SOURCE: profiling requires 4mb free space
I have the same problem, and the RCA website is a piece of ****.
SOURCE: not working properly
The same thing happened to mine... The firmware is probably corrupted. Go to RCA's website (http://support.rcaaudiovideo.com/select.aspx?u=downloads) and download the firmware update for the model that you have. You'll most likely have to choose the "reformat" option (which will erase all of your music) to get it to work, but you can try doing it without it first. When I did it, I had to totally reformat, though... Good luck!
SOURCE: profiling requires 4mb free space; reformat required
1. Disconnect the player.
2. Download the new driver from http://support.rcaaudiovideo.com/
3. Install the software on your computer, then run it.
4. Reset your player by either pressing the reset button or removing the AA-battery from the player.
5. While holding down the "Play" key on your player, connect it to the PC via the USB cable. Release the "Play" key when you see the progress bar moving and "initializing" text. If you cannot see the "initializing" text, please disconnect your player and try again.
6. Click the "Start" button to upgrade your player
Found the solution to my problem.
I use Linux, so what I did was go to the folder of the MP3 device and hit Ctrl+H which brought up a folder called trash. It still had all the songs I had previously deleted so it was taking up the space.
If you can figure out how to do that on Windows you should get it fixed. Hope this helped anyone that has had this problem.
