Question about Traulsen Freezers
Bad Temperature Controller
So old need generic replacement part. Where do I find one?
  • 700 Answers
You can go to either aJohnstone Supply, United refrigeration, or baker supply, Insco Distributing, refrigeratin hardware supply company( they shio it from eithe dunver or someshere in california
Thank for using FixYa
Posted on Dec 24, 2008
Ge profile refrigerator temperature setting
Sounds like the damper controller is stuck due to obstruction or isn't working at all and needs replaced.
Jul 31, 2014 | GE PFE29PSDSS 29 cu. ft. French Door...
Hotpoint freezer FZA84 does not freeze ,high temperature light is on. when switched on the temperature comes down to about -12 C . does not come any lower but i hear a irregular hissing sound probably
You need to cut it off. You may be doing a lot of damage there. If this freezer is 8-10 years old, you may want to go ahead and replace it. At least it will not give you any more problems.
Jan 25, 2013 | Hotpoint Freezers
P-1 flashes in temperature display
P1 is a probe fault on the control probe. Check it's not damaged or got water in the end.Check the connection to the controller. If all good, replace probe.
Apr 20, 2012 | Freezers
The frigde is turned dow but still freezing all
your cold temperature control is bad, not shutting the unit down when the temperature is correct. needs to be replaced.
Mar 23, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
What is the normal and the lowest temperature that the Haier HNCM035E, 3.5 CU FT capacity C hest Freezer will susstain?
WATH IS THE NORMAL AND LOWEST TEMPERATURE THA THE SMALL MAGIC CHEF FREEZER MODEL CUF3DS
Sep 10, 2009 | Haier Freezers
Delfied Freezer6000XL freezing temps are not hold
Sounds like a refrigerant restriction in the system. Recover the refrigerant, replace the filter drier and pull a deep vacuum on the system before recgarging.
Mar 21, 2009 | Delfield Freezer 6151XLSR Stainless steel
WHIRLPOOL UNDER WORKTOP FREEZER APPROX 11 YEARS OLD BEEPING
the temperature control is bad. when you push the fast freeze it bypasses the thermostat for 12-24 hours depending on which model you have. I am not able to find any parts information with the model number provided but you should be able to find a temperature control at any local appliance parts house or online thru any reputable supplier. Thnaks Peyton
Feb 24, 2009 | Whirlpool Freezers
My freezer is not cold enough to keep food frozen...
the "e" usually means it has an error. it could be a bad temperature thermistor or a bad control board. the most likely is the board.
i hope you are less then 1 year old as the board can be quite pricey, about 150 bucks.
you could try to unplug the unit for a few minutes and then plug back in and see if the code goes away and returns to the cooling mode.
Dec 29, 2008 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore freezer quit working after power outage
simple stuff, you have a compressor a stat and power. check the receptacle to be sure you have 120 volts . then check the compressor with stat at max cold setting to see if you have 120 volts at compressor. if you do then compresssor is bad =new compressor or new unit. if no power to compressor then stat is bad= new stat. i always recomend new unit cause new stat or compressor wont fix a freon leak.... i have replaced a few compressors that died soon after due to a freon leak. good luck...
Nov 23, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
171 people viewed this question
Top Traulsen Freezers Experts
Dennis Boxerman
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
