Question about HP LaserJet 4L Printer
Paper jam i had something printing and i stupidly open paper cassete now it is jamed please help......
    Scholar:
  • 77 Answers
Remove the toner, and try to gently pull out the paper jam.. If the page gets torn, or ripped, make sure you have all the pieces of the paper removed. Then re-start the printer. Print a test page to make sure the paper path is clear..
Posted on Nov 21, 2008
Any idea how to fix it? Is it the sensor or something else?
Open totally the cassete look for paper jam inside that might cover the sensor.
Remove cassete and look for black plastic actuator located on top of paper when cassete is inserted, it might be broken.
If all are ok , press as follow to reset the malfunction [off] while pressing [ Utility/Counter] turn [On] wait till the display appear then [trouble reset] it will appear OK on screen turn OFF/ON main power.
Aug 17, 2015 | Konica Minolta bizhub C250 All-In-One...
Paper jamed on the bottom of the copier that I can't get to it
hi just remove the paper casset and remove the paper and reset the casset hope help you
thanks
May 13, 2010 | Office Equipment & Supplies
Paper jam cassete 1
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 28, 2009 | Kyocera FS2000DN Laser Printer
My epson cx3200 says paper jam, I dont see any paper jamed, when i press the button to say ive cleared it,it then runs a sheet of paper through it and says paper jam again, surely if there was a paper jam...
Dec 06, 2009 | HP PSC 2210 All-In-One InkJet Printer
Paper jamed
Hi
Thanks for using FixYa. Perform the steps below in order to solve this incidence:
  1. Disconnect the power cord or power supply adaptor from the rear of the HP All-in-One product.
  2. Remove the paper pack remaining in the input tray.
WARNING - Do not try to remove the jammed paper sheet yet. Trying to clear a paper jam from the front of the device can damage the print mechanism. Always clear paper jams through the rear access door.
  1. Open the rear access door or the two-sided printing accessory.
  2. Gently pull the jammed paper sheet out of the rollers.
  3. If the paper tore when it was being removed from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If not all the pieces of paper are removed from the device, paper jams are likely to occur again later.
  4. Replace the rear access door or the two-sided printing accessory.
  5. Restart the printer to continue the current job.
Please seee this link for more details--
HP Photosmart C5280 Paper jam error
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | HP Photosmart C5280 InkJet Printer
Jam paper or? on np6650 11
That could be a bad sensor.
Jun 21, 2009 | Canon NP 6650II Copier
PAPER JAM
open the front door and remove inkl cartridge then check thr is not any paper jam .thn refix the inkmcartridge.
Mar 12, 2009 | HP Deskjet 450 wbt Printer
Paper jamed
Sounds like the fuser is causing the jam. Anything from a dislocated pic finger to other paper debry can be causing these types of jams.
If you open the back door, will the page exit the printer fine of does it still jam?
If it still jams the fuser is definatly the problem. If it dosen't, then it might be the delivery assembly causing the jam.
You might be able to see where the jam is happening if you print something and watch it though the back to see where the paper catches and jams.
Nov 19, 2008 | Brother HL-2040 Laser Printer
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Canon mf5650
Check the paper setting in your software. Paper size should be A4 in all instances. Hope it helps
Oct 04, 2007 | Canon LaserBase MF5650 All-In-One Printer
HP LaserJet 4L Printer Logo
126 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
