Question about Everex StepNote NC1500 Notebook
Laptop is on but no screen and no response to any actions
The computer is on, the fan blows, the wireless indicator is lit, but it does nothing. It charges, however, it doesn't indicate its charging. Stepnote 1502 less than a year old. If I could get something on screen, it would help. Plugged into Different monitor but still nothing but black screen.
  • 2 more comments
  • chryvine Nov 21, 2008
    tried that when hooked up to other monitor but nothing. It just sounds like its on and does nothing. When the problem first arose, it would take a long time to boot then go black and nothing. Now it doesn't appear to boot but sounds like it is.
    Hard drive only lights up a quick flash when first turned on, then nothing from it. doesn't really sound like booting now that I listen closer, just fan on.thinking hard drive or motherboard but thought I would definately get motherboard singing if it was motherboard.
    yes.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    did you use the Fn + one of the F keys to switch between monitors?
  • Everex Master
  • 4,806 Answers
It does not sound like inverter has failed because you are using the correct method to switch screens, if the hard drive indicator is flashing/blinking that seems ok too.
latops are supposed to beep when there is hardware failure to give us engineers an idea of the problem, you haven't mentioned that, but i know there is hardware by the description.
start by taking the ram out, this could be faulty or disslodged and the machine sounds like boot but no display, clean the contacts on the ram with a pencil eraser (they work best) and dust off the rubber with a dry clean cloth, make sure there is no build up of dust there the ram slots, if you have more than 1 ram module try them one at a time.
see what happends
keep me informed please
regards
Posted on Nov 21, 2008
  • Lee Hodgson
    Lee Hodgson Nov 21, 2008
    motherboards are silent, its the other devices which are noisy, did you remove the memory and clean it like mentoned above?
  • Lee Hodgson
    remove the battery and try on AC power only, if still no joy remove hard drive, try again, if still no joy after that the problem would seem to much more serious
Bought a new battery pack (jensen brand) for panasonic 5.8GHz gigarange supreme KX-TG6500 2Line cordless phone and it wont charge.
check that you got the right make of battery for the charger
some phones use a nicad battery and others use a lit ion battery
2 different recharegable batteries -- 2 different chargers required
Nov 29, 2016 | Panasonic Lands Phones
How do you recharge jump start system
put a battery charger for a car on the + and - leads and this will recharge it if you do not have the correct power pack recharge transformer
Jan 09, 2012 | Stanley Black & Decker Stanley J5c09 500...
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
I've misplaced my users manual for my Stanley J5C09 jump starter
Go to www.baccusglobal.com and link the Stanley link and then the "manuals" link and it should be there
Dec 27, 2010 | Stanley Black & Decker Stanley J5c09 500...
On the Jazzy select what color for charging indicates fully charged, red, green?
scraig Lights on the joystick all lit up to the far right and the green light lit on the charger. Red indicates charging or blinking red indicates error in charger. Hope this helps
Nov 20, 2010 | Pride Mobility Products Jazzy Select
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
I have a problem with asus eee 901. I've just bought it. It had linux, but it was changed into windows xp. Since it had been fully charged only once I was using it on battery and setting it up with new...
Remove the battery for a couple of minutes while the unit is not plugged into the a/c adaptor. Reinstall the battery, plug the unit into the a/c adaptor, and see if it will boot up.
Mar 14, 2009 | ASUS Eee PC 901 20G Notebook
Toshiba L20 - screen appears dead?
Try to plug in an external monitor on laptop to check if there is a problem with your LCD.
Plug in the external monitor then boot the computer. If still nothing happens try removing the battery and the adapter, let it rest for a minute then plug in only the adapter and try to boot up with out the battery.
Hope this helps.
Sep 13, 2008 | Toshiba Satellite L20-S310TD Notebook
Purple light
The purple (majenta) light usually means it is in pairing mode. Is it possible that the button is stuck pressed in??
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Jun 09, 2008 | Motorola Mobility H700 Wireless Headset
Can't Turn on/Charge
I had the same problem when I purchased mine. There was nothing to do except return it for a replacement.
Jul 25, 2007 | Samsung WEP170 Wireless Headset
Everex StepNote NC1500 Notebook Logo
164 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
k24674
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
