Question about IBM ThinkCentre A51 PC Desktop
IBM Thinkcentre A51
PC power on, but doesn't boot up. I have removed and cleaned the RAM which worked for 6 boot ups, BUT the same problem has returned.
  • 3 Answers
Please check the system board if there is any bloated capacitor,and also try to take out the cmos battery reset the cmos and try to boot,if it fails,its system board.replacement needed
Posted on Apr 06, 2009
Problem booting on start up its turning off...but when you are in bios its ok...even withouth hdd and cd its turning off when gets on start up...i/ve tried different power supply but its still the same...
press delete at startup
go2 BIOS option
1ST BOOT DEVICE CD/DRIVE
2ND BOOT DEVICE CD/DRIVE
F10 SAVE
RESTART PRESS F12
read here
http://pctells.blogspot.com/
http://mailerror.blogspot.com/
http://faqall.blogspot.com/
http://net2go.blogspot.com/
Feb 18, 2011 | IBM ThinkCentre A51 PC Desktop
IBM THINKCENTRE A51p WIN XP PRO/SP3 1GB RAM ALL MICROSOFT UPDATES ARE CURRENT BOOTS QUICKLY WITH 1 SATA HARDDRIVE (1.5 MINUTES) BOOTS SLOWLY WHEN 2ND SATA IS ADDED (5 MINUTES) ONCE WINDOWS...
it seems as they are conflicting this u usually caused by jumper settings you need to download the utility program from the hdd manufacture the utility allows you to change hdd priority you need to change the settings on the second hdd to slave and the first hdd to master but like i said unlike ide which has jumpers sata has digital jumpers the utility from products website is needed for this
Sep 02, 2010 | IBM ThinkCentre A51 PC Desktop
My IBM A51 model 8123 is not booting. There are several beep sounds when I turn on the PC. The booting is not running and the monitor is blank. We already replace the memory but the sound are still...
You can use the following link to pint point the problem. The multople beeps can be caused due to loose memory chips on the motheboard or a keyboard key is pressed.
Click on the Link Below
Troubleshooting IBM
Thanks for using Fixya
Proton
Aug 20, 2010 | IBM ThinkCentre A51 PC Desktop
When i start the system the fan runs in high speed and the system not booting, i have tried with replacing RAM, SMPS still then the problem persist
The fan you hear when the the computer start, is the power supply fan, the system not booting up mean you should check the cable which connect the monitor to the computer If the connection it proper then you should check the video card you can do this by try using another monitor or replace the video card because if its faulty the computer will never boot.
Aug 16, 2010 | IBM ThinkCentre A51 PC Desktop
IBM ThinkCentre S51 Intel Pentium 4 PC Desktop won't boot up. The power light comes on for about a second and then goes off, over and over again. It does not stop unless I unplug it. The mouse's infrared...
Sounds like it's probably the power supply. The computer takes more power to boot up than to run, so if it can't get enough wattage it can't boot all the way up, and it will shut down and try again.
If you're comfortable opening your computer up, you can test the power supply connectors with a voltmeter or multimeter to verify. A new power supply is typically only $30 or $40.
May 29, 2010 | IBM ThinkCentre A51 PC Desktop
Lenovo thinkcentre a51 reboots with several beeps
There is a system error in the system. Would be hard to determine cause of the error without viewing an error log. I recommend, using system restore and setting the pc back to a time it worked good. Otherwise, download a free registry error cleaner and registry optimizer called "glary utilities" from glaryutilities.org
Run the program to get all the bugs out of your pc
Aug 04, 2009 | IBM ThinkCentre A51 PC Desktop
IBM THINKCENTRE A51 - WON'T BOOT
Simple dear, I think that you can see the power led and hdd led but it wont boot. Right. So switch the system and than open the cabinet and than remove the RAM , CLEAR THE DUST ON THE SLOT AND RAM. THAN REPLUG IT IN THE SAME WAY. PLEASE DO NOT INSERT IT FORCEFULLY BECAUSE IT WILL GO EASILY IF YOU ARE INSERTING IT IN RIGHT WAY. SO CHECK THE POSITON OF THE NOTCH ON BOTH THE RAM AND SLOT OK
AND THAN START THE SYSTEM. THIS MIGHT DEFINATELY SOLVE YOUR PROBLEM.
Nov 19, 2008 | IBM ThinkCentre A51 PC Desktop
IBM ThinkCentre A51 PC Desktop Logo
467 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
