Question about U-Line Wine Captain (2015WC) Wine Cooler
The ULN-15WCSS-00 stopped running (cooling)
I removed the lower grille to clean the condenser coil; put it back together and it hasn't run since. Any ideas? Thanks. Jackie
  • michael_loch Dec 16, 2008
    Same exact problem. Coil is clean and the light still works. Any help would be greatly appreciated.
  • ejod3 Feb 07, 2009
    Same problem on the same model.....light works, cooling has stopped
SOURCE: Ice maker will not harvest
As crazy as this sounds, turn the temp control a little warmer (counter clockwise). On this model, this control needs to switch to harvest the ice. A warmer setting should fix this issue.
Dean
You can also go to:
www.u-lineservice.com
Posted on Jun 05, 2009
  • 3600 Answers
SOURCE: Wine cooler #ULN-75BWC-00 motor seems to have shut
the motor could be defective or it could be low o refrigerant causing the pressure switch to not kick on the fan. Could even be wires have come loose from the fan. If the fan does not work it won't cool. however it mould most likely cosy you more to fix if you take it to a shop to have it repaired if you have the tools to test it with I can help you so let me know if you have a test meter volt ohm meter and I can tell you how to test the system.
Posted on Feb 15, 2010
  • 176 Answers
SOURCE: my uline keeps running and soda in cans freeze.
your thermostat is bloked or didn't see the reeal temperature, it must be replaced whit similar new one.
Posted on Feb 21, 2010
ZJLimited
  • 17970 Answers
SOURCE: How do I access and
Most likely the Thermostat is bad not bringing the unit back on; the Thermostat is the temperature control knob located in the toe grille of the unit.
Removing toe grille you will see a little box that houses the t-stat. If you wanted to test to be sure just remove the 2 wires that are connected to the thermostat and conncet them together to make sure compressor and fans start up.
Hope helps.
Posted on Dec 20, 2010
  • 135 Answers
SOURCE: MY COLD CONTROL IS BAD
go to googlr type your refrigerator brand name and parts .
if you would not get. see me e-mail wongjimmysoon@qq.com
i need brand name and model #
Posted on Jan 11, 2011
Ffa52 hotpoint diamond freezer running too warm
change condenser fan clean condenser coil dust at bottom of ref stopping cooling processes.Just like if you put cardboard in front of your car it will over heat or if fan is not blowing air on condenser coil
will not cool it fan and coil at bottom of ref. remove back you will see the dust pet hair a big problem with ref.
Mar 04, 2015 | Hotpoint Refrigerators
My daughter's fridgidare top mount freezer blowing out cool air but not keeping things froze , can freon be put in it , fridge is only about 5 yrs. old
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor.
Floor Level Coils
You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils.
Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Rear-Mounted Coils You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant.
Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.
Jul 10, 2011 | Frigidaire Refrigerators
The freezer is running and is set to the coldest setting but still is not cold enough to freeze our food. Ice has melted and food in the freezer is beginning to thaw.
1. Make sure condenser is clean.
2. If you have a "rear mounted" condenser (black coil on back) make sure it has enough room around it for air to circulate. Not against the wall and if under cabinet should have about six inches clearance.
Rear-Mounted CoilsYou should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant.
Floor Level CoilsYou should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils.
Jul 10, 2011 | Amana ARB220RCW Bottom Freezer...
Hot spots on outside of Amana fridge. sxd22s2w model
if it feels like it's running hot check the coil to see if it needs to be cleaned,remove the bottom kick plate and look at the coil,the coil should be cleaned once every 6 to 12 months,also pull the fridge out,remove the back bottom panel,make sure the condenser fan is blowing and vac out any lint near the fan and compressor,also check the cover that you removed and clean that too.you might want to unplug the fridge while you clean back there so you don't hit the fan blade,wait 5 minutes before you plug it back in so the compressor can reset itself.there are gas lines that run through the frame of the machine,if the coil is jammed with dust and lint the machine runs hotter,this is how it cools off through the condenser coil and the fan blows the air around to help cool it down,if it runs hot then the freon will run hot and you could feel it on the frame and in the strip where the doors close together.you can buy a brush that you can push into the holes of the coil to pull the dust out or if you have a shop vac you can vac out as much as you can and then put it on blow and blow the dust out of the coil,just hit it with short bursts or the dust will blow everywhere.
May 22, 2011 | Amana Refrigerators
How to clean condenser coils on lfx25960tt
Condenser coils- The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Sep 04, 2010 | LG LBC22520S (224 cu ft) Bottom Freezer...
KitchenAid KSSC42QM The divider between the fridge and freezer is warm to the touch and the fan on top keeps running. The freezer and fridge are still cold but I'm worried that something is going out.
I do not think my first attempt to help you went through, if this is a duplicate response I am sorry. It sounds like your condenser is overheating, this could be due to the coils being very dirty or the fan that keeps them cool is not running. The motor you hear on top is most likely the compressor that does the cooling. Remove the grille on top and look at the coils (similar to a radiator in a car but smaller) there will be a fan behind them that will (should) be turning. If the coils are dirty use a vacuum and brush if you have one to clean very thoroughly. I have put together some instructions on how to do this but it is for bottom compressor models, but it might help, I have attached the link to the bottom of this reply.
If the motor is not running you can see if something is caught in the blades stopping it, if it is clear and not running you will need a new condenser fan motor.
I hope this helps, let me know if you have questions.
http://www.fixya.com/support/r4694132-hot_door_seal_rail_divider_strip_between
May 05, 2010 | KitchenAid Refrigerators
My Lieber fridge freeze KSDves 4632 has power and the compressor is hot and sound like it is running, but neither the fridge of freezer are getting cold. I have circum navigated the therm and it is still...
NOTE_ Make sure that the evaporator and condenser fans are running. If they are not running, this will lead to a failed control board.
Jan 07, 2010 | Refrigerators
My refrigerator and freezer worked fine until after a power outage. Now the unit will not cool at all, and the fan runs constantly. What should I look for?
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously(non stop fan action) or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Now, Once the coils are cleaned, simply re- introduce power to the unit, and observe for a couple of hours. If the fan continues to run, and there is no cooling affect, this will indicate that the main control aboard(PCB), is damaged. It must be replaced in this case.
Dec 27, 2009 | Kenmore 64802 Top Freezer Refrigerator
Compresor is hot and refrigerator it doesn't work
HI. This will occur if the condenser coils are dirty. This will inhibit the coils from dissipating heat.
Nov 25, 2009 | Maytag Refrigerators
Open Questions:
See all U-Line Wine Captain (2015WC) Wine Cooler Questions
U-Line Wine Captain (2015WC) Wine Cooler Logo
825 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
