Question about Kenmore 77082 Gas Dryer
Need a lint screen, also need a hood for natural gas/propane
I have a Kenmore Elite Gas Dryer model 77082. I recently lost the lint strip in the lint screen and as a rersult the dryer stop working. I am in dire need of a lint screen. In addition I need to change the gas hood as the gas used on this machine is propane gas. It is sooting because the hood is incorrect base on the type of gas used.
    Sergeant:
    Champion:
  • 324 Answers
You can get the parts at sears.com. the model should start with a 110. if the strip went down the vent it probably lodged in the blower jamming it.
Posted on Nov 21, 2008
How do you revert a Kenmore Elite He5 gas dryer from propane to natural gas. Is it just changing out the orifice?
a little more than the orifice needs to be changed the pressure regulator and on some the whole gas valve body
Sep 24, 2016 | Kenmore Dryers
Conversion of Kenmore Elite Gas Range 790.7523 from Natural gas to propane.
each burner has a natural gas jet or (orifice) as you pull them out, one atb a time. You should be able to color coordinate them at that point. the jets will be at the end of each gas line right before the burner. and each burner gets one. I haven't seen the model you are referring to. but the ones i have changed out in the past, usually the hole is the same size for all the burners no matter the size of the burners. I hope this helps. good luck with it!
Jun 17, 2015 | Kenmore Kitchen Ranges
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
Converted a kemore from gas to propane now it doesnt get very hot and takes forever to dry
Normally natural gas appliances have a different nozzle size than the propane units. i would check with your propane/gas dealer to make sure.
Mar 02, 2014 | Kenmore Elite HE3 Steam 8674 Dryer
How do i convert gas dryer to propane kenmore elite
kenmore has instructions along with the correct orfices you need to burn propane the only difference between gas and propane orfices is the hole size in the center of the orfices and there is very little difference in size propane is smaller hole because the pressure difference between natural gas low pressure proppane higher pressure
Jan 13, 2013 | GE GFDS350GLWW Dryer
I have a kenmore ellite bbq model 141.16691 propane - I want to convert to natural gas, there is no conversion kit to make it but the natural gas model 141.17691 is exactly the same - just natural gas. If...
Many manufacturers make grills in propane and natural gas, but are not convertible from one gas type to another. The reason being safety. Each grill model, whether it's Natural Gas or Propane is tested and approved for that one specific gas type and that alone. Converting it would put all the responsibility on you, if something was to go wrong.
I suspect in part, the reason you want to convert is so that you want have to refill the propane tank any longer. But, you may want to consider this against convenience. Propane Gas burns cleaner and hotter than Natural Gas in an outdoor environment. Which boils down to lower high end temperatures, longer preheating times and the expense of running an approved gas line to the grill for Natural Gas. Not to mention the cost conversion parts.
But, the decision is yours to make. Thanks for choosing FixYa.
Aug 06, 2011 | Kenmore Elite 644 sq. in. Cooking Area Gas...
How do i switch from propane to natural gas on a Kenmore he3 Dryer
You would have to change the gas train out to a natural gas one, the orifice sizes are different.
May 02, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
I moved and after hooking up my gas dryer to gas tank it will not heat up....
were you on propane b4 the move or natural gas? A natural gas dryer will not run on propane nor a propane one run on natural gas
Jan 14, 2009 | Kenmore 73932 Gas Dryer
Soot from gas dryer!
have you recently changed from natural gas to liquid propane, or visversa? if so, this could be the problem. especially natural gas to lp.
Oct 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 77082 Gas Dryer Logo
126 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
