Question about Blitzz Technology (BWP612) 802.11b Wireless Adapter
Limited or no connectivity with my blitzz 802.11b wireless card
Everytime i try and connect to my router it says limited or no connectivity i have the correct network key.. i was wondering if there was a blitzz customer service number if yall couldn't help me
My computer did the samething so i took it to a computer repair shop and they reconfiguered the network connections and now it works fine, but bring your router with you so they can reconfigure that too. it cost my 25 bucks and i think that it was worth it. It saved me alot of headache
Posted on Mar 04, 2009
I am trying to connect to a wireless network router and everytime i try to connect it has limited connectivity to the desired network
Hi ,
you need to go into your router settings and see if you have it set correctly , 2nd- check your firewall settings to make sure there are ok .................let me know if this works , if not we will go into more detail in the network settings .........................Good luck Roy
Aug 27, 2011 | HEWLETT-PACKARD G42-415DX Laptop
Trying to connect wirelessly to 2 wire. I get limited access icon
Hi groveland1,
I see that you are having issue with your Internet Connection, Limited or no connectivity is a possible issue with your network key / security key on the router and your laptop.
1. Try and check the network key in your router.
2. Check your network settings in the Laptop and see if the security settings in your Laptop is the same as the security/network key in your Router.
3. If possible recreate your wireless connection in windows for a fresh connection from your Laptop to your Router.
4. Change your Network Key in the Router and in your Laptop see if it will connect in-case you may have forgotten you old Network Key.
Hope this helps.
Apr 04, 2011 | 2wire (1000-400108-001) Router
Need to configure router to att modem
In case of 2 wire router the security key is on the back side of the router.
if you turn it upside down you will find 10 digit number. That might be your security key for the wireless network.
if network key is not there or it is not working then you will need to open the setup page of the router and find out the network key.
if you have any computer connected to the router then use that computer to find out the network key.
Click Here for more information about the routers and network
Oct 25, 2010 | Blitzz Technology (BWA611) Router
Loss of wireless connection
Is your laptop able to connect to other networks? If so, your router maybe at fault. Reset the router, if it still doesn't work, you may need a new router. If your laptop has issues connecting to other networks, the wifi radio in your laptop may need to be replaced.
Jan 06, 2010 | Zoom X6 (5590) DSL Modem (55900003)
Limited connectivity - wireless
Verify if your wireless option on the router is enabled.
Also when you setting the wireless on the router, be sure that channel is not on automatic. Specify a channel number. After that try to connect again to wireless
Aug 05, 2009 | Blitzz Technology BWA711 (B3WL000900)...
Can not laptop to connect
Wireless Troubleshooting Checklist 1. Unplug power from Router and Modem for 3 mins. 2. Restart computer. 3. Make sure your wireless device is active: a. Verify that your wireless device is turned on. Some laptops have a physical hardware switch located on the case. Make sure this is in the ‘On’ position. Other laptops use a Function Key combination (e.g. Dell uses Fn+F2, IBM uses Fn+F5)
b. Open Network Connections (from the System Tray or from the Control Panel). Verify that your wireless Connection is Enabled. If not, right-click on your wireless connection and select ‘Enable.’
4. Renew your connection. Changes elsewhere on the network can sometimes knock out your connection. To reconnect quickly, click Start, Run in XP (or press the Windows key in Vista), type ipconfig /renew, and press Enter. 5. Check for interference. Have you installed any new wireless devices (speakers, baby monitors, ect)? If so unplug them. Make sure your wireless network has a unique name (ssid). 5. If other wireless devices can connect to your router and only your computer can't. a. Try deleting your wireless profile. If you are using the built in wireless for windows go to Control Panel> Network Connections right click on Wireless Network Connection and select View Avaliable Networks. On the left hand side under Related Tasks click on "Change the order of preferred networks" select your network name and click remove. Now try reconnecting to it. Be sure to type in the correct security key. b. Disable your software firewall. 6. If you can connect to the router but not the internet. a. Click Start > Run type CMD into the box and click OK to open a command prompt.
At the prompt type netsh winsock reset catalog
This will Reset WINSOCK entries to installation defaults
When the first one is done tyoe this netsh int ip reset reset.log
This will Reset TCP/IP stack to installation defaults
Reboot the machine. b. Change the name of your wireless network (SSID) c. Change the wireless security key and or wireless security type. Some devices are not compatible with the WPA encription. be sure to use a HEX password Hex is 0-9 and A thru F only. The Hex key
must be exactly 10 characters long for WEP64, or 26 characters long
for WEP128. If you're using 5 characters or 13 characters, it's
really ASCII, not HEX. Please don't forget to rate this solution.
Jun 15, 2009 | Blitzz Technology BWA711 Router...
Wireless connection
Check the ip addres of your pc. You might be having an ip of 169.x.x.x(that means limited or no connectivity). If this is the case, you were not able to completely connect to your wireless network because your network is secured. Try to connect to your wireless network again and make sure you enter your correct network key. When you check ip address again you should have an ip of 192.168.x.x(depending on your router's ip)
Mar 13, 2008 | Blitzz Technology Wireless G BWU713...
Blitzz Wireless Router not working correctly
Here is a site that will help you setup & or troubleshoot ya rig.. http://portforward.com/routers.htm
Aug 14, 2007 | Blitzz Technology (BWA611) Router
Blitzz Technology (BWP612) 802.11b Wireless Adapter Logo
119 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
Will Halftowaite
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
