Question about Husqvarna Designer I
PR600 Needle #4
Needle 4 sews correctly, however it will only sew about 20-30 stiches at a time and stops. I have to cut the thread and then the machine will start to sew again. I have adjusted the tention... it makes no difference?
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Does not sound like a viking designer machine. Resubmit with more info, including make and model of sewing machine.
Posted on Feb 13, 2010
My sewing machine straight stitch sews in reverses but misses stiches while going forward
try these suggestions
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Jan 24, 2013 | Riccar Sewing Machines
I have a pr600 brother embroidery machine,it trims the thread too short
Make sure that when your machine stops and cuts that your needle is in the upper most position. Other than that you may need an adjustment from a pro repairman.
Dec 04, 2012 | Sewing Machines
I have kanmore sewing machine its not stiches at all one time noise & stop stiches thered not pick up for bobin its not come out.
Wow. If I understand your attempt at English. Your machine made a noise and now won't sew or pick up the bobbin thread.
First change your needle and make sure it's full inserted and correctly oriented in the needle bar. Do a test stitch on scrap fabric.
If you still have problems.. check the timing. The shuttle hook should just be starting to pass the needle scarf when the needle is at the lowest point of travel.
I hope that helps you. Good luck.
Aug 20, 2012 | Kenmore 15218 Mechanical Sewing Machine
Sewing in reverse cuts top thread, help? Please!
the fabric & thread & needle may not be compatable
try changing the needle- it may be damaged
the horrible grinding noise needs to be check --the machine needs to be serviced
check for burrs on the needle plate & on the bobbin
some sewing machines don't do with strong material
Mar 18, 2012 | Sewing Machines
When I am sewing it will sew about 3 stiches and then jam.. It does it if I change weight of material or it will s kip stiches.
Skipped stitches is usually indication that needle is blunt or burred.
Or if you are using a sharp needle on knit fabrics it may also skip a little.
Not sure what you mean by "change weight of material" - do you mean you are sewing applique and going from one fabric weight onto another? or different sewing projects?
It is a good idea to change your needle for each new project (4-6 hours sewing time max) and choose the right type of needle and size for your project.
However, the jamming part sounds more like thread tension issues, especially if the jamming is happening underneath from the bobbin. If stitching is loose underneath, then top tension is the problem and visa versa.
Recheck your threading path, top and bottom tensions and that you have good quality thread. Change the needle, rewind a fresh bobbin, thread up and try again.
There is really good info on www.sewing.about.com or I refer to my Singer Sewing Machine textbook at lot too. Good luck.
Mar 30, 2011 | White Sewing Sewing Machines
Janome sewing machine Harmony 2139 The bobbin thread is not connecting with the needle to make a stitch. We have put in a new needle. Using needle 4 tension
Take out the thread. Now cut the end of thread using a pair scissors. Now try that again. Once i had the same problem and later found out that the uneven end of the thread caused problem by refusig to move around freely hence preventing the stich formation
Dec 02, 2010 | Janome Sewing Machines
I have gotten my Mother- in -Laws sewing machine it said on back it is a 1764180 kenmore 24 stich , I can not get it to sew stiches in row it skips , I had no instructions with it for settings etc. can...
Hi Vicki
It's possible that the needle is too small for the size of thread you are using. Also make sure thread is not wrapped around the needle and that the needle is properly seated in the needle bar. It's also possible that the machine needs to be timed and serviced to correct this problem. Is it possible to get the users manual from your MIL? It would have the information you need reguarding needle sizes and threading, etc.
~<Ray>~
Oct 29, 2010 | Kenmore Sewing Machines
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
Bobbin thread not feeding into the upper needle thread
completely unthread the machine....ensure the needle piston shaft is in the correct position and retread the upper. reinstall the bobbin and turn the machine by hand to engage the bobbin thread. Draw the bobbin thread through the stitch plate and with the needle thread, allow to trail off the back. attempt to sew a piece of scap material.
please let me know what happens at this point.
clarkco
Feb 08, 2009 | White Sewing Fashionaire Sewing 2380...
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
83 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
