The fresnel screen itself would cost about $300 if that is damaged. If it is an additional screen covering it, then I would expect it to cost about half that price. I'm not sure however if it can be easily removed. Sometimes it's a friction fit, other times it can be a real chore. You may want to contact a local repair shop to do it.
I replaced the screen on my 62 inch projection TV for about $50 and the the picture quality is good! Have a sheet of plexiglass cut to the EXACT size needed. BEFORE installation it MUST be frosted on both sides by either a fine particle sandblaster or by sanding it VERTICALLY on BOTH sides with a power sander and a fine grade paper. If this is only an OUTER protective screen and the image is projected on the inner screen then DO NOT frost the replacement screen, just install it.
On my RCA P46770CK, all you do is lift upwards on the screen and the bottom can slide forward releasing the whole screen. Look for something like that if no catch screws visible.
I have a Mitsubishi WD-52631. When I power it on it has a message that says;TV will shut down in a...
(More)
I have a Mitsubishi WD-52631. When I power it on it has a message that says;TV will shut down in a few seconds, check to see if the airflow is blocked.Then it shuts off. Does this mean the lamp is going bad and I need to take it in to be replaced?
We have a AWA lcd tv with no remote control, we have pressed the wrong button on the tv console and...
(More)
We have a AWA lcd tv with no remote control, we have pressed the wrong button on the tv console and now there is a child lock on and we cannot turn the tv on at all. How do we remove the child lock?
Tv picture turned off. there is still sound. the repairman took the main board out and never came...
(More)
Tv picture turned off. there is still sound. the repairman took the main board out and never came back he said he couldnt get the replacement board so now I gotta find it on my own
