Question about Bosch HGS435UC Gas Kitchen Range
All lights on the touch panel are flashing and a continous beeping sound
The power went out and went back on during cooking. The range started beeping and all lights on the touch panel are flashing. What could be wrong? The USER INTERFACE BOARD or the POWER BOARD?
  • slate Nov 26, 2007
    same story with my bosch maxx 6 washing machine. now it does not start.
  • WDTWAGNER Feb 11, 2008
    The same thing happened to my oven. Did you ever find a solution?
Bosch 700 series range. So far unplugging the range and waiting several minutes to plug back in reset everything like rebooting a computer.
Posted on Apr 30, 2008
I have a Frigidaire Elements stove. When I went to preheat the oven I got a constant 'beep' and a code, F13 ERR. Please help Thank-you Anxious in Indy
Hi akadiki,
This error code F13 description is a bad Clock ERC. The steps below will help you determine whether the ERC or touchpad is defective.
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F13 code comes back (usually accompanied by a beeping sound).
7. If F13 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
Sep 15, 2011 | Kitchen Ranges
Have roast on burner and it beeped and flashed FI. I pressed cancel and it stopped. Is this something I should be worried about? It is working fine.
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#ixzz1gY5sWaIg
Mar 31, 2011 | Frigidaire GLEB27S7A Electric Single Oven
I have a mer5730aaw my bottom element dosen't work.Then the display showed F1 and started to beep.So I unplugged the oven and disconnected the multi wire to the control panel.Then it displayed F3
(Clock).
Dec 09, 2010 | Maytag MER5530 Electric Kitchen Range
I have a Maytag Advanced Cooking System Model #MGR5745ADA that is showing a code "F1" on the display. The oven doesn't work.
HI. This will occur when there is a fault present within the main control board, or touch pad assembly. use the procedure below to determine where the actual damage is located.
Caution: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
Nov 25, 2009 | Maytag MGR5750 Gas Kitchen Range
Magic Chef Oven 3888VRA beeps and shows F-1.
Hi this is indicating a Defective touch pad or clock (ERC).
This simple test will help determine whether the ERC (Electronic Range Control board or Clock) or the touch pad is defective when F1 error code is present. Follow carefully, and with caution.
Warning: Do not preform this test if you feel as if you are not qualified to do so. Contact your local service depot, if needed.
Nov 17, 2009 | Magic Chef CER3725AA Electric Kitchen...
F2 and F3 Errors just started on my GE Electric Range
I had to clean the contacts in the control panel to fix my same problem.
Nov 10, 2009 | GE Kitchen Ranges
F1 error code, beeping
You have either a bad ERC (clock) or a bad touch pad.
  • Disconnect power to stove
  • Gain access to the back of the clock (electronic range control or ERC).
  • Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  • Make sure everything is clear and will not short out when power is turned back on.
  • Turn power back on to stove.
  • Watch for the F1 and listen for the beep.
  • If you get the F1 and beep, replace the ERC.
  • If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    N
  • OTE: Some models incorporate the touch pad and the clock as one part.
  • Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Aug 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    F1 code problem
    Jul 28, 2009 | Jenn-Air JGW8130A Electric Single Oven
    F1 code on display pad
    That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
    Appliance Repair Help With Live Chat
    Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
    Bosch HGS435UC Gas Kitchen Range Logo
    579 people viewed this question
    Top Bosch Kitchen Ranges Experts
    William Miller
    William Miller
    Marvin
    Marvin
    Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
