Question about GE JE2160 Microwave Oven
Arcing inside microwave after small fire
I have the ge profile microwave je2160...my grandson put a metal hot wheels car in the microwave and turned in on...car burned...we got the car out...cleaned the soot up with soap and water...but when we turn the microwave on it continued to arc....is there any chance in fixing it...i guess what i get for paying over 300 for a microwave
  • GE Master
  • 9,098 Answers
Quite often this is due to carbon, grease, or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Nov 24, 2008
Arcing and flashing during cooking cycle
Arcing and flashing either has to do with having metal parts inside that are not chromed perfectly (better yet only put metal in if it's a microwave convection oven on convection setting only), or some of the powder coating on the inside of the cabinet is damaged. Or a twist tie etc was inside during use. If the cabinet is damaged dispose of unit.
Oct 20, 2013 | GE Adora Over the Range Microwave....
I have a GE Profile Advandium 120 SCA1000DWW03 microwave. Recently noticed arcing or sparking at the base of the back wall when microwaving. Any ideas or solutions? Was purchased about 5-6 years ago
This is not good, the magnetron is arcing because there is exposed metal. The manufacture provides a special enamel white paint that insulates the interior to prevent this. I would contact GE or appliance repairman and not use the oven until this is dealt with, running the microwave unchecked will eventually burn out the magnetron.
Feb 06, 2011 | GE Microwave Ovens
My ge Profile microwave just stopped heating food/liquids. All else works on panel; just not heating. Why?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
45xs
May 12, 2010 | GE JE2160 Microwave Oven
My GE Profile microwave just stopped heating food/liquids. All else works on panel; just not heating. Why?
heatman101
Mar 19, 2010 | GE JE2160 Microwave Oven
Fire in microwave
Do not put any metallic objects or substances in side the oven . It will produce arcing inside the oven. Take care in future.
May 10, 2009 | Microwave Ovens
Microwave smells of electrical fire
The magnetron inside the microwave is starting to short out to ground. This happens after use there are small minute cracks on the body of the magnetron and those small cracks are big enough for 15,000 volts and up to 30,000 volts to leak through and arc to ground. It is not a small short but a big one. Replace the magnetron before it burns holes inside your microwave. Replacing the magnetron if you can find it locally or through the internet is pretty straightforward. Unplug the microwave and take the cover off about 6 screws. On the same side as the control panel and right behind it you will find the microwave on top. It is held in place with only three to four big screws. It will have about 4 wires with terminals on them that plug into a couple of places one being the large capacitor that stores all the voltage and discharges it through the magnetron. Take the terminals off and I always recommend with some needle nose pliers with insulated handles. There is nothing to unsolder and to solder. Its like replacing the battery in your car or the electronic module. Take care and good luck.
Jan 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
RECALL ON GE MICROWAVE OVENS
I am not finding it on the recall list put out by GE... They also have a toll free number 1-888-240-2745 if you would like to contact them directly...
Have a great day!!
Bill
Dec 07, 2007 | GE JE2160 Microwave Oven
Light Stays ON Inside - GE JE2160
It may be a stuck relay on or other problem on the control board.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
It's possible but not likely that you have a bad door swith or door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 30, 2007 | GE JE2160 Microwave Oven
Light Stays ON Inside - JE2160
If it's under warranty, I would contact GE Customer Service at http://www.geappliances.com/service_and_support/contact/
If not, then I would suspect a bad door switch or a problem on the control board.
We repair these control panels on a regular basis for customers nationwide with our guaranteed $39.95 service.
Please write back with your brand and model number if you need further help.
Nov 29, 2007 | GE JE1540 Microwave Oven
GE JE2160 Microwave Oven Logo
199 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
