Question about IBM ThinkPad T40 2373 Notebook
When using laptop on lap, screen blanks out and turns fuzzy
I have a T40, and it works fine if it is placed on a flat surface such as a desk. But when any sort of pressure is exerted on the case unevenly, the screen blanks out and freezes, which is an extremely aggravating problem. I have narrowed down the part of the case that seems to cause the blank out- it is below the left side of the keyboard, above the pentium sticker. Is there a component directly in this area that would cause the screen to short, and is this a common problem? Any help would be appreciated, I have never disassembled a laptop but would not be uncomfortable doing so. Thanks!
Chris
  • Anonymous Mar 26, 2009
    My laptop has been doing the same thing its a compaq and it turns fuzzy for like a split second and then goes abck to normal but it always goes fuzzy no clue why it does that im not sure is its the computer or is its a virus??
  • IBM Master
  • 19,396 Answers
That is frequent on thinkpads, aftwer few years.
Because of a fault in the design , the motherboard inside get bent and the soldering joint ath the video chipset lose contact.
If the problem get worse you will be unable to use the computer, I have two like that here.
Try keeping the laptop always on a rigid surface , like a table. Despite the name, do not use it on your lap.
Even if you want to disassemble, you need to replace the whole motherboard to fix this , usually is not worth the repair.
Posted on Nov 21, 2008
Lap top freezes and screen goes fuzzy
Use your guarantee, looks like it is overheating.
Jan 24, 2012 | E-Machines Computers & Internet
Touchpad does not work while laptop is charging
Voltage can mess with digitizer of any touch screen. Most like the aftermarket power cord is drawing slightly too much power or slightly too less. My guess is slightly too much and when you are setting it on your lap, you are grounding that extra current. Find an original power cord and see if problem persists.
I’m happy to help further over the phone at https://www.6ya.com/expert/tarik_f88885a87e319a0d
Oct 24, 2017 | Computers & Internet
My laptop is over heating
Hi! first, i would like to ask if you are using cooling fan? if does, then i'll give you some tips on how to keep your laptop from overheating
1. Turn off your computer and allow it cool down.
2. Work with your laptop on a flat surface. The rubber feet on your laptop are designed to allow airflow to the underside of the computer, so if you are working on a bed or other soft surface, you cut off the airflow. If you do want to work away from a desk or table, try keeping your computer on your lap, exposing the underside to air.
3.Shut down your laptop before placing it in your carrying bag.
4 Give your laptop a bit more lift to increase the airflow under the machine. Two simple, flat rulers placed along the front and back edges of your computer is enough to increase the flow of air and keep your laptop cool.
5 .Unplug your charger as soon as the battery is full. A common mistake people make is leaving their computer plugged in at all times. However, the constant source of electricity will heat your battery and in turn overheat your laptop. Only charge your computer as long as necessary.
Hope this would be helpful.
Thanks for usinf FixYa : )
Sep 13, 2011 | Dell Computers & Internet
Sony's not do ing the consumer right ONTHIS laptop IT gets hot &ONE of the service tech AGREED and the fan is not big enough to cool it down therefore it fries the laptop, Ihad this services three...
ONE: The 'tech' should have told you that the air intake port, and Fan/Heatsink assembly, needs to be clean inside that laptop.
TWO: The 'tech' should have recommended a laptop cooler, if it is known that the fan is too small in cooling capacity.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3486&name=Notebook%20Coolers
THREE: The laptop CANNOT be placed directly on a carpet floor, it must be on a hard flat surface. (Which means should not be placed on your lap)
Oct 30, 2010 | Sony VAIO NS Series Notebook
I have a compaq presario x6000. every time i place the laptop on my bed and turn it on it cuts off within 5 minutes. but when I place it on a desk and turn it on it does not cut off. do not understand why...
The reason is because when the laptop is placed on the bed the cooling vents are blocked and the CPU overheats and shuts down. When the laptop os placed on a flat surface there is sufficient clearance between the bottom of the laptop and the flat surface of the desk to provide sufficient air circulation.
If you wish to use the laptop in bed then place the laptop on a flat surface and not let the bed clothes cover the laptop's cooling vents.
Aug 12, 2010 | Compaq Presario X6000 Notebook
Over heating. Turning off
use hitsink paste between Processor (CPU) and Hitsink Fan.
Apr 15, 2010 | Compaq Presario CQ60-220US PC Laptop
Blank Screen
Well it is possible to install a new screen relatively easily... It is a bit of a mission, Ya need to get a replacement screen & driver board and do the reverse procedure from removal. A screen can be got from say, Ebay, or the net. Otherwise get a reputable place to do it for you.
Jan 26, 2010 | Acer Aspire 3610 Notebook
My medion laptop keeps overheating
change your laptop heat sink fan
Nov 11, 2009 | Computers & Internet
Have 2 lap tops,1 desk top. Desk top and 1 lap
For the 2nd laptop, first upgrade the LAN card driver, then reinstall the driver if the problem is not resolved with the driver upgrade.
Hope this helps.
Aug 29, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Display Becoming White
First, to verify if it is your display adapter, connect an external monitor to your laptop and see if it displays fine. If it is fine on the monitor, then we know that it is from your laptop screen(in this case, it is either you first check from a technician if it is the colour that has to be refilled or if you need to purchase a new screen). If not then it is from your display adapter(could be from corrupt display drivers). In this case, you would have to re-install new drivers for your display adapter(you can download it from your system manufacturer's website if you don't already have it).
Thanks
Dec 01, 2008 | Computers & Internet
IBM ThinkPad T40 2373 Notebook Logo
206 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
