Question about Apple Mac Pro One 2.8GHz Quad-core Intel Xeon/4GB RAM(4x1GB)/320GB/16x SuperDrive/2600XT (Z0EM-2.8GHZ4GB) Server
We added extra drives but the machine does not mount them
How do we get the machine to recognize the new drives?
  • 130 Answers
Try adding one at a time. Make sure the drives are jumpered, partitioned and formatted, correctly. Make sure you are using the right type of cable. Cable select or you select.
Posted on Nov 22, 2008
My dvd drive disappeared from computer/device manager. Drive opens, and spins disc, but isn't recognized by Windows 7.
Does BIOS still recognize the drive? Also, check to make sure the IDE / SATA cord is fully connected, the dirve will operate with power, but wont be recognized without the other cord. If the cords are connected and BIOS reads it then win7 should autodetect it. If its not, it may be the disc itself, try putting something you know for a fact works. If the problem persists, try adding the hardware through the device manager, or deleting all mention of it, then re-adding it through the device manager. This tricked worked for Xp machines, although Ive never had to try it on a Win7 machine, it should still work.
Jul 28, 2011 | Compaq Presario F767NR Notebook
If they are SCSI drives, you must enter the SCSI configuration software during a powerup and initialize the drives. From there, you can add them to a drive array or create a new array.
Feb 18, 2011 | Dell PowerEdge 1600SC Server
I am trying to find were to put the new hard drive in the compaq presario 5000
There are several extra bays internal. You need proper data/and power cables, possibly a "Y" splitter to give you access to an additional power tap. Also about 4 small machine mounting screws and or spacer shims if the HD is smaller than the available bay. The HD does not necessarily need to be mounted through the front bt the 5000 has removable bezels that exposed the xtra bays.
Aug 21, 2009 | Compaq Presario 5000 PC Desktop
Hotpoint aquarious extra wd63 motor mounting broken
Made a new mounting bracket out of a piece of flat bar. Machine has never run so quietly!
Jun 13, 2009 | Washing Machines
I purchase more memory for my sansa e250 player and when i go to download music from my mediaplayer it doesnt recognize that i added more memory
the extra memory is considered a seperate drive and is recognized by your computer. Try moving the files you have from the normal internal memory to your backup drive so that you can download to internal again. (Via your computer and dragging and dropping)
Jan 28, 2009 | SanDisk Sansa e250 MP3 Player
Installation of one touch mini 4
hello, if you are adding an extra hard drive for space make sure to change the teeny jumper to the proper pins next to the connection slots on the hard drive. the jumper makes your hard drive work as a slave (extra drive) or a master (main drive). if you have a main drive allready on your comp and you dont switch the jumper the slave position the computer will not recognize it becuase of the new hard drives jumper being in the master position or pin connector.
if your installing it as a 2nd master drive you need to use your extra hard drive slot on the mother board for this to work as a secound master then you need the jumper in the master pin slot. there is a small diagram on to the hard drive info label it looks like pins and it shows you where to locate or place the jumper for either master or slave.
for a slave drive once you have placed the jumper properly then you can instal it on the same cable with the main. look at the cable it will have a main and a slave small label printon the connector or if you prefer you can use the 2nd hard drive cable on the secound slot on the mother board turn on your comp if you are going for a extra hard drive the comp should recognize it if the jumper is properly placed. when your comp is running you can check by going into (computer) and it should be there as a new drive letter
after this you may need to format the drive for use. you right click on the hard drive letter and choose format drive
hope this helps good luck with your upgrade.
Dec 10, 2008 | Maxtor Hard Drive
Simplech simple drive not operational.
I have a 2007 SimpleTech PininFarina 320GB USB drive that stopped working. Windows XP recognized the USB interface, but was unable to load the drivers. Also, while the drive has always been quite I noticed that I could not hear the drive motor. So.... I opened the case only to find the drive moved forward because the mounts failed. Result the SATA connection was not power!
I found both, and only, plastic supports to hold the Hitachi drive failed. During manufacturing the screws were overtightened which cracked the plastic mounts. As I continued to carry the drive around the mounts eventually failed. So I removed the drive and drilled two new holes in the unused mounts. NOTE that I did not tighten the screws down...only snugged up to the plastic (I drilled the holes for an exact fit...If you wish to enlarge the holes use small washers between the drive and the mount...the extra 1/16" play between the drive and the mount is why the mounts failed).
To open the case remove the four screws on the bottom of the unit. Two are visible, and two are under the serial number sticker near the front. The top will now lift straight off once the front relase tab pops free. Note that there is no way to "release" the tab (tab is in the middle (side to side) and approximately 1/2" from the front). Just keep pulling gently, and pray. Once the top is loose switch wires allow you just enough room to place the top on the work surface and repair the unit. Also the side panels will slide straight up and off once the top is removed.
Good luck. This is the reason my drive failed...and I suspect the reason many others failed since the mounts were not properly fastened.
May 21, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Wont recognize additional ram
It could be the wrong ram that u are using when i put extra ram in I make sure they are all the same brand. some boards take 2 different types of ram (speeds) i would go back to crucial with your good ram in and then do a check and see what ram your board needs
Dec 20, 2007 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Apple Mac Pro One 2.8GHz Quad-core Intel Xeon/4GB RAM(4x1GB)/320GB/16x SuperDrive/2600XT (Z0EM-2.8GHZ4GB) Server Logo
63 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
