Question about Gateway Computers & Internet
When i put a dvd in the dvd drive it says it is a cd and is full.so i can't write to a Dvd disc.
  • Gateway Master
  • 4,806 Answers
Put a normal dvd in, see if it reads it, try this with cd's also, if the it reads them, you may have bought a set of coasters ( **** dvd's ) get a different brand one and try that if you have one to hand regards
Posted on Nov 21, 2008
Dell gx 260 there is no disc in the drive.
OK, first of all you said you put a blank DvD in the drive. Make sure your dell has a DvD writer. Look on the drawer of the drive and see does it say DvDrw or DvDROM. It has to say Rw for rewritable and not ROM for Read Only Media. Maybe you have a Combo Drive that is DvDrom and CDrw which means it will read both DvD's and Cd's but in can only Write CD's.
If in fact you do have a DvD writer make sure you're not trying to put a Blue Ray disc in the drive.
Lastly, remove the DvD from the drive. Click Start/My Computer. Notice what it brings up as to your DvD Drive. Does it Say DvDrw or just plain ole DvD. DvD means it will only read a DvD.
Mar 20, 2012 | Dell OPTIPLEX GX260/SMT P4 2GHz 512MB...
I put in a dvd/rw disc and it will not read it. in My Computer it comes up as a blank disc (cd)
Make sure the discs you are using are compatible with your drive. Some drives will burn dvd - r discs but not dvd + r discs. Hope this helps.
Jun 09, 2011 | Lite On LH-20A1H DVD RW Dual Layer Burner
When I insert a dvd in the slot it does not read the dvd however cd is displayed. What may be the reason?
-cd corrupted ( try clean the disc with cleaner. If you don't have it then try using perfume(with alcohol). I'm also have try many time using my BOSS perfume. Is alright.
-dvd player have problem( try clean with cd cleaner )
-disc dvd is empty (or damage). Right click to DVD ROM .Choose properties, and see what capacity for that dvd. If it have zero use and full capacity is not zero, that mean dvd disc that is still zero.
May 27, 2011 | Acer (KV.16X04.007) DVD Drive
I am trying to burn 16x dvd-r discs but it keeps saying disc is full, when i click properties it shows full in the blue but no files are on the disk
the cd/dvd burner might not be getting enough power
make sure the leads that are attached to your cd/dvd drive have secure connections and are not bad/faulty or just replace them include electrical extension leads
or you might have bad batch of rewritable cd/dvd's
hope this helps
Nov 11, 2010 | Mad Dog Multimedia Computers & Internet
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
I have a gateway with windows xp and my dvd rom won't read dvd-r
it could be that your dvd drive is only able to read dvd discs not to burn them, if its a combo drive its very likely a cd burner that can read dvd discs.
if you send me the brand and model or the full name / details of the drive I could check on it.
Jun 03, 2009 | LG GCC 4320B CD-RW/DVD-ROM Burner
Not find disc in drive
Sounds like you need to install a DVD decoder, Roxio, WinDVD and PowerDVD are good decoders.
May 20, 2009 | Sony DRU 530A DVD±RW Burner
Audio works but not installation disk
HEY is it playing other DVD'S check is it a combo drive , dvd wirter or a cd writer, if its only a cd wirter then it won't play DVD
Aug 26, 2008 | LG GCE 8481B CD-RW Burner
Computers & Internet Logo
22 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
