energy and soap. Using the delay cycle is never a good idea, since you will be assured of a cold fill the first few cycles.
Water Hardness-
Most areas have fairly hard water, which affects the cleaning properties of detergents. Hard water is water showing above 7 grains of hardness. Our Austin customers have, for example, 11-20 gr. hardness in many areas, mainly due to the limestone aquifer which supplies the vicinity. For them, I recommend filling both detergent cups full, plus using a rinse aid. If you don't know how hard your water actually is, we have a solution.
Water Hardness Test Kits- Know where your water stands to determine your strategy.
[IMAGE][SRC][/SRC][ALT][/ALT][WIDTH]100[/WIDTH][HEIGHT]100[/HEIGHT][STYLE][/STYLE][/IMAGE] Easy to Use!
Checks hardness in Grains. Takes the guesswork out of detergent measuring!
Great for monitoring your softener's efficiency!
Click Here for details!
- According to dishwasher industry statistics, approximately five million new dishwashers are sold each year. Many new dishwashers find homes in the 1.3 million new houses built annually. But that leaves 3.7 million other dishwashers-and most are replacing existing units that no longer perform because of lime scale, soap scum, iron and grease buildup. Based on an average cost of $400-500 for a new dishwasher, consumers are spending more than $5 million dollars each day on new dishwashers ($1.85 billion each year). Perhaps this would change if they had heard about the Dishwasher Magic product first :)
You can determine the cause of cloudy glassware by soaking a glass in vinegar for 5 minutes. If the cloudiness is removed it is a hard water deposit and more detergent is likely needed. If the cloudiness is not removed it is a permanent condition known as etching. In this situation, use less detergent and stop pre-washing. In actuality, dishwashing detergent needs a bit of soil to work on, otherwise it will tend to foam up.
Maintenance Techniques-
Every two months, run the unit with a quart of white vinegar added to the tank (no dishes or detergent for this!). This removes any deposits left behind in the tub, and actually helps keep the drain clear! Do this mainly on units with plastic tubs, since they are porous, and will absorb not only grease, but residue from the detergent.
Use a rinse-aid, such as Jet-Dry, in your dishwasher, unless you have a water softener. In this case, do NOT use a rinse aid, and reduce your powder detergent to one teaspoonful per grain of water hardness. We recommend the solid form of the Jet-Dry, not the liquid. For one thing, the liquid is harder to deal with than checking a hanging basket visually. Also, the liquid dispenser only injects a couple of drops of liquid into the unit at the end of the wash cycle. This does not take into account varying degrees of water hardness in different areas. The solid version is always working right thru the wash and rinse cycles. Hang it in the left front corner of the upper rack for the best distribution.
Detergents- Gel or Powder?
Gel detergents are not the best solution for your dishwashing . They create more problems than they resolve. A few examples include:
Gels contain chlorine bleach (dissolves rubber seals)
Gels tend to cloud glassware, leaving a whitish film.
Gels never really rinse off of interior tub or from sump area.
Gels clog the detergent dispenser, making it release late or not at all. This causes door streaking by the chemicals.
Gels don't work well in hard water, they leave spots
Always use powdered detergent or tablets, and make sure that your water temperature is at least 125-130o to the dishwasher! It makes a world of difference in the final results.
The problem is usually the water not being hot enough and the detergent. need to try buying small containers of different detergents and see with works best with your water and machine. hard water and the wrong detergent causes this problem.Perhaps you changed detergent lately or they changed the formula of your detergent. Or your machine is not heating the water properly any more. Like a failing heating element.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jun 13, 2011 | Hobart Dishwashers
I own the Whirlpool duet set with the front loading washer. The clothes comeout with a bad smell. I was told that the washer probably needed to be cleaned. How is this done, and what makes it happen?
Using the wrong kind of detergent in your fancy front loader is a great way to grunge up your washer and impart some oder onto your clothes. And it accelerates the mechanical deterioration of your washer.
2. Using too much fabric softener and/or detergent.
Liquid fabric softener does not break down very well in cold water and the residue collects on the outer tub and basket along with the lint left from the wash. We professionals refer to this accumulated as grunge. Once formed, this grunge collects ever more additional soap, dirt, grease, human waste, mites, , parasites... and then some really bad stuff.
As it turns out, this grunge makes a perfect substrate for microbial life forms. Over some time- not very much time in warmer climates- those little bacterial colonies build up lots of microbial sewage, just like we do until one day you open the door to the washer
Using too much fabric softener will waterproof your clothes. How clean do you think your clothes will get if they repel water inside the washing machine?
3. Doing all your wash loads in cold water only.
Detergents don't dissolve as well in cold water. As a result, cold water washes leave behind more grunge. So... do an occasional wash in hot water. OK, maybe more than occasional. Like, I hope you at least wash your skivvies in hot water.
4. Leaving clothes in the washer at the end of the cycle.
Front loaders don't have as much access to open air as top load machines. Consequently, leaving clothes in the washer for more than eight hours will increase mold and mildew build up.
1. Add one additional gallon of hot water to the unit before sending it into a hot wash. This will raise the water level high enough to remove the Grunge Hiding Behind the Basket
2. Same as 1 but with bleach added to all dispensers. Clean the fabric softener cup with a rag first (bleach will not break up fabric softener since it is introduced in the rinse cycle with the fabric softener).
3. Same as1 and 2 but with a cap full of pine cleaner added to the wash water (NOT the dispenser). Add some old rags (they don`t need to be dirty) and select the extra rinse cycle. The wash action will help remove the accumulated grunge from the components
Once again, make sure you're only using high efficiency (HE) detergents in your front loader.
Nov 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Cold wash/rinse selected, but only hot water is used
I have a Sears front load washer and I also noticed that on a cold wash/cold rinse cycle the machine was drawing hot water.
Laundry detergents require water to be at a certain temperature to aid in disolve. The machine adds sufficient hot water, regardless of the cycle, until that temp is reached. If I was to use a cold water detergent the machine, because it has no way of knowing which detergent I'm using, will still add hot water until that minimum temp is released. I don't know if there are machines available which include detergent type as an option?
Sep 28, 2009 | Kenmore Washing Machines
Whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Sep 12, 2009 | Washing Machines
Maytag Front Load Intellisense 6.5kg
washer may not be detecting water temp but water flow ..if you never use hot water may try hooking cold water to a Y-connector and then hooking to both hot and cold inlet valves ..however it is also possible washer is detecting inlet temps in which case you're out of luck ..i suspect the latter
Sep 01, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
