Question about Dell 3200MP Multimedia Projector
Dell 3200mp Hi, How do i reset the lamp hour`s? I replaced the lamp. It was flickering, loosing color and would shut off in 10 to 15 minutes. I go to the onscreen menu and go to management. The hour`s say 0 hour`s. I try to reset the hour`s and it wont change it. I still have the same problem with the new lamp, flickering and shutting off. Is the lamp the problem? Will changing he hours fix the problem? Thank`s for your help.
  • 3 Answers
Suggest your remove your case (screws on the bottom, except foot, and one side screw). Blow out your projector paying special attention to your color wheel assembly, this part gets dusty and causes your described problem.
Posted on Jan 15, 2012
Im not sure sounds like its something internal thats not related to the lamp reset (board or component failure). I have a totally different problem. I have a bad dlp chip and need a donor unit to replace if you dont get this fixed and want to sell it email me @ussmillerco@yahoo.com and let me know. Good luck thx sean
Posted on Nov 27, 2008
  • John Hoog Jun 22, 2012
    The picture shake is caused by the DLP chip loosing sync with the color wheel, caused by dust on the sync sensor that is reading the color wheel.
    I had the identical problem with a new lamp until I blew out the system, even though visually it looked clean. No issues since cleaning, just need to be careful where the dust is blown.
Dell 3200MP DLP Projector: displays OK, but with vibrations soon as power button is pressed ON. found cause; rotating see thru thin plastic disk has a quarter of the disk broken off, thereby causing...
You need a replacement color wheel (that is the name of the broken plastic disc, likely glass). I have been unable to source one. Recommend you buy a used projector with a bad lamp, usually less than $100 on eBay and just put your good lamp into it. Keep your old one for parts.
Jul 04, 2011 | Dell 3200MP Multimedia Projector
Dell 3200mp lamp
are both of the lamps the same? have you installed it correctly in the socket. you might need to do a cold start for your projector. unlpugg it and try to wait for 5 minutes before plugging it again and turning it on. one your projector detected that a new lamp is intalled, it should work fine now. but if its still not working, you might want to try and replace the new lamp again. sometimes this happens.
hope this helps.
Feb 20, 2008 | Dell 3200MP Multimedia Projector
Lamp will not stay on more than 1 hour and during that time it flickers and the color fades in and out
Your lamp is nearing the end of it's life. Contact Dell about a replacement lamp.
Feb 27, 2011 | Dell 1201MP Projector
Replaced the lamp in my Dell 3200mp projector when the lamp indicator came on. After replacing the lamp indicator is off , but the lamp will not even attempt to light. Anything else I can check?
did the old lamp fail? Or did the lamp light just come on?
Firstly I would disconnect the mains and carefully put the old lamp back in. Test the projector. Then put the new one back in and test.
There can be problems with lamps not being seated correctly, and/or the lamp cover not being fully closed.
Post back for more help if required.
Dec 29, 2010 | Dell 3200MP Multimedia Projector
Tv stays on for couple of minutes and then shuts off
Hear any grinding or motor noises,pictures flashes or flickers in black and white?All these cause are the death of a colors wheel.Must replaced the colors wheel.When was the last time,this tv replaced it projection lamp?1 1/2 or 2 years the projection lamp was replaced,tv on and in used like 4 or 5 hours a day.The projection lamp life is over.Require a new projection lamp.
Aug 16, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Dell 3200MP projector. Lamp warning light comes on after approx 30 minutes of use and the lamp turns off. Bulb is new. I am not sure what the warning light is indicating.
The ambient temperature in the room is to high.
Try lowering the room temperature. If that doesn't work
get a small fan and place it near the projector to provide
extra cooling. The projector is running border line on
high temperature and just needs a little extra cooling.
Jul 18, 2010 | Dell 3200MP Multimedia Projector
Dell 3200 Projector
Hi Tara
This normally indicates that the lamp will need replacement.
The Ibook and this Projector are compatible as long as you run a Microsoft operating system i.e. Windows 98' and higher.
When replacing the lamp , you can just as well clean out the Projector - this is quite important as it prolongs the life of your lamp.
May 18, 2008 | Dell 3200MP Multimedia Projector
Dell 3200mp
Hi Lagnitta
Take out the lamp and check for any irregularities like discolouration and marks.
This is unfortunately dammage to the lamp and the lamp will need replacement.
Thanks for using Fixya.
Apr 27, 2008 | Dell 3200MP Multimedia Projector
Dell 3200mp lamp not working
Dude! You just saved me 250.00..It worked...I could kiss you!! ...HA! HA!...:)
Feb 19, 2008 | Dell 3200MP Multimedia Projector
Sharp Projector XV-Z90 Flickering
the color wheel is dirty. It just need to be cleaned.
Feb 18, 2008 | Sharp Projector lamp Projector Lamp
Dell 3200MP Multimedia Projector Logo
468 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
